E36 318is clicking under acceleration - Bimmerfest - BMW Forums
E36 (1991 - 1999)
Old 12-19-2019, 05:17 PM
JRichardson JRichardson is offline
Mein Auto:
I've owned this car for about 6 months now, and have changed out just about every bushing/mount other than the rear subframe and diff mounts. Today, after letting the car sit for about a week, I decided to drive it. While cruising around, I noticed a clicking sound coming from underneath the rear of the car ONLY during acceleration. As soon as I let off the gas, or push in the clutch, it immediately stops. I have never experienced this, and it drives me nuts. If anybody has experienced this, or knows what's going on, help me out!!
Old 12-19-2019, 05:43 PM
hornhospital's Avatar
D'oh, You Kids!
Mein Auto: E24x2,E36x3,E30x2, F150
Welcome to Bimmerfest!
A couple things to look at:
Check the C/V joint at the differential. If it make ANY noise when the driveshaft is turned back and forth, the joint is failing.
Check the heat shield around the exhaust and driveshaft.
Quotes to live by:
Ken Kanne, Silverhill, AL, Bimmerfest Site Moderator
BMW-CCA #441426
1993 325is M3 clone"Ashlyn"; 1993 325is "Elvira"; 1985 635CSi "Katja"; 1984 633CSi "Sylvia"; 1987 325is "Odette";1995 318is"Bebe "; 1985 325e "Hazel Ann"
Old 12-19-2019, 05:50 PM
Mein Auto:
I appreciate that. I got under the car and shook the axles, driveshaft, tires, nothing seemed abnormal....first bmw, and bought it in rough running condition for super cheap. I like projects, and this seemed like a solid one. But never had anything like this happen, and dont know what to be looking for
Old 12-19-2019, 08:26 PM
D'oh, You Kids!
Intermittent noises are the worst to find. You have to figure out what is moving under acceleration and try to find what's hitting where. I wish I could be of more help. Good luck.
Quotes to live by:
BMW-CCA #441426
