JB3 map switching - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > The Best of Bimmerfest! > Forced Induction
Forced Induction
Aftermarket superchargers & turbos as well as tuning for stock BMW turbos (N54 motor - 135i / 335i / 535i). Force-fed discussion to make your car go faster
Old 01-17-2009, 06:57 AM
pkitch pkitch is offline
Mein Auto: '17 X5 40e
JB3 map switching
Apologies if this has been detailed elsewhere, but I couldn't find details. I also thought I would ask here rather than BMS directly in case info is useful to others...
-With the new gas pedal map switching, once your desired level is selected, will this stay the default map after car is restarted? I.e. do I need to re-select it each time I get in the car?
-Assuming the mapping levels stays in place per above, is it unique to the car's 'profile'? By profile, I refer to the car settings that are unique for each key. My GF obviously has different settings for hey key, and would be great if her key also set the mapping to level 0, whereas mine retained whatever level I had last time I drove it.
Thanks in advance...
'17 X5 4.0e
'16 650ix
'13 328i Msport
'11 M3 E90 6MT
'08 335i
'06 Z4
Old 01-20-2009, 08:10 PM
I sent this question to Terry from BMS direct, and his response as follows for anyone interested:
1) Yes
2) It would be nice, but no. The JB3 can not detect which key is in.
So the selected map will be persistent for all drivers.
-Paul
'17 X5 4.0e
'16 650ix
'13 328i Msport
'11 M3 E90 6MT
'08 335i
'06 Z4
Old 02-20-2009, 06:01 PM
darkphantom darkphantom is offline
Mein Auto: E93 335i
Do you know if the car has to re-adapt every time you switch a map?
Old 06-10-2016, 01:50 PM
Michy530i Michy530i is offline
Mein Auto: 530i
How do you edit your profile
