Car Battery Replaced, Now Strange Noise Inside - Bimmerfest - BMW Forums
Old 04-16-2019, 01:26 PM
ZoominZ396 ZoominZ396 is offline
Mein Auto: 96 Z3 Roadster
I had not moved my Z3 for about 3 months and I tried turning the vehicle on, and of course, battery was dead. I did notice the terminals were corroded so I removed them, cleaned and sprayed a protective coat on them. I then used my car battery charger to turn it on. Once hooked on, I went inside the cabin and started hearing a long noise "beeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee eeeeeeeeeeeeeeeeeeeeeeeeeep". I positioned my key and turned it on the "ON" position and the noise went away but it did not turn on.
This is my first time with this issue and wanted to see if this just means I need a new battery or something else. I will be purchasing one soon, but I would appreciate any input. Thanks
Old 04-16-2019, 03:12 PM
southcoastguy southcoastguy is online now
Mein Auto: 328xi
Sounds like an alarm noise?
Old 04-16-2019, 04:21 PM
southcoastguy
Im not sure if its an alarm noise. As I mentioned, its my first time dealing with this. Do you know if an alarm is set off when the battery gets disconnected? Because that noise goes away as soon as I turn the ignition(but engine does not turn on). Do you know if there's a need to reset the vehicle with a code because of this? Thanks for your response.
Old 04-16-2019, 05:51 PM
vintage42's Avatar
BMW CCA 1405
Originally Posted by ZoominZ396 View Post
... had not moved my Z3 for about 3 months... battery was dead... used my car battery charger to turn it on. Once hooked on, I went inside the cabin and started hearing a long noise... I positioned my key and turned it on the "ON" position and the noise went away but it did not turn on...
It is not clear what you did.
You used the battery charger to start the car, and heard a beeping, but the car did not start?
I would wait until the battery was fully charged, and then try starting the car.
Old 04-17-2019, 09:17 AM
Yes, that is correct.
Used the battery charger to charge the vehicle, went inside the cabin and heard that noise. I will take it in to have it fully charged, and if needed, will purchase a new battery.
Old 04-17-2019, 12:46 PM
NZ00Z3 NZ00Z3 is online now
Mein Auto: 2000 Z3 3.0i
Disconnect one terminal of the battery and charge it isolated from the car
Old 04-17-2019, 12:50 PM
vintage42's Avatar
BMW CCA 1405
OK, I thought you expected to jump start with the charger, because Post #1 you said "I then used my car battery charger to turn it on."
But then in Post #5 you said "Used the battery charger to charge the vehicle".
So did you wait for the charger to bring the battery up to strength, and did the engine start OK?
bob's shoe
Similar Threads
**Z3** DIY Guides (post links here) JonM E36/7 Z3 (1996-2002) 92 12-06-2017 12:40 PM
Battery recharge sign....after new battery OnlySkills 7 Series - E65 / E66 (2002 - 2008) 57 10-15-2014 04:36 PM
Battery Replacement iewing E60 / E61 (2004 - 2010) 24 10-19-2010 09:49 PM
bad battery shami E60 / E61 (2004 - 2010) 3 07-12-2010 11:40 AM
523 Strange Noise When Braking sloveridge E39 (1997 - 2003) 3 06-17-2008 05:30 AM
