08 e83 x3 3.0si 6spd "Rabbit Hole" & Killing Gremlins Journal. HELP Pls & TY :) - Page 5 - Bimmerfest - BMW Forums
Old 06-02-2020, 01:23 PM
oh_member_ oh_member_ is offline
Mein Auto:
Originally Posted by dukedkt442 View Post
Thatís because Jeepoís oil pan gasket is leaking so the thinner oil finds its way out. 5w-40 was way too thick for my engine, a sign of still having tight tolerances.
Lol. Maybe. But atleast mines not
Old 06-02-2020, 02:21 PM
dukedkt442's Avatar
dukedkt442 dukedkt442 is online now
Anti-Hack
Location: Hudson Valley/LI, NY; Treasure Coast, FL; OBX, NC.
Mein Auto: 2008 BMW X3
How much Marvel did you add to the oil? With as much yuck as I think youíre describing, youíll probably want to change again in 500-1000 miles. Itís safe for gasoline and works wonders on injectors. If your 5w30 is 502-505 approved itíll be fine for the bmw. Itíll likely be fine anyway for a few short mileage OCIs coupled with MMO to clean the sludge out of the engine. It canít keep proper time with oil restrictions. As it cleans the sludge youíll want to change oil frequently for a few thousand miles as the filter will be bypassed in short order.
Which ground strap did you look at, engine one or exhaust? And you say ordered... you didnít order the expensive one right??? Off the rack cables from the auto store will do you just fine. I promise.
If you have gunk and grime on the engine and transmission bellhousing, itís because of a leak. It doesnít get there by magic.
The "need to have my head examined " E21 build thread
2008 BMW E83 1981 BMW 320i
2016 Chevy Silverado 2011 VW Jetta
1984 GMC S-15 1986 Oldsmobile 442
Another half dozen '60s tractors
Old 06-02-2020, 02:47 PM
Mein Auto:
How much Marvel did you add to the oil? With as much yuck as I think you're describing, you'll probably want to change again in 500-1000 miles. It's safe for gasoline and works wonders on injectors. If your 5w30 is 502-505 approved it'll be fine for the bmw. It'll likely be fine anyway for a few short mileage OCIs coupled with MMO to clean the sludge out of the engine. It can't keep proper time with oil restrictions. As it cleans the sludge you'll want to change oil frequently for a few thousand miles as the filter will be bypassed in short order.
Which ground strap did you look at, engine one or exhaust? And you say ordered... you didn't order the expensive one right??? Off the rack cables from the auto store will do you just fine. I promise.
If you have gunk and grime on the engine and transmission bellhousing, it's because of a leak. It doesn't get there by magic.
6 oil 1magic stuff
Ill keep that in mind to change it pretty early.
I ordered just some generic **** from autozone but it looked to flimsy and junky. Im gunna go insulated like you were saying, itll just make me feel better. Engine.
I havent got to climb around the rear yet. Gunna have to back up on some ramps
Yes i know, i know, it got there somehow.
its more that I cannot track it bc I cannot follow a fresh trail. Its all just goupy, not exactly fresh goupy and caked on goupy.
Old 06-02-2020, 04:26 PM
dukedkt442's Avatar
Anti-Hack
Ah. Thatís a good safe ratio for MMO. Iíve gone as high as 20%.
Gotcha on the cable. Grab a cable from the battery section in whatever length you need. Actually grab two and add a second on top of the engine. When I get back to NY next week I can take a picture of how I ran mine.
I put a braided piece on the exhaust, itís about underneath the rear seat on the exhaust pipe (which is insulated from the chassis, just like the engine is insulated from the chassis without the ground cables). Canít have too many earth straps; your electrical issues will likely go away with proper grounds. The alternator canít properly charge the battery if the grounds are bad, either.
For cleaning, Brakeleen and a rag work fine. The best is pure gasoline and a toothbrush... use at your own risk. Grab the large bottles of CRC Pro Brakeleen. Engine degreaser used to work great until it got all eco friendly.
Old 06-04-2020, 08:14 AM
Mein Auto:
06/04/20 changed case fluid, 203447.
Was kinda dark, Amber-ish in colour. Was much darker in comparison to the new oil.
Havent drove yet, updates to to come.
Sent from my BBB100-3 using Tapatalk
Old 06-04-2020, 10:41 AM
Mein Auto:
Ok driven. Everything seems hunkidoorie. Have not noticed any significant difference BUT at least I know it has been done and with the proper fluid.
Old 06-04-2020, 10:46 AM
Mein Auto:
All the cables they had in the battery section were wicked long. Like 24-48 inches!
I found the rear earthing, it's in the same cruddy green condition as the front but neither are frayed/broken. Will still change those though.
Gasoline???
Old 06-04-2020, 12:50 PM
dukedkt442's Avatar
Anti-Hack
Yes gasoline, one of the best solvents out there. Iíve cleaned many a a sludged engine over the last 30 years. Gasoline isnít actually very flammable, despite the misconception.
Grab a 24Ē cable, cut it in two and crimp new eyes on the cut ends.
Old 06-04-2020, 06:14 PM
Mein Auto:
I'm not worried about the flamibility so much as the smell. Wouldn't it leave a greasy film?
Twas lazy, just ordered 2 separate cables
Old 06-05-2020, 04:09 AM
dukedkt442's Avatar
Anti-Hack
If youíd planned on painting the area, youíd need a final cleaning after gasoline, but to cut through built up gunk, a splash of gasoline in a can and a toothbrush is my go to. Brakleen or MAF cleaner work well but sometimes evaporate too quickly to dislodge thickened oil/grease/dirt deposits. All depends on what needs cleaning and where.
Old 06-05-2020, 06:50 AM
BMWaufKS BMWaufKS is offline
Mein Auto: 2008 X3
Look in Walmart's, etc. garden/lawn section. There are shorter ones readily available for lawn/garden tractors, often with lug-ends already installed on both ends:
https://www.walmart.com/search/?quer...20cable%20lawn
Since 1/2016, restoring a
2008 BMW X3 M-Sport, N52, automatic ("#1")
Modifications:
All stock except dashcam
Since 3/2017, also restoring a
2008 BMW X3 base-model, N52, automatic ("#2")
Modifications:
Dashcam, cargo cover, cargo mat
Parts for sale: https://www.bimmerfest.com/forums/sh....php?t=1382187
Old 06-05-2020, 07:52 AM
dukedkt442's Avatar
Anti-Hack
He wins the internet today with that suggestion!
Old 06-08-2020, 10:41 AM
Mein Auto:
Everything. Everything needs to be cleaned lol
Old 06-08-2020, 10:42 AM
Mein Auto:
Not a wal-Mart shopper but thanks I appreciate you find those though. I already have some on the way- hopefully they'll be here soon enough bc I'm getting radio static too
Old 06-11-2020, 01:24 PM
Mein Auto:
Ok. Another thing on the list, valve cover gaskets. Both bimmers actually
Gonna be a fun summer lol
Old 06-11-2020, 06:28 PM
dukedkt442's Avatar
Anti-Hack
Just wait until you decide to do the leaking oil pan gasket.
Old 06-13-2020, 05:45 AM
Mein Auto:
I can't even describe the mean disgruntled face I'm making at you.
Old 06-13-2020, 07:23 AM
bmdubya1198 bmdubya1198 is online now
Mein Auto: '99 528iTA Sport
My E90 also has a small oil leak from the pan... you think I'm gonna fix that?
Alex
1999 528iT Sport M52TUB28- 2-2-1999 240k+ miles
--AlpinweiŖ III/Sandbeige
2004 X3 2.5i- M54B30 swapped
--Titansilber/Hellgrau
2006 330i N52B30
--AlpinweiŖ III
2000 Volvo V70R Manual swapped, daily driver
1991 Volvo 944 Turbo
1992 Volvo 245
Old 06-13-2020, 12:04 PM
Mein Auto:
Just keep adding oil, this is fine
Old 06-28-2020, 11:54 AM
Mein Auto:
02/28/20
204444 miles
Engine and rear earthing cables replaced.
Old 06-28-2020, 11:56 AM
Mein Auto:
Transmission codes:
lt-3
Old Yesterday, 04:41 AM
dukedkt442's Avatar
Anti-Hack
Apologies for not getting these to you sooner.
Sent from space
Old Yesterday, 01:11 PM
Mein Auto: 2008 X3
I went on the left side instead, to a cooler point on the power steering reservoir's mount. To do like the above's run from the jump-start ground connection on the right side, though.
Modifications:
Modifications:
Old Yesterday, 01:28 PM
dukedkt442's Avatar
Anti-Hack
^ Also a great location.
Thereís probably a half dozen more ways to do it.
