Trouble codes after sitting through the winter - Bimmerfest - BMW Forums
Old 04-05-2019, 02:25 PM
TMair TMair is offline
Mein Auto: BMW Z3
Hello All
Ok I have a 96 BMW Z3, it ran great when I put it up for the winter, full tank of fuel, I did take the battery out for the winter and actually had to put a new battery in it.
I did put some HEAT in the tank, along with sea foam full disclosure.
It runs great when it is cold but when it warms up it misfires, and of course that makes it run poorly.
I am getting codes po300, po325, po330, po303, and po304.
I have looked these codes up on line, but am wondering what would/could cause all of them after sitting over the winter?
Any help would be greatly appreciated!!
Thanks in advance,
Terry
Old 04-05-2019, 03:14 PM
zed3coupe zed3coupe is offline
Mein Auto: 1999 BMW M Coupe
Misfire codes. That stuff in the fuel maybe effecting how it is running. Put fresh fuel in the car and see if it runs better.
1999 M Coupe.
Old 04-05-2019, 06:14 PM
Mein Auto: BMW Z3
Thanks for the reply, the reason I put that stuff in the tank is because it was running bad to begin with I've ran sea foam in it before to get the fuel gauge to work, and gas dryer I wouldn't think would make it worse.
Thanks again.
Old 04-07-2019, 01:50 PM
Mein Auto: BMW Z3
So for anyone who might care the problem was the spark plug holes were full of water, can't imagine that much condensation but that is the only thing I can think of
Old 04-09-2019, 11:36 AM
kingfisher1 kingfisher1 is offline
Mein Auto: 528i
Mine had similiar issues misfires,etc..just put new fuel in there and cleared the codes.Code reader will save you money!
Also tending
2003 Dodge Cummins
1999 Jeep XJ Country
2014 F-150XLT off road
Old 04-10-2019, 10:56 AM
Was car in garage or outside? Had a similar situation with my old E36 when it would heavy pour, water would run down into cylinder 6 spark plug hole.
If it was sitting in a garage, I don't understand how water would make its way down a spark plug hole.
1999 M Coupe.
Old 04-10-2019, 11:51 AM
Mein Auto: BMW Z3
It was actually in one of those frames with the fitted tarp cover on it, I took the battery out, then zipped the door closed on the garage and left it for the winter, which wasn't all that long, but we did get a fair amount of snow.
Your guess is as good as mine as to how that much water got in there, and it was in all 4 spark plug holes to one degree or another, so I guess lesson learned.
There was also those little white spots on everything that is aluminium under the hood like everything had gotten drops of water on it.
When I put my side by side in the tarp garage the ground was dry, just can't imagine.
Thanks for the reply.
Terry
Old 04-10-2019, 11:55 AM
Mein Auto: BMW Z3
Yes I have a code reader, that's how I got the codes mentioned in the original post.
I was actually hoping as happens so many times on here someone would tell me how they had the exact same issue and here is the easy fix!! So now I guess in the future I can be that guy!
I just would have never guessed that much water could accumulate over a short winter in a covered enclosure!!
Terry
Old 04-10-2019, 01:50 PM
Yeah that seems weird. Water in spark plug holes will def drive you crazy, been there before!
1999 M Coupe.
Old 04-16-2019, 08:13 PM
Mein Auto: BMW Z3
Yeah I would really like to know how it got there, I would think if it leaked in there that it would have only gotten one or two plugs not all 4 of them.
Terry
Similar Threads
Winter Tires DeepSeaBlueX5 F85 X5 M and F86 X6 M (2016 - Current) 5 03-04-2019 03:57 AM
Nokian NRW tire gets grip on winter ChrisTO General Automotive Forum 11 01-13-2005 06:26 PM
Winter Tires Season 2004/2005 [email protected] BMW News 0 10-05-2004 07:08 AM
Winter Tires Season 2004/2005 [email protected] Tires, Wheels, Brakes & Suspension 0 10-05-2004 07:08 AM
