325i long crank/ hard start - Bimmerfest - BMW Forums
E36 (1991 - 1999)
Old 12-09-2019, 11:34 AM
Zesinlijn Zesinlijn is offline
Mein Auto:
Hello!
I need some help from you e36 gurus!
My 92 325i with vanos developed a long cranking issue.
When the car has been stationary for longer than 5 minutes the cranking takes more time than normal. When the engine finally turns on it takes 5 seconds to reach a steady idle rpm
If you start the car after it just had been running it will start up just fine.
The car drives great, has full power but sometimes when still cold it will judder slightly at a red light.
Already replaced without succes: fuel pump, fuel filter.
Any ideas in which direction to start looking?
Cleaning icv? Cam position sensor? Coolant temp sensor?
Thank you & greets from Belgium
Old 12-10-2019, 12:21 AM
hornhospital's Avatar
D'oh, You Kids!
Mein Auto: E24x2,E36x3,E30x2, F150
Welcome to Bimmerfest!
Is the VANOS oil line clear? Is the wiring to the VANOS solenoid intact? Is the fuel pressure regulator vacuum line intact?
Quotes to live by:
Ken Kanne, Silverhill, AL, Bimmerfest Site Moderator
BMW-CCA #441426
1993 325is M3 clone"Ashlyn"; 1993 325is "Elvira"; 1985 635CSi "Katja"; 1984 633CSi "Sylvia"; 1987 325is "Odette";1995 318is"Bebe "; 1985 325e "Hazel Ann"
Old 12-11-2019, 12:20 AM
Mein Auto:
I will check all the vacuum lines this weekend
how could the vanos oil line and wiring interfere with startup?
Old 12-11-2019, 12:51 AM
D'oh, You Kids!
If the VANOS isn't returning to idle position it's advancing the cam when it doesn't need to be. It's unlikely that the VANOS is the problem, but if the wiring is damaged, it could be. It's easy to check, figured I'd throw that in there as a possible.
Quotes to live by:
BMW-CCA #441426
Old 12-11-2019, 01:32 AM
Mein Auto:
I see! thanks for the advice. the Vanos Wiring looks in good condition..
the car didnt have fault codes stored in the system as well..
