2011 bmw 550i need help - Bimmerfest - BMW Forums
Old 11-16-2019, 08:47 PM
F10Bmw5n63 F10Bmw5n63 is offline
Mein Auto:
My car is giving me a lot of codes and i already changed the ignition coils all of them 2 times plus i got my injectors checked amd there good i got a new battery too about a year ago
Fault Code: 140502
Fault Explanation: :Misfiring, cylinder 5: exhaust gas harmful to start
operation
Fault Code: 140602
Fault Explanation: :Misfiring, cylinder 6: exhaust gas harmful to start
operation
Fault Code: 140002
Fault Explanation: :Misfiring, several cylinders: exhaust harmful to
startup
Fault Code: 140402
Fault Explanation: :Misfiring, cylinder 4: exhaust gas harmful to start
operation
Fault Code: 120408
Fault Explanation: :Boost pressure control, shutdown: pressure
build-locked / Boost pressure control: shutdown due to reaction
Fault Code: 140102
Fault Explanation: :Misfiring, cylinder 1: exhaust gas harmful to start
operation
Fault Code: 118501
Fault Explanation: :Mixture control 2: mixture too lean, excessive
deviation
Fault Code: 107001
Fault Explanation: :Throttle angle 2 - absolute pressure suction pipe
2, comparison pressure too high / Limit Exceeded: intake manifold
pressure 2, correlation - throttle angle
Fault Code: 140801
Fault Explanation: :Misfiring, cylinder 8: injection is switched off
Fault Code: 20A608
Fault Explanation: :Turbocharger coolant pump, control: Pump
blocked
Fault Code: 20A504
Fault Explanation: :Turbocharger coolant pump, control: Line break
Fault Code: 142002
Fault Explanation: :Misfiring: tank level too low
***10007;
Nov 15 2019 - 5 (F10, F11, F18)
