Misfiring of Cylinder No. 6 - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > M5 & M6 > E60 M5 (2006 - 2010)
Old 05-08-2012, 03:29 PM
sam joe sam joe is offline
Mein Auto: 2006 M5
Hello guys
I have a strange problem with my M5 - where it recently giving me an reduced power message where the RPM redline goes all the way into the 4.5 & the car losses power big time and start rattling.
My problem it sometime it does this and sometimes it works fine, but mostly of the time it is giving me a reduced power message.
On the computer it showing misfiring on cylinder 6 -- all the time, when the reduce engine appear misfiring on cylinder 6 error comes up on the computer.
I replaced the plugs, and change the coils, cleaned and changed couple of the injectors but the same problems is still happening
Any advise
Sam
Old 05-24-2012, 01:41 AM
hmouradian10 hmouradian10 is offline
Mein Auto: E60 M5
i have this same problem when i step on it on the freeway i get ''engine malfunction reduced power'' ....it says cylinder 3 misfire everytime..i put new plugs i swapped coils and injectors still same problem with cylinder 3 anyone have this problem resolved?
Old 09-19-2012, 04:10 PM
suprlude suprlude is offline
Mein Auto: e60 M5
Ionic control sensor is your problem! I has the same issue with my e60 m5 and did everything you did until i found out about the ionic control sensor. There are two, swap out the left bank to the right bank one and your error code will now read cylinder 10 misfire, if so you know for a fact the ionic control sensor has gone bad, hope this helps you and saves you some $!
Old 12-10-2013, 05:06 PM
azziat azziat is offline
Send a message via ICQ to azziat Send a message via AIM to azziat Send a message via MSN to azziat Send a message via Yahoo to azziat
Mein Auto: m coupe
Question cyl 4 missfire
i have this issue right now
is anyone knows what is the problem?
swaped spark plugs, coils, ionic module injectors still misfire on 4
Old 12-11-2013, 06:51 AM
Mein Auto: e60 M5
its 100% the ionic sensor, its located right on the front bank, swap the left and right bank and your cel code should change to cylinder 10, then youll know its the sensor.
Old 05-16-2014, 07:07 AM
Baramack Baramack is offline
Mein Auto: 07 m5
Hey guys i got misfire on cylinder 6-10. Any advice before replacing all coils and plugs? Will try switching ionic control sensor
Old 07-05-2017, 02:52 PM
CorySoTall CorySoTall is offline
Mein Auto: 2009 535i xdrive
I have the same issue on my '09 535x. I just replaced my first bank of injectors and now I'm getting a misfire and cylinder 6. The injectors didn't fix my problem so let's hope this does!
Thanks man!
misfiring on cylinder 6, reduced power light
