Battery CCA Test Result - predictive? - Bimmerfest - BMW Forums
Old 12-06-2019, 01:21 PM
Bright Spark Bright Spark is offline
Mein Auto: 535i
Can a Cold Cranking Amps test predict the battery life remaining?
Test result yesterday at a local tire/battery shop:
Measured: 782 CCA
Rated: 950 CCA
Temp: 71-deg F
Voltage: 12.32v
The battery is approaching six years old (original delivery). Is it possible to proactively avoid a dead battery in a cold airport parking lot -- without wasting money?
How much time do I have left?
Old 12-06-2019, 02:20 PM
Doug Huffman's Avatar
Nuclear engineer
CCA is meaningless relative to your BMW. At the point that it becomes an issue, you have bigger problems. Your BMW ECU maintains a State of Health figure of merit that is the end of life criterion. I have not seen BMW say what parameter is tracked but strongly suspect that it is minimum voltage at maximum cranking current.
A six year old battery is 3/4 through its MAXIMUM expected lifetime under the very best of circumstances; a BMW is very hard on its battery, never fully charging it.
Replace your battery for peace of mind.
Old 12-06-2019, 04:20 PM
Mein Auto: 535i
Many thanks, Doug - much appreciated.
Old 12-07-2019, 07:01 AM
tgame80 tgame80 is offline
Mein Auto: 12 E350 bluetec
My 528 is 5 1/2 years old and I'm also concerned about the battery. Is it worth going to a different brand to save the money? would i need the BMW dealership to reset the code or is that fairly easy?
Old 12-07-2019, 09:11 AM
Nuclear engineer
BAtteries are commodities. Buy the cheapest with adequate specifications. Fully functioned BMW aware coding devices can register a new battery. New batteries must be registered for best service life.
The only relevant electrical specification for a modern car is ampere-hours AH capacity. ALL other specifications are obsolescent. When they become an issue, you have bigger problems than the battery.
Old 12-07-2019, 03:42 PM
surly surly is online now
Mein Auto: '11 F10 535xi
Preferably also including AGM construction.
If you switch away from AGM you'll need to have the car coded for flooded chemistry.
Old 12-08-2019, 07:20 PM
Thanks for your reply. What is the best code resetter to buy? There are different ones out there and i want to get the most cost effective.
Old 12-08-2019, 08:03 PM
bhiguy bhiguy is offline
Mein Auto: 530i
I have a 2013 535i which i purchased in Dec 2012, and still have the original battery, which is an AH 105. Although no hints of any problems, the battery is the original and nearly 7 years old, so I figured I should be proactive and replace. Calling around, I am seeing quotes for "exact-fit" replacements that don't specify how many AH. Do I need to insure that the batteries are AH105?
Thanks Scott/BHIGUY
Old 12-08-2019, 08:32 PM
balfor balfor is offline
Mein Auto: 2016 535i
You might want to look online, I've noticed the 950CCA batteries are listed as 105AH but sometimes you see a cheaper 850CCA or less with under 100AH. The 105AH are a bit more expensive but probably worth it especially if your car came with it. Not sure if you have a "batteries plus" or similar store near you but they can be an alternative to the dealer and a lot of times have coupons online.
Old 12-11-2019, 07:42 AM
Kist2001 Kist2001 is offline
Mein Auto: BMW
I bought the BMW battery charger when I first got my f10. I figured to keep the battery in good condition just like the Porsche guys do. I charged it monthly. It made no difference and my battery was replaced under warranty. They are easy to change and code. Just consider them a commodity.
Old 12-11-2019, 09:42 AM
Nuclear engineer
Batteries are commodities. The only electrical specification that matters is ampere-hour AH capacity. All other electrical specifications are obsolescent. When they become an issue then your BMW has bigger issues.
