New BMW owner - X3 general questions - Bimmerfest - BMW Forums
Old 07-08-2019, 11:59 AM
yawning yawning is offline
Mein Auto:
Hi,
New to BMW, due to growing family wife and I just traded in our cars and I decided to get an X3 and am loving it so far. I've had a dealer look it over and give it the general thumbs up and have ordered new air filters (engine/cabin) as I usually replace those immediately after buying a car.
I asked the dealership for a maintenance schedule and the dealer said almost all maintenance work on the car is "as needed" and there is no schedule but I was wondering if you guys had any general tips or suggestions of things I should do now or soon to get the best service and life from the car.
2013 X3 - 55,000 miles.
I've read that the transmission fluid should be changed out at some point because BMW's lifetime transmission fluid is BS. When should I do that?
I managed to pull my FSC code and update to the 2019 maps, anything else worth updating?
Old 07-08-2019, 09:47 PM
SEANRGEE SEANRGEE is offline
Mein Auto: F11 TOURING 530d LUXURY
What model is it please?
Old 07-09-2019, 05:14 PM
Mein Auto:
xDrive 28i
Old 07-09-2019, 09:15 PM
02420X3 02420X3 is offline
Mein Auto: 2011 X3 35i
OK, you should be aware of a problem with 2013 28i's and timing chains. The guides have been known to fail, and to destroy engines. BMW has extended the US Warranty to 70,000 miles, but I haven't read of similar extensions in other countries. Whether or not the problem is limited in scope or widespread is unclear. It is something which you may want to research.
Old 07-11-2019, 11:06 AM
Nerdboss Nerdboss is offline
Mein Auto: 2015 X3 35i
Originally Posted by yawning View Post
Hi,
Generally the transmission fluid is changed at 100k now for the ZF 8 speed.
2016 535i | M Sport | Cold Weather Package | Driver Assistance Package | Premium Package | Driver Assistance Plus Package | Multi-Contour Seats | Dynamic Handling Package | Harmon Kardon Audio | Carbon Black Metallic | Ivory White Nappa
2005 530i | Jet Black | Sport Package | Heads up display | Adaptive Xenon | Navigation | Rear Sunshade
Old 07-11-2019, 04:35 PM
DBU's Avatar
DBU DBU is offline
Mein Auto: Glacier Silver X4 M40i
To the OP and in the continuance of the quoted post, here are a few things to do/consider:
- Take the car to the dealer and give him the key. They can then tell you if your vehicle is covered by the extended warranty on the Timing Chain (TC)
- Open oil filler cap and visually observe the TC (with the engine stopped). Do you see any shiny marks on the top part of TC? (Hopefully not).
- Close oil filler cap and start engine. Have someone rev it up a few times. Is there a whining sound that increases with the RPM? (hopefully not).
- Do extensive searches on this forum and Google for something like "N20 TC failure."
- Do NOT use the Automatic Start/Stop (ASS) feature. Have it coded out or simply turn it off each time you drive the car.
- Consider changing the TC tensioner. BMW has used three different TC tensioners on the N20 engines. Having the latest couldn't hurt, could it? There is a DIY somewhere on this forum (I wrote it).
- Finally. if you see shiny marks or hear the whine, document it with video and plead your concern to the dealer. Even if they disallow it, it may come in handy later on if that proved to be wrong.
These engines have the valves going into the cylinder in a space sometimes occupied by the piston. Timing is critical, and if the TC fails the engine needs to be replaced.
His: 2017 X4 M40i - Glacier Silver with all the options (except cold weather stuff) - not needed in SoCal
Hers: 2015 X4 28i - Glacier Silver - loaded M-Sport
Old 07-12-2019, 04:37 AM
scostuart scostuart is offline
Mein Auto: 2014 F31
Here is the list of cars that have the 7/70 timing chain extension
https://bmwtechnician.com/2019/01/31...ain-7-70-list/
Wifes----2016 Dodge WD R/T
Mine....2016 F25 Msport
Retired:
2014 F31
2013 Q5 3.0T PP Sline
2013 WK2...HEMI
2011 E90 Sedan
2008 E70
2004 E46 Sedan
Old 07-12-2019, 07:00 AM
hogwldfltr hogwldfltr is offline
Mein Auto: X3
Does this issue carry over to the N55 as well? Also if you know, if not, why not?
Old 07-12-2019, 09:34 AM
Mein Auto: 2014 F31
No.
It is a N20/N26 problem.
Retired:
2014 F31
2013 WK2...HEMI
2011 E90 Sedan
2008 E70
2004 E46 Sedan
Old 07-15-2019, 04:37 AM
Z4530i Z4530i is offline
Mein Auto: Z4 3.0si
Transmission fluid interval
I did transmission and transfer case change at 80,000 miles (2012 x35); based on recommendation else in this forum.
