Rehab of 1994 326 ic - Bimmerfest - BMW Forums
E36 (1991 - 1999)
Old 04-17-2019, 02:40 PM
MH325ic1994 MH325ic1994 is offline
Mein Auto:
Looking for suggestions to replace/repair inside door panels for 1994 325i conv. Glue failed and panels are separating/warping. I tried pop-riveting with washers, but panels are still warping. Also looking for suggestion for kit to replace the carpet. Thank you.
Old 04-17-2019, 03:29 PM
hornhospital's Avatar
D'oh, You Kids!
Mein Auto: E24x2,E36x3,E30x2, F150
You have to get EVERY SPECK of old glue off both surfaces before gluing them back together. The glue I found that works is "Shoe Goo". I actually sanded the gluing surfaces to get below the greasy-feeling black coating on the pressed wood panels. I don't know what that stuff is or why it's on there, but it effectively prevents glue from sticking to the pieces.
Turtle Labs makes a metal repair part that replaces the fragile strip that connects to the door at the top of door card. I've used them on my own car and they work great.
Ken Kanne, Silverhill, AL, Bimmerfest Site Moderator
Amateur Extra ham radio operator KO4AXN, see you on 40 meters!
BMW-CCA #441426
1993 325is M3 clone"Ashlyn"; 1993 325is "Elvira"; 1985 635CSi "Katja"; 1984 633CSi "Sylvia"; 1987 325is "Odette";1995 318is"Bebe "; 1985 325e "Hazel Ann"
Old 04-17-2019, 03:33 PM
D'oh, You Kids!
The Turtle Labs piece
Name:	2018-02-25 22_1555540362721.05.42.jpg
BMW-CCA #441426
Old 04-17-2019, 03:35 PM
D'oh, You Kids!
Glued on the door card using "Shoe Goo".
Name:	2018-04-02 19_1555540538523.11.12.jpg
BMW-CCA #441426
Old 04-18-2019, 02:46 PM
spyderg0d spyderg0d is offline
Screamin demon
Mein Auto: 1995 325ic
If the board is warping, spray it with a fine mist on the inside particle board. Let it sit for about an hour or 2. Then you should be able to pin it straight with aome rulers and vices. Let it sit and dry for a day. It should be the way you left it. See above for plastic retainer repair. I use loctite and garilla glue 2 part resin. Its held a couple of my door panels together for half a decade now.
Similar Threads
Rehab of 1994 326 ic MH325ic1994 General BMW Questions 1 04-18-2019 04:42 AM
For kicks: 540i 0-60 and 1/4 mile times (stock) rate well against many cars: Waveho E39 (1997 - 2003) 48 12-31-2015 12:39 PM
1994 318is computer HELP! Ibebach E36 (1991 - 1999) 2 08-29-2005 03:26 AM
NJ BMWCCA Round 2 Elwood Motorsports, Racing & Track 75 07-06-2004 04:45 AM
