No name on FDL Editor - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > X Series > X6 F16 (2015 - Current)
The all new 2015 BMW X6 is the second generation luxury cross over. BMW referes to the X6 as a Sports Activity Coupe (SAC) as it combines the attributes of an SUV (high ground clearance, xDrive and all-weather ability) with the stance, styling and roof line shape of a coupe. The F16 BMW X6 is build side by side with the F15 X5 at BMW's BMW's Spartanburg, SC plant. Read all about the second generation BMW X6 here!
Old 10-22-2015, 11:25 AM
rafaelroni rafaelroni is offline
Mein Auto: BMW Z4
Hi everyone.
When I read the CAFD Codes from my F25, the FDL Editor shows no name on parameter folders. I only get a dot "." in place of that.
It is like this image: https://drive.google.com/file/d/0B4S...ew?usp=sharing
E-SYS version: 3.23.4 (tried a 3.2.61 version too).
PSDZDATA: 3.56.4.003 (tried a earlier version too).
I already tried to copy the files from Data\PSDZDATA\SWE to Data\SWE (same files on both folders)
Thanks in advance._a_
Old 03-18-2016, 12:58 AM
Jamesx6 Jamesx6 is offline
Mein Auto: x6 m50d
same problem no name for folders just ...
Originally Posted by rafaelroni View Post
Hi everyone.
Old 03-20-2016, 12:30 AM
Almaretto's Avatar
Almaretto Almaretto is offline
Super Moderator
Mein Auto: Test Vehicles
Are you using the E-sys Launcher? You may want to update your Psdzdata as well. Can you read your *.ncd with TM NCD / CAFD Tool?
Old 03-20-2016, 02:52 AM
Mein Auto: x6 m50d
with new v.58.1_PSdZData all good thanks
Old 03-20-2016, 12:33 PM
Almaretto's Avatar
Super Moderator
Old 03-21-2016, 12:28 AM
Mein Auto: x6 m50d
Speed limit info
Hi
anyone knows how to activate speed limit info? my car got the option but i live in Australia so this option deactivated by BMW Australia should i follow these steps?
1) 8TH to VO no need i have it already
2) HU_CIC, 3001 EXBOX, SPEEDLIMIT_INFO = aktiv got NBT
3) KOMBI, 3000 Anzeige_Konfiguration, SPEED LIMIT GENERATION = sli_gen2 Got multi function digital Cluster comes with X6 f16
4) KOMBI, 3003 FZG_Ausstattung, SPEED_LIMIT = aktiv
5) KAFAS, 3010 SLI_CODING, SLI_ON_OFF = SLI_ON
6) KAFAS, 3010 SLI_CODING, CODE_ELECTRIC_HORIZON = nicht_aktiv
7) KAFAS, 3010 SLI_CODING, Country_code_display = wert_3 Not sure Wert 3 is the same for Australia or not
8) KAFAS, 3010 SLI_CODING, UNIT DISPLAY = wert_4
9) KAFAS, 3020 KAFAS_COMMON, COUNTRY_VARIATION = wert_3 ?! Australia?
10) Turned on Speed Limit Info in the display.
regards
James
Old 06-26-2017, 02:14 AM
DK_fatty DK_fatty is offline
Mein Auto: F16
8TH Speed Limit Info
Hi
regards
James
Same situation here.
8TH Speed Limit Info - Doesnt work in Serbia.
ecu, f25, fdl
