Skid Plate Bolt thread stripped - Bimmerfest - BMW Forums
Old 09-12-2018, 09:14 AM
hoppydidit hoppydidit is offline
Mein Auto: 2004 325i 2007 X3 3.0Si
My '07 E83 needs the front driveshaft replaced. Had a back issue & ask my son to help with this project. Unfortunately he stripped the left front bolt on the skid plate turning it the wrong direction. Anyone removed one of these bolts with this problem? Once the bolt is out, What does it thread into? We tried a pry bar to put pressure on the fastener in hopes it might grab hold of the good threads & get it to come out. No luck with that. I looked at RealOEM, but it doesn't show what the bolt threads into. My concern is after the bolt is removed, what am I working with to thread a new bolt back in?
Old 09-12-2018, 09:27 AM
swampX3 swampX3 is offline
Mein Auto: bmw++many
happens sometimes
>the bolt threads into the subframe .....we have found several stripped over the years ......just go a little oversize/tap in a new thread close enough ..... or...... drill the hole out a bit and use a nut and bolt with washers....also .....the plate is described as "structural".......so ....get it nice and tight
Old 09-12-2018, 09:30 AM
they bolt all kinds of skid plates on
>some images of skid plates simply bolted on with aftermarket fasteners
https://images.search.yahoo.com/yhs/...g&action=click
Old 09-12-2018, 09:36 AM
16mm bolts
>don't know why pelican says the 16mm reinforcement plate bolts are not reusable .....but .....some good views in this diy
https://www.pelicanparts.com/techart...e_Removing.htm
Name:	Screen Shot 2018-09-12 at 10.34.58 AM.jpg
Old 09-12-2018, 01:02 PM
Thanks all. I just wasn't sure what I would be working with once the bolt is out. Looks like I'll try an oversized bolt & tap. Thanks again.
Old 09-15-2018, 06:20 AM
a good pic of two of the holes in the subframe
>this one shows two of the tapped holes in the x3 subframe and the big red ground strap
Name:	Screen Shot 2018-09-15 at 7.18.16 AM.jpg
Old 09-15-2018, 06:32 AM
more good views of the frame etc
>not too much effort needed to retap the holes in this thickness plate
>get on to these fiftees kid videos for lots of good tips and views
Name:	Screen Shot 2018-09-15 at 7.29.23 AM.jpg
ID:	818463   Click image for larger version
Name:	Screen Shot 2018-09-15 at 7.26.54 AM.jpg
Old 09-15-2018, 09:19 AM
Thanks SwampX3. That video does help. You mention the ground cable. That was one of the earliest things I did on my X3 to cure the slow crank. I made a strap from 2 gauge battery cable, & cured the slow starter for good.
