Radiator fan not working - Bimmerfest - BMW Forums
E36 (1991 - 1999)
Old 04-25-2019, 07:17 PM
318tiallday 318tiallday is offline
Mein Auto:
I have an 97 318ti (e36) and today the fan stopped kicking on and the car is over heating. Someone told me it could be the fuse and the diagram on the fuse box says #48 under the steering wheel but I cant seem to find it.
:I have another thread but I think I posted it in the wrong section:
Old 04-25-2019, 08:50 PM
hornhospital's Avatar
D'oh, You Kids!
Mein Auto: E24x2,E36x3,E30x2, F150
Download this:
https://redirect.viglink.com/?format...orums&txt=This
Don't worry, it's safe. That should help a lot.
You have either a blow fuse (maybe 48, maybe not} or the fan relay has failed.
Edit: does you 318ti have a mechanical fan (belt driven)?
Quotes to live by:
Ken Kanne, Silverhill, AL, Bimmerfest Site Moderator
BMW-CCA #441426
1993 325is M3 clone"Ashlyn"; 1993 325is "Elvira"; 1985 635CSi "Katja"; 1984 633CSi "Sylvia"; 1987 325is "Odette";1995 318is"Bebe"
Old 04-26-2019, 01:32 AM
Mein Auto:
Electric.
The link isnt working.
Old 04-26-2019, 10:33 AM
Mein Auto:
It says image broken.
Old 04-26-2019, 10:41 AM
D'oh, You Kids!
Well, phooey. That's too bad that the link no longer works. It was a .pdf version of the Bentley E36 manual.
Quotes to live by:
BMW-CCA #441426
Old 04-26-2019, 01:14 PM
Mein Auto:
Update: figured out it wasn't the fan itself. I just took some spare wire and hooked it to the battery. So I suppose the next step is the relay, fuse, or wiring I suppose. I finally found the fuse but any idea where the relay would be?
Edit: yea I've been trying to find a downloadable version. Thanks tho
Old 04-26-2019, 05:56 PM
Engel12626's Avatar
Engel12626 Engel12626 is offline
Mein Auto: '95 525iT, '97 328is
Name:	Screenshot_20190426-205358_Adobe Acrobat.jpg
Old 04-26-2019, 06:00 PM
spyderg0d spyderg0d is offline
Screamin demon
Mein Auto: 1995 325ic
The coolant temp sensor/fan switch in the radiator clicks on low or high, sends signal to the dme, the dme turns on the accessory fan relay and turns the fan on. If your fan works, jumped at the socket, and the relay clicks when tested, its theradiator coolant temp sensor/fan switch or the wireing from the switch to the dme which does indeed end up broke on alot of cars.
The only time the car needa the accessory fan is when the car is sitting still or very low speeds. If your car is overheating while moveing and the fan isnt coming on, chances are you have air in the cooling system and needs to be bleed. Its entirely possible the engine temp senaor is getting hot coolant stuck, while the radiator is holding the cold coolant, which is essentially a air bubble trapt system.
Similar Threads
2011 328i electronics not working imarichards E90/E91/E92/E93 (2006 - 2013) 4 03-06-2017 02:06 PM
IDrive controller and parking assistant button not working? frivas F10 / F11 (2011 - 2016) 3 06-11-2016 10:09 PM
BMW Live stopped working - help please rpoitras BMW Coding and Programming 0 03-24-2016 04:58 PM
ABS and ASC working intermittently. Huezo E39 (1997 - 2003) 6 10-25-2007 01:18 PM
