Disable easy entry/exit steering wheel movement - Bimmerfest - BMW Forums
Old 04-03-2012, 11:31 PM
alphaod's Avatar
alphaod alphaod is offline
Mmmmmm…
Mein Auto: F15
I hate the fact the steering wheel moves out of the way every time I turn off the car. It stopped doing this a while ago and I thought I disabled it somehow, but couldn't remember if I did. I prefer the manual adjustment levers for this very reason.
Well today I was trying to adjust my steering wheel when I noticed it no longer adjusted. Moving the little lever did nothing. Then I listened closely and I found the steering wheel was trying to move, but something was stuck. I turned off my car and I noticed the same sound. So my conclusion was my steering wheel adjustment broke, which is why it stopped moving out of the way. I wanted to adjust the wheel, so later in giving up, I hit my steering really hard.
Now the problem: I can adjust my steering wheel again, and it moved out of the way when I turn off my car.
Is there way I can disable this? I would hate to be somewhere remote, only to find the steering wheel stuck in the upright and out of the way position.
2015 BMW X5 xDrive50i
BMW CCA 509766
Old 04-04-2012, 03:11 AM
ductman's Avatar
ductman ductman is offline
Mein Auto: 2011 X5 35D /2011 M37X
Unfortunately no, I also would like the ability to disable this as I know down the road this motor will fail, on my wife's Infinity it can be disabled as well as my previous MDX.
Old 04-04-2012, 08:22 PM
AndyX5d AndyX5d is offline
Mein Auto: 2010 X5 3.5d
I've had mine for two days and I already want this to be disabled. It seems like it takes forever for it to move anyway, and like you I know it's just a matter of time before that thing is toast.
Old 04-04-2012, 08:56 PM
Penguin Penguin is offline
Mein Auto: Z4 and X5 Diesel
I agree. It would seem to be very easy for BMW to provide a disable option in the "settings" portion of the i-drive software. Even my Mother's 2008 Taurus offers a disable option for this feature.
I'm constantly surprised how far behind the times BMW is with their software. I guess that's one area where the U.S.-based manufacturers still have an advantage.
Old 04-05-2012, 05:27 PM
seems like there would be a fuse that one could take out. Only problem is that it more than likely does more than just the adjustment motor.
Old 04-05-2012, 06:26 PM
True.
But even if it only did the steering wheel, that would disable the ability to adjust the steering at all -- I just want to get rid of the automatic exit/entry motion, not make it so other-sized people cannot drive the vehicle without replacing a fuse.
Old 04-05-2012, 07:11 PM
BenF12400 BenF12400 is online now
Mein Auto: 2006 X3; 2010 528;2013 X5
Originally Posted by Penguin View Post
True.
The motor should last a long time - we have a 2004Rx and a 2008 RX and the motors have thus far had no problems (each vehicle has over 125000 miles). Don't see why a German car would have a shoddier motor.
Old 04-05-2012, 09:25 PM
Do a Google on BMW window mechanisms... or Auto transmissions... or radiators... etc.
Old 06-11-2014, 05:06 PM
karlpaulsen karlpaulsen is offline
Mein Auto: X5
There is a way to disable the steering wheel easy exit/entry feature...I had it done when I first bought my X5 in 2012...it takes what I'll call a "cheat code" (combination of unrelated buttons/switches/levers) to make it stop. I had my radiator replaced and now it's active again. Neither the dealership nor BMW genius knows (or is willing to share) how to deactivate it again.
Old 06-11-2014, 07:23 PM
TinyRK's Avatar
TinyRK TinyRK is offline
Ja mei!
Mein Auto: G12
I think you can disable it via coding
Disable EINSTIEGSHILFE_HOEHE & EINSTIEGSHILFE_LAENGE and you should be good to go.
Find a coder and he can code this and more.
Sent from BMW Assist in the ditch
BMWCCA Member# 481324
Old 06-11-2014, 07:41 PM
Mein Auto: X5
You may be right...I had it disable a couple years ago and don't recall if I did it myself or the dealership did it after I brought it in. Interesting that the customer service reps don't seem to have a clue, even after they talk to the mechanics.
Old 06-11-2014, 10:52 PM
dzampi dzampi is offline
Mein Auto: 2010 BMW X5d
Hate the feature as well so what I did was pushed the wheel all the way up, released the lever and then pushed it all the way up again which made the steering wheel move just a tad more even though it seemed that can not be moved any more...this stopped the wheel moving/assisting me while entering/exiting.....
Old 06-12-2014, 04:59 AM
Mein Auto: X5
Thanks...I will give this a try. Is the wheel now permanently in the full up position (and does it have to stay in that position) to keep the easy exit/enter from working? I ask because I drive with the SW in the full down and extended position.
Old 06-12-2014, 05:57 AM
It is in the full up position and it stays there does not move anywhere when I open the door/shut engine and exit... Mind you I'm 6'4 (long arms) so I keep it all the way up and pushed all the way in...hopefully it works out for you....
Old 06-12-2014, 12:51 PM
Mein Auto: X5
Long Arms
Unfortunately, the full up setting doesn't work for me...5'7 and short arms . Thanks for the recommendation, though.
Old 09-02-2015, 07:04 AM
rpoitras rpoitras is offline
Mein Auto: 2010 BMW X5 3.0si
I'm dredging up this old post because there is a way to disable this 'feature'. I, personally, find it's useless because I'm out of the car and locking it by the time it finishes its sequence. I've looked into programming and cannot see a way to disable it, although I'm sure the setting is there tucked away someplace. I searched my entire vehicle settings for those two parameters listed a few posts above and came up with nothing so now I do the next best thing.
Disclaimer: I do not recommend anyone doing this as it applies force on the mechanism, and there is a potential for it to break, so this is for informational purposes only.
All you need to do is right after turning off the vehicle (and the wheel starts moving up) is to apply downward pressure to force the wheel to stop moving. There must be an anti-trap mechanism similar to what the windows have so when you stop the wheel from moving it kicks in and disables the feature from that point onward. The only thing is that afterwards you cannot re-adjust the wheel position otherwise it will be re-enabled. The best thing to do is adjust your steering wheel how you like it then adjust it a little lower so that by the time you stop it from moving up it will be about where you want it. The telescoping all the way in doesn't start until the wheel is all the way up, if I recall, so that adjustment shouldn't change.
Old 09-02-2015, 11:07 AM
lpcapital lpcapital is offline
Send a message via AIM to lpcapital Send a message via MSN to lpcapital Send a message via Yahoo to lpcapital
Mein Auto: Wasp & Duc
Thanks for that!!! I'll give it a try...
Old 06-23-2016, 02:19 PM
agn7786 agn7786 is offline
Mein Auto: E63 645Ci
I had the same issue. Did some research and I can confirm that you can easily code out the steering auto-tilt function in NCS Expert.
On a E63/E60 you'll need to access the SZM module and set "EINSTIEGSHILFE_HOEHE
" to "nicht_active". This disables the auto-tilt, but leaves the steering adjustment options fully functional.
Old 06-28-2016, 05:17 AM
smassey321 smassey321 is online now
Mein Auto: 09 X5d - 06 325i
Just did this last week
Disable easy exit steering column
Chassis : E70 (E70,E71,E72)
Module : IHKA_E70.C08
ELSV_EH_LAENGE -> aktiv -> nicht_aktiv
ELSV_EH_NEIGUNG -> aktiv -> nicht_aktiv
Old 07-01-2016, 08:55 AM
TurboBusa TurboBusa is offline
Mein Auto: 2012 X5 5.0i
Ok... That's good information, is the same true for an E70??
Old 05-08-2017, 07:52 PM
nothing.new2me nothing.new2me is offline
Mein Auto: '04 325xi
How do you program this?
Old 11-01-2019, 08:29 AM
16valex's Avatar
16valex 16valex is online now
Mein Auto: 530I Blown/ X5 35D
Nice! Thank you for sharing.
02- 530-Blown
10-X5 35D
Old 11-02-2019, 02:01 AM
robnitro robnitro is offline
Mein Auto: x5 35d e70 2011
Use ncsexpert with ncsdummy. Read up on it to find out how to do this, it's better than the tricky method which locks it that way until you clear the codes.
FYI: I can't see your signature because I turned off that option since people like to put big images in theirs, which this site doesn't let you block...
