Is this normal? - Bimmerfest - BMW Forums
Old 08-27-2008, 06:28 PM
SJK SJK is offline
Mein Auto:
Is this normal?
When I put the shift lever on R, the car goes backwards. Is this normal, or do I need to have my i-drive reflashed?
Also, I was thinking about 22" rims. Will this make the problem worse?
Old 08-27-2008, 06:31 PM
Edev's Avatar
Edev Edev is offline
BMW Genius @ BMW Portland
Mein Auto: M Coupe
isnt R for reverse in automatics?
maybe im just a tard..
BMW Genius @BMWPortland.
2000 Z3 M Coupe
Old 08-27-2008, 06:38 PM
Orient330iNYC's Avatar
Orient330iNYC Orient330iNYC is offline
Flying monkey herder
Mein Auto: Daihatsu Terrios
you need progman version 33.5.i to fix this issue. integration level will be N.5.4.T.T
also, 22" rims are not compatible with your car. either 21 or 23" rims are recommended OE fit. 22 is divisible by 11, which is bad.
Past: 2001 330i ZSP/ZPP/Step
Past: 2004 S60R 6MT Sport
Past: 2016 F34 335i xDrive ZCW/ZDA/ZDH/ZTP/ZMP/2V5/5DL
Present: 2019 G01 M40i ZDA/2VF/ZPP/ZPX/688/3AC
Old 08-27-2008, 07:04 PM
SJK SJK is offline
Mein Auto:
I should add that the car is a 2008 (May build) E90 Sedan, Sapphire Black, Terra leather, with a sport package, and aftermarket trunk liner. I thought there might be a service bulletin for this configuration.
Old 08-27-2008, 07:08 PM
Uncle Fester's Avatar
Uncle Fester Uncle Fester is offline
Mein Auto: 2005 330 Ci Convertible
You have the trunk liner in backwards. Turn it around and the car will go forwards in the R position. As a bonus, you'll get a number of different settings which will make it go backwards at different speeds.
330CiC (ED)
X5 E70 4.8i
Old 08-27-2008, 07:18 PM
blaze739's Avatar
blaze739 blaze739 is offline
Mein Auto: 2008 BMW 335i
haha i love it
2008 335i Coupe 6MT, Premium, Sport, Nav, Heated Seats, CA, PDC, iPod
Alpine White, Coral Red Leather, Aluminum Trim
Mods: JB3, Modified CDV, GY F1 Asymmetrics, 35% Huper Optik Extreme X3 tints, RPI scoops, ACS aluminum pedals
Delivery: 6/21/08
Old 08-27-2008, 07:24 PM
Adumbration's Avatar
Adumbration Adumbration is offline
Mein Auto: 2016 A6
You need to reset the reverse pedal response. Start the car and put it in R and then floor it for 30 seconds. Make certain you have enough room behind your car.
Old 08-27-2008, 07:27 PM
captainaudio's Avatar
Worlds Foremost Authority
On the BMW Steptronic, R stands for "Race". You should only shift into "Race" at speeds above 85 MPH.
Drivers Club at Lime Rock
BMWCCA
Cayman Club Nor'Easters
Porsche Club of America
Sports Car Club of America
M Gruppe (New York Metro/New England Regional Director)
Mount Washington Observatory
Old 08-27-2008, 07:37 PM
djfitter's Avatar
djfitter djfitter is offline
Mein Auto: BMW '08 535i
very entertaining.
dj
'08 535i
Deep Sea Blue
Cream Beige
Dark Poplar
6 Sp Manual
Sport
Premium
Rear Shades
BMW CCA #392316
Old 08-27-2008, 07:38 PM
AzNMpower32's Avatar
Tar Heel Faithful
+1, I thought R was like the race-mode found in the Nissan GTR. I haven't tried out out yet, but it should be a blast!
Old 08-27-2008, 07:46 PM
zekeman1 zekeman1 is offline
Mein Auto: 335XI
[QUOTE=SJK;3503395]When I put the shift lever on R, the car goes backwards. Is this normal, or do I need to have my i-drive reflashed?
Hmmmm, I think a reflash might be in order. On my 335XI, putting it in R usually allows me to make right turns. Have you noticed that you aren't able to do that? That might be the problem, especially if you're going backwards.
Z
Old 08-27-2008, 07:59 PM
bmwKbiker bmwKbiker is offline
Mein Auto: K1200RS, E93/335i:4cruzin
Sounds like you should start pursuing lemon law options immediately!
Old 08-27-2008, 08:00 PM
unless thats a dinan trunk liner, your warranty is void.
Old 08-27-2008, 08:41 PM
SJK SJK is offline
Mein Auto:
I was afraid of that. If I take out the trunk liner before service, will the computer show that I was using a trunk liner?
Old 08-27-2008, 08:55 PM
headshot headshot is offline
Mein Auto:
This is why I never take Active Steering...
Old 08-27-2008, 09:00 PM
you need to have the Trunk Liner Electronics Module's adaptations reset.
you'll need a DiS Plus diagnostic head with TIS cd level 8675309. and a male goat.
unless its a V3 trunk liner with diagnostic invisibility. then you might just have limp modes due to liner target not being met.
unplug the battery then follow this sequence with your iDrive controller and your steptronic paddles:
Up Up Down Down L-R L-R ShiftUp ShiftDown ShiftUp ShiftDown Press Accelerator.
Old 08-27-2008, 09:02 PM
tturedraider's Avatar
Freedom isn't free!!
Oh, I assure you, when you try it it will be like nothing you've ever experienced!!
www.bmwcca.org
Old 08-27-2008, 09:04 PM
Pocket Rocket Pocket Rocket is offline
Mein Auto: 08' - 335i
I thought the "R" was for request for refund! You may want ask for one if it continues to go in reverse...
Old 08-27-2008, 09:06 PM
you must have the engine at redline before engaging R(ace Mode) or else you void the factory maintenance on the blinker system, you will no longer get free factory fill on the blinker fluid. i suggest picking up some of this:
Old 08-27-2008, 09:08 PM
SJK SJK is offline
Mein Auto:
I just got back from trying that. It doesn't go backwards anymore. Thanks for the help.
Old 08-27-2008, 09:09 PM
i hope you didnt end up over spinning your muffler bearings
Old 08-27-2008, 09:14 PM
Fredric Fredric is offline
Mein Auto: '07 328xiT
Actually, the "R" stands for regurgitate, which is what will likely happen after following all of the directions given above, unless you have the swivel-seat option, which allows you to face the rear of the car.
Old 08-28-2008, 07:05 AM
brucebanner brucebanner is offline
Mein Auto:
That gives your car 100 lives i fyou do it before pressing start
Old 08-28-2008, 09:15 AM
jwac's Avatar
jwac jwac is offline
Mein Auto: '14 335i 6MT
Does BMW recommend only synthetic? Is it covered under the free maintenance plan? I only use BMW-recommended products in my car.
2014 335i Sedan 6MT
Estoril Blue | Black leather | Dark Burl Walnut
M Sport | Premium | Driver Assistance Plus | Technology | Dynamic Handling | Cold Weather | 19" 403M Wheels | M Sport Brakes | Harman Kardon | Rear Window Shades | Auto High Beams
09.16.13 European Delivery
Past:
2011 335i Coupe 6MT (ED)
2010 135i Vert 6MT (ED)
2007 335i Coupe 6MT (ED)
2006 325i Sedan 6MT
Old 09-10-2008, 12:43 PM
Exclamation SJK - Did you ever figure out why ?
SJK - Did you ever figure out why your car went in REVERSE when you placed the shifter in "R" ??? Just Curious!
