W.a.r. and newb ? - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > The Best of Bimmerfest! > Forced Induction
Forced Induction
Aftermarket superchargers & turbos as well as tuning for stock BMW turbos (N54 motor - 135i / 335i / 535i). Force-fed discussion to make your car go faster
Old 06-28-2017, 12:26 PM
spyderg0d spyderg0d is offline
Screamin demon
Mein Auto: 1995 325ic
W.a.r. and newb ?
Have m50tub30 with all the NA mods.
I've come across Miller's war system as my best bet until I become better coordinated in tuning. At which I will be first NA to learn and then boosting on a m90.
At what point is the stock MAF no longer good to use with war. Same question with injectors?
I'm trying to just make out with the basic war package of chip and software with cables for 400 bucks and am fretting that Il later just get the MAF and injectors that are offered in the 1 grand war package when I boost.
Are there other cheaper MAF and injector options?
Also. It says that you cannot see live data through the chip. But would I not be able to see it through the round connector in the engine bay with a live diagnostics reader while the car is running like the stock dme for notes for map change?
Old 07-16-2017, 02:10 PM
MisterM52's Avatar
MisterM52 MisterM52 is offline
///Power Extraordinaire
Mein Auto: 318Ti
On a M50 you are better off using a piggy back system from what I gather, Grab some $100 white giant injectors from the forums, the stock maf is good if you scale it, and maybe delay the voltage using a resistor or a diod like we did, you will have issues if it reads over 700KG air under 3000RPM like we did. First do your blower install if thats what you are up to. We have ready made M90 brackets (short snout M90's from Jag only) if you like. But other than that, nothing much to it.
"So we've come to the conclusion that BMW just has parts laying around they decide to throw on cars for no reason."
The HMW Supercharger Project - for M50/M52/M54/S50/S52/S54 & M42/M44
