exterior door handle trim - Bimmerfest - BMW Forums
Old 09-28-2017, 08:30 AM
jbwbhs jbwbhs is offline
Mein Auto: '97 540I 6 '98 Roadster
Anyone with experience replacing trim on the door handles? New trim piece will not engage the top clips, either the gasket is too thick or perhaps the clips at top are a bit larger than holes??
Old 09-28-2017, 09:49 AM
Carlín96/M44 Carlín96/M44 is offline
Mein Auto: z3 bmw 1.9
Old 09-28-2017, 09:57 AM
I have replaced both door handles plastic trims on my '96' with the help of YouTube due to is a difference how to remove handles depending on the year/model of the car. Either you pull or push the tab to the plastic trim retainer.
Old 09-28-2017, 11:48 AM
z3jeff z3jeff is offline
Mein Auto: 2001 Z3
I found an Indie shop that replaced both door handle trims for $50. He had a tool that looked like an ice pick with a curved tip. It took him about 30 seconds each. I lucked out when I bought them. I never get parts at the dealer because of price but I went to the dealer to get the parts number to order online. He said he had a pair he had ordered for someone and they never picked them up and he was going to return then to the distribution center. He gave them both to me for $25.
Old 09-28-2017, 12:08 PM
Nice all the way around, and yes I did use something similar to remove the old ones a metal scriber with a 90° on one end.
Old 09-28-2017, 12:26 PM
vintage42's Avatar
vintage42 vintage42 is offline
BMW CCA 1405
Mein Auto: 1997 BMW Z3 1.9 5MT
Some DIY threads:
http://www.bimmerforums.com/forum/sh...0#post29030880
http://www.bimmerforums.com/forum/sh...im-Replacement
This shows the sliding latch:
When I did mine, looking through the hole in the end or the door, I could see the latch, but not feel it well with the hook tool, was unable to hook onto it, and was unable to release the latch. I waited until I went into the door for other problems, which exposed the latch, and I poked the latch back and forth with a screwdriver. It had resistance.
My new gaskets from eBay were not OEM and did not fit and hold very well. I had to press them hard, squeeze them with the sliding latches, and let the handles hold them down.
Old 09-28-2017, 02:39 PM
Ok, think I've got it. Hope I don't have to pull the door card, just put it back. Many thanks.
Old 09-29-2017, 03:27 AM
Bob's Shoe Bob's Shoe is offline
registered user
Mein Auto: 1996 Z3 E36(7) M44
In the paint section of hardware stores they have a tool that has a bottle opener on one side a flat hook the other. It is about six or seven inches long. They use it to pry open paint cans.
It worked pretty well when I changed mine
Old 09-29-2017, 05:58 AM
As usual, mining the good info on this forum provided the cure for the problem. On my '98 M roadster the hole in the door allowed me to see the slide and it required moderate pressure to push and open the slots for the trim piece.
Old 09-29-2017, 01:43 PM
danomite danomite is offline
Danomite
Mein Auto: SC'd Z3 3.0 Coupe
^^^This!
It's a paint can opener, and they're usually free!!!
It should take no longer than 60 seconds to change each side.
You don't win silver...you lose gold.
Old 09-29-2017, 05:28 PM
vintage42's Avatar
BMW CCA 1405
Originally Posted by danomite View Post
... It's a paint can opener...
I did try that first. I was too clumsy to make it work. The sliding latch did not budge for me. I had to use direct pushing with a screwdriver blade after the card was removed for other repairs.
Old 09-29-2017, 07:08 PM
registered user
^^^This!
Lol they are !
Old 05-14-2019, 02:04 PM
ZEEBOY ZEEBOY is online now
The Arkleyologist
Mein Auto: 1997 Z3 Roadster 2.8
I replaced my rubber/plastic door handle gasket today. I had no problem taking off the "door jam" plug...I had no problem pushing in on the gasket retention slide bar through the door jam hole...and I had no problem removing the exterior door handle gasket and cover piece. I initially was having a problem pulling the slide retention bar back inside the door to secure the exterior cover piece and new gasket.
This is what I did to help me understand what I was doing wrong.
1. I removed the new gasket and cover piece
2. I took a small inspection flashlight and looked inside the door
3. I was able to clearly see the retention slide mechanism inside the door and learned how to freely push and pull it back and forth
4. While I pushed and pulled the retention slide back and forth I was able to see exactly how the interior slide mechanism worked on the TOP 2 retention holes by watching the action from the exterior door handle on the outside of the door.
5. I learned that I had NOT pushed the interior retention slide ALL the way back enough to allow the new exterior piece and gasket to be in position to be captured by the slide.
The main point I am making is:
1. Push the slide retention bar inside the door ALL the way back
2. When installing the new cover/gasket put the BOTTOM two cover piece location pins in FIRST and the put all the pressure on the TOP 2 locator pins while you are PULLING the slide retention bar BACK inside the door.
ID:	851811   Click image for larger version
ID:	851813   Click image for larger version
ID:	851815   Click image for larger version
Old 05-14-2019, 06:44 PM
lrome12 lrome12 is offline
Mein Auto:
Old 05-15-2019, 01:38 PM
The Arkleyologist
Irome..I have $13 total invested...if I need to do it again it will be a ten minute job for me...
Old 05-16-2019, 04:27 AM
RogerEH RogerEH is offline
Mein Auto: 1999 Z3
I have a set of ebay gaskets arriving in today's mail along with a new antenna gasket. Looks to be a fairly simple replacement for both. The antenna gasket will require a little more work but mine is rotted and most has fallen off. I'm hoping that may be the source of the water getting into my truck during a heavy rain. Yesterday I replaced the two fender badges. I'm slowly emptying my bank account into m week-ago purchase of a 1999 Z3.
Old 05-16-2019, 08:39 AM
The Arkleyologist
Totally agree rogereh..that antenna grommet is a bear..just more time comsumming and a few more cuss words...I have noted before that those antenna grommets go bad because the supplier got them too hot during the molding process and they were somewhat brittle even when new..if they had a softer durometer they would last forever...they must still get them from the same supplier because the "new one" I installed a year ago was very hard...
Old 05-19-2019, 04:38 AM
Mein Auto: 1999 Z3
I managed to replace my antenna grommet but apparently the cheapo ebay ones are taller the the OEM BMW ones so I had a difficult tome getting the antenna base high enough into the grommet to thread the antenna back into it. When it finally got into it enough the bolt hole in the antenna bracket was too high so I couldn't put the bolt back in I managed to get it in but now the grommet is squeezed down almost back through the hole in the fender, It would have been an easy replacement except for that and the problem of the power top unit has to be removed to do it because it is right in front of the antenna base.
The door handle gaskets were a breeze to replace. The sliding lock mechanism on mine moved freely and I used the paint can lid remover tool to pull it back into the locked position. Hardest thing for me was removing the two plastic hole plugs in the door because they are 20 years old and have hardened. I don't know if there's replacement for those but I did mange to get them out and then they went right back in. Easiest upgrade that I've did so far.
Next project will be replacing my dead radio.
Rogereh
1999 BMW Z3
