Searching for Dyno South Jersey - Bimmerfest - BMW Forums
E36 (1991 - 1999)
Old 04-29-2019, 03:56 AM
Greenday694's Avatar
Greenday694 Greenday694 is offline
Mein Auto: 93 BMW 325is
Hello, after a year of trying to Road tune my car , and asking quite a few people at the local shops where I can get my car dynoed. I figure it's worth a shot to post in here. I did find a few within reasonable distance, but once I told them my car and ECU, they didn't want to touch it.
This is my setup. 93 325is. Engine, I built about a year ago. 3L M50 Stroker. All ARP Hardware. Tri metal bearings. Cometic 140 head gasket. And replaced everything else with Quality Parts. Eaton m122 H supercharger, 16 PSI air-to-air intercooler. Link G4 plus ECU. 60lb injectors. Aeromotive boost referenced fuel pressure regulator. Stage 3 clutch single Mass flywheel. Zf320 Z transmission. 315 LSD.
I have been driving it for the past year. Tweaking the tune a little here and a little there. My afr's look good right now. And drives pretty well. But I know my timing is out of whack. I tried to set the timing map a little on the safe side. But without a Dyno I'm never going to get it running the way it should.
Thanks to anybody who can help. Keith / hmw.
Sent from my LM-X210VPP using Tapatalk
Old 04-29-2019, 05:33 AM
bluptgm3 bluptgm3 is offline
Mein Auto: 99M32
Talk to Ben at Rogue Engineering, he should be able to put you in contact with a dyno.
Similar Threads
The absolute basics of how to select replacement tires for your beloved BMW E39 bluebee E39 (1997 - 2003) 68 07-29-2015 11:33 AM
Shop in south jersey Yogixxx 7 Series - E65 / E66 (2002 - 2008) 0 07-25-2012 06:52 PM
Cutting up a Babe Ruth jersey hockeynut Off-Topic 6 10-20-2003 04:44 PM
In remembrance of 9/11 AF Off-Topic 6 09-11-2003 11:12 AM
