I can rip this out, right? - Bimmerfest - BMW Forums
E36 (1991 - 1999)
Old 04-24-2019, 03:54 AM
Engel12626's Avatar
Engel12626 Engel12626 is offline
Mein Auto: '95 525iT, '97 328is
Dealing with a vacuum leak, pretty sure I found the source but these 24 year old vacuum hoses are getting replaced anyway. One branch in this maze of hoses goes to the vacuum controlled flap in the muffler.
Can the vacuum tank, hoses, and valve be removed and capped off without causing any issues?
ID:	849149   Click image for larger version
Old 04-24-2019, 08:42 AM
hornhospital's Avatar
D'oh, You Kids!
Mein Auto: E24x2,E36x3,E30x2, F150
Yup, commonly referred to as the golf tee mod. You can just remove the hose at the muffler end and plug it with a golf tee or something similar.
Quotes to live by:
Ken Kanne, Silverhill, AL, Bimmerfest Site Moderator
BMW-CCA #441426
1993 325is M3 clone"Ashlyn"; 1993 325is "Elvira"; 1985 635CSi "Katja"; 1984 633CSi "Sylvia"; 1987 325is "Odette";1995 318is"Bebe "; 1985 325e "Hazel Ann"
Old 05-07-2019, 08:14 PM
Duanob328iC Duanob328iC is offline
Mein Auto: 1997 BMW 328iC
I just folded mine and tied with a small zip tie. No golf tee needed.
BMW 328i: Inspiring over-confident drivers since 1936.
Old 05-07-2019, 08:26 PM
dc_wright's Avatar
You can plug the hose at the muffler with no issue, but I believe if you remove the vacuum switch in the engine compartment you'll get a fault code because it's monitored. At least it was on my '96 328iC.
Old 05-07-2019, 08:37 PM
southpark11235's Avatar
southpark11235 southpark11235 is offline
Mein Auto: 1999 BMW 323is
The vacuum switch is for the SAP not the exhaust flap. Removing the switch does set a code so I just left it plugged in with no vacuum lines. For the exhaust flap I plugged the vacuum line at the intake manifold because I was messing with the intake anyway.
Alex//1999 323is - power e46 M3 seats, style 43 rims, 328 exhaust, Z3 rack, Bilstein PSS coilovers
//1992 Mazda Miata - cat delete, power windows, oil filter relocation
“We got about ten minutes before this entire county is up in flames. If you want to live, you’d better step on the gas! Oh wait is this a Tesla? Sh!t! Well, step on the prissy pedal, we're going to die!” – Cartman
