1992 325i maf sensor issue an question - Bimmerfest - BMW Forums
E36 (1991 - 1999)
Old 01-06-2020, 01:42 PM
Dizzy2217 Dizzy2217 is offline
Mein Auto:
I have a 1992 325i .. problem is my original maf sensor broke. So I ordered the 89 dollar one off a1auto I believe. Well worked ok..ish during this summer when it was warm. But now i cant keep it running on cold starts it jumps into limp mode ect. So my question is I have the 6 pin maf sensor connection. What other cars or bmws have this same maf seems other years up to 99 even a 91 I've checked doesn't have the same connection .. can i splice the wires an reconnect a connector from another bmw to fit the maf or does anyone know a car with a maf sensor that is interchangeable .. I've search the forums but cant seems to find detailed info on innerchangable parts
Old 01-08-2020, 05:02 PM
Mein Auto:
Anyone?
Old 01-08-2020, 07:43 PM
hornhospital's Avatar
D'oh, You Kids!
Mein Auto: E24x2,E36x3,E30x2, F150
Welcome to Bimmerfest!
Probably can't use one designed for a different BMW, but since you know the part number you can search realoem.com to see what other cars it may have been used on.
My guess the problem is the cheap MAF sensor you bought. Sensors are something you never want to replace with cheap parts.
Quotes to live by:
Ken Kanne, Silverhill, AL, Bimmerfest Site Moderator
BMW-CCA #441426
1993 325is M3 clone"Ashlyn"; 1993 325is "Elvira"; 1985 635CSi "Katja"; 1984 633CSi "Sylvia"; 1987 325is "Odette";1995 318is"Bebe "; 1985 325e "Hazel Ann"
Old 01-09-2020, 04:07 PM
M-technik-3 M-technik-3 is offline
Mein Auto: 88 M3x2 86 330i 4 e36's
Are you in EU or NA? Sounds as if you have a M50b25 non vanos engine. That is the only 6 prong HFM It would look like this.
Old 01-11-2020, 03:21 PM
spyderg0d spyderg0d is offline
Screamin demon
Mein Auto: 1995 325ic
Probably a vacuum leak.
