Video module. Video INPUT possible? - Page 9 - Bimmerfest - BMW Forums
Old 07-18-2019, 03:15 AM
vibbelito's Avatar
vibbelito vibbelito is offline
Mein Auto: 2007 730i E65
Originally Posted by irish745 View Post
That sounds promising
The electronics engineer is going to analyze the pictures of the MMIF and the CD. So hopefully he's able to help in some way.
Old 07-18-2019, 03:38 AM
cimdahers cimdahers is offline
Mein Auto: BMW e65 730d
Maybe in between it is possible to include also the signal splitting issue
Sent from my LYA-L29 using Tapatalk
Old 07-18-2019, 03:52 AM
irish745 irish745 is offline
Mein Auto: E66 760Li individual
Originally Posted by cimdahers View Post
That be great id love to have a cheaper way of splitting the lvds than the original splitter
Sent from my SM-G390F using Tapatalk
Old 07-18-2019, 05:15 AM
vibbelito's Avatar
A splitter could maybe be included in it but I think it will be much easier and cheaper to just split the hdmi signal after the conversion. There are many redaly available tiny hdmi splitters for cheap.
Skickat från min SM-G955F via Tapatalk
Old 07-18-2019, 05:29 AM
Thanks,
You are right, but anyway, in order to maintain center armrest rear screen with its LVDS signal from the rear MMIF You should split the LVDS signal before it is converted into the HDMI signal for the common use tablets/monitors.
So, to my mind there should be both a HDMI splitter, and LVDS splitter as well. My understanding is based that OEM slitter splits the LVDS signal from one to three outputs, because all the OEM screens can accept the LVDS signal. The centre armrest rear screen, and two backrest rear screens.
Although this is my assumption because I haven't seen the splitter and haven't seen any wiring diagrams of this individual equipment. Probably, I am not right.
Old 07-18-2019, 05:34 AM
vibbelito's Avatar
I found this thread on the Ti forum about splitting this lvds signal.
https://e2e.ti.com/support/interface/f/138/t/336955
Old 07-18-2019, 05:39 AM
vibbelito's Avatar
Thanks,
You are right, there should be an lvds splitter for those that want to have all 3 screens. Me personally would most likely remove the center screen and only have the 2 backrest monitors.
Anyway this is the OEM splitter and I think it only has 2 outputs.
Old 07-18-2019, 05:48 AM
Yes, seems like that. Although we cannot see the sockets really. Hiwever the diagrams/simbols in the stickers show rather clearly socket nukber, coding and coloring...
Then whether the stock solution is either having the 2 backrest monitors or one centre armrest rear monitor, without mixing with each other, so that there are no 3 screens - just one centre, or two on each of the backrests.
Otherwise, there is another solution how BMW spkits the signals
Old 07-18-2019, 06:10 AM
vibbelito's Avatar
Well I suppose you could use 2 of these splitters to get 3 signals or just go the getho way and do a Y or T split of the cable. Only thing is that you will lose some signal strength and about 33% reflection and the impedance will also get lower
Anyway Irish745 should have one of these splitters in his individual 760.
Old 07-18-2019, 06:20 AM
I just looked innto RTK and saw thet the OEM splitter is only 1 in quantity.
Old 07-18-2019, 07:38 AM
The rear original mmigt is split into 2 signals that feed the rear headrest monitors which are actually 6.5" screens the same as whats on the rear fond screen .and the original rear foldup screen is removed by individual when new thwyre are no cars with 3 screens .even on my vin and other vins its documented about the rear screen been removed the real problem with the backrest monitors is u can only have 2 people in the car cause the idrive to control them is in the armrest and needs to be folded down .thats y id like to fit 2 android touch screens there running the bmw ui off the original lvds signal
Old 07-18-2019, 07:50 AM
Thanks. Clear
Old 07-18-2019, 08:24 AM
vibbelito's Avatar
I wonder why the 7 didn't get the same treatment as the RR1 in regards to the individual rear entertainment. In the RR the MMIF have 2 LVDS outputs instead of using a splitter like the E65. This means that in the RR you can actually control the two 6.5" screens individually from one another
Old 07-18-2019, 08:47 AM
Probably because it is RR, and there is not an option with only one screen in the middle only.
Old Yesterday, 03:56 AM
vibbelito's Avatar
I've just completed the first experimental update file for the MMI. Where I have done something as simple as changed the text where is says AUX to display BT instead.
I have a bluetooth adapter in my car connected to the aux port so I thought this would make for a good first experiment if it's even possible at all to modify the MMI software by ourselves.
I will try to flash it to my experimental MMI on Sunday evening when I get back from my hiking trip. Right now I just hope that I won't brick it hehe.
I have done many steps of conversion over several months to get her so there's a good chance that I have screwed something up on the way.
.0pa (intelHex) ---> .bin ---> stripped unnecessary bits ---> Zlib unzipped ---> changed AUX to BT ---> Zlib zipped ---> .0pa
If this method works I'm going to do some modifications and a translation to other language to start with before I try to add AV input
