Cost and difficulty to refresh front suspension with adaptive drive? - Bimmerfest - BMW Forums
Old 05-28-2020, 04:36 PM
BabyUnicornTaco BabyUnicornTaco is online now
Mein Auto: 2008 X5 4.8i E70 Sport
2008 4.8i with adaptive drive. I don’t have any current issues now but down the road I know my front suspension will need some refreshing. I’m having trouble finding a refresh kit for my vehicle that has adaptive drive with the EDC shock absorbers. Anyone know the options and difficulty? Is it easier to refresh an E70 with adaptive drive EDC shock absorbers as opposed to those without? Good idea to refresh around the existing shock absorbers? Looking for some ideas and experience to prepare for the next year or two. Links to the appropriate refresh kit? Info appreciated.
Sent from my iPhone using Bimmerfest mobile app
2008 X5 E70 4.8i M-Sport
2008 550i RPI Exhaust, RPI Ram Air
Old 05-28-2020, 05:38 PM
ard ard is offline
Resident Curmudgeon
No experience w the E70, but with an E39...
So if $$$ is 'easier', then the non-EDC will be 'easier'... . Basically its some added connectors beyond the normal mechanical install.
It is good to start thinking of this...perhaps even developing your own parts list. While I love FCP euro, for example, I'd rather build my own parts kit. I never found anyone with a truly complete kit.
Basically pull up a parts diagram and start listing BMW part numbers. Then drill down on each, see who the OEM is, etc etc, Decide if you want OE or OEM or aftermarket. Heck, figure out if you'll have a choice!
There are the usual parts- struts, springs, spring perch, bumps top, all the bits and bobs in the strut/spring assembly. Then the arms- upper and lower, wheel bearing, tie rod ends, steering arm idler.
Wanna get crazy? Add in motor mounts, transmission mounts.
Moving rear wards? Driveline, Guibo, center bearing...rear diff bushes..sub frame bushes.... now you are at the rear suspension.
Finally, given the cost of the EDC, I might try to find a shop that can bench test them for you on a shock Dyno. Definitely out of the usual, but given the cost, it'd be wroth spending $few hundred to see if they are fine. I'd think very long and hard about spending 2500 to replace them, TBH.
Start a list. I'll need it in a few years.
OEM is not what BMW sells
Old 05-28-2020, 06:35 PM
ard, I figured you would respond first. I know the list goes on and on. It’s hard holding onto an E70 with the adaptive drive and never wanting to give it up. It drives so much better than the new X5s. I wonder what chances I take with refreshing around the EDC shock absorbers without testing them. I think of difficulty as DIY possibility. If I build around the EDC shocks absorbers does it make it easier? Looks like the difficulty is in coil compression and loosening old bolts when doing a full refresh. My SC X5 has zero rust. Underside parts look nice. I debate having an Indy do it or myself. It would obviously take days to complete by myself. I’d rather prepare now than wait for the “clunk.”
Old 05-28-2020, 09:00 PM
ard ard is offline
Resident Curmudgeon
Id be inclined to do everything except the EDC damper. All new mounts, bumpers, etc inside the strut assembly. And then know that you may need to bite that bullet eventually.
Or maybe find some idiot that is tearing out his EDC so he can isntall a superior 'lowering kit w KYBs'... Start looking....
Its all an easy DIY. Just mechanical work, and under a car too.
Old 05-28-2020, 09:56 PM
deroy deroy is offline
Mein Auto: X5 e70 4.8
Steering arm idler? On a e70?
Is the spring that holds rack and pinion together some modern day equivalent of that maybe?
Verzonden vanaf mijn iPhone met Tapatalk
Old 05-28-2020, 11:21 PM
OP, you’ll really want an impact wrench for that kind of work. Saves you a lot of time, and especially the fiddling with ring wrenches and allen keys on the ball joints. A big enough ball joint separator is a joy too. I had to “adjust” mine to make it fit and not slide off; wider jaws and filing a different angle on the tip. See pic.
Just did my LCAs, so all fresh experience here.
Old 05-29-2020, 07:05 PM
Thanks for the replies. I went out for an extreme test of the suspension today to look for weak points. I found that a quick left to right steering wheel movement back and forth at low speed can produce a “clink” sound and a more extreme bump can make a squish sound. These sounds are produced under not so normal road conditions but I think it could effect high speed braking or emergency maneuvers. My first thought is inner and outer tie rods for the “clink” and maybe #7 for the squish. Thoughts? https://www.realoem.com/bmw/enUS/sho...diagId=31_0795
Old 05-29-2020, 10:25 PM
7 is just a bump stop, but it’s possible. My 8/9/10 combo squishes a bit, but all visible sections are still fine.
Old 05-30-2020, 04:16 AM
Doug Huffman's Avatar
Nuclear engineer
Not this of course ...
Originally Posted by Doug Huffman View Post
Old news? New to me.
CRACKING NOISES FROM THE FRONT AXLE AREA WHILE TURNING THE WHEELS, WHEN STATIONARY OR PARKING
https://static.nhtsa.gov/odi/tsbs/20...38386-9999.pdf
Similar issues are scattered all through the product line. I noted elsewhere the highest FRU allowance that I have yet seen, 42 FRU!
Old 05-30-2020, 06:16 AM
It’s also possible that some play between 8/9/10 is causing the squish and the clink. I still have #10 parts in my garage ready to be installed from above. I guess it’s possible there is some play at that top locking nut due to degraded #10 materials.
Old 05-30-2020, 06:19 AM
That’s interesting. I haven’t seen that before. Adds to the possibilities. Does that site list all service bulletins?
Old 06-01-2020, 01:26 PM
Old 06-02-2020, 09:51 AM
My #10 was toast on both sides. Click image for larger version
ID:	895099Click image for larger version
ID:	895101Click image for larger version
Old 06-02-2020, 12:46 PM
ard ard is offline
Resident Curmudgeon
Thats why I prefaced my statements with "E39"
As they say, YMMV.
Also, a lot of rubber suspension parts LOOK fine. They degrade internally as well as deform and sim-aliagn, in a way that CAN be hard to appreciate when assembled.
Old 06-02-2020, 06:31 PM
Next is sway bar end links simply because they have been sitting in my garage for months. Might eliminate the left/right play at slow speeds. Give some time for the mount/shock area rebuild. There is noticeable improvement in the stability of the ride after replacing these pads (mainly the slight feeling of buckling over speed humps has disappeared). It was a great time to get rid of those seldom seen leaves. Lol. Click image for larger version
ID:	895153Click image for larger version
Old 06-03-2020, 12:29 AM
I’m trying to understand you; deforming i get, but sim aligning? Is that some anisotropical internal wear at molecule level over time or so?
Old 06-05-2020, 03:10 PM
Replaced a sway bar end link up front to test out my new floor jack. Easy job. When the old one was installed it didn’t seem to have much play. When I took it off it goes from looking ok to this. Click image for larger version
ID:	895529Click image for larger version
Old 06-05-2020, 03:43 PM
ID:	895533 I’ll see if the new ones get rid of the front end side to side little “clink” when I finish up some other work.
Old 06-06-2020, 05:10 PM
Other sway bar end link since we were talking about hidden internals that you can’t see from eyeball inspection. Click image for larger version
ID:	895703Click image for larger version
Edit: this was the noisy side by the way. Notice what would normally be white lubricant inside is now dirty/gritty black.
Old 06-06-2020, 11:52 PM
Did they show play when on the vehicle? Or now in your hands?
Old 06-07-2020, 07:14 AM
A very little bit of clink and play when on the drivers side where I heard the clink while turning left and right. When off the X5, the drivers side link has a metal to metal ball joint clink just when moving by hand. Lots of grit/sand inside that I can hear when I move the ball joint around. The passenger side did not.
Old 06-10-2020, 07:54 PM
Old 06-15-2020, 10:16 AM
I was finally able to test out the new front sway bar end links today. Cornering is more precise and they have eliminated the “clink” I referenced earlier when turned wheel left to right at a slow speeds. Overall, the two cheap and easy parts I replaced has eliminated any current concerns. I’ll come back when it’s time to do a full job.
