I have a question about Wheel Spacers? - Bimmerfest - BMW Forums
Old 04-23-2019, 03:31 PM
rabbita1 rabbita1 is offline
Bob Ramsey
Mein Auto: 1997 BMW Z3-01 BMW 330Ci
Will it damage or cause problems for my 97 Z3 Roadster if I install these on my car?
4 Pc BMW 10mm & 15mm Hub Centric Wheel Spacers Plus 20 Conical Lug Bolts Chrome.
I wander if there would be a problem with the wheel bearings or camber in the back?
Old 04-23-2019, 05:37 PM
ZEEBOY ZEEBOY is offline
The Arkleyologist
Mein Auto: 1997 Z3 Roadster 2.8
If I recall..the standard Z3 wheel is @ +45mm offset. That means the wheel is 45mm pushed in toward the car as compared to zero offset if it was centered at the wheel bearing. What that means is that with the spacers you are pushing the wheel @ 3/8" and 5/8" toward the lip on the fender well...measure your current distance with your factory wheel/tire setup and see if you have that much space available before you hit the lip of the fender..
Old 04-23-2019, 05:52 PM
Bob Ramsey
Thank you I'll do that, from eyeball it seamed to be OK but I'll take that precaution, I still wander if there would be a problem with the wheel bearings or camber in the back?
Old 04-23-2019, 06:00 PM
The Arkleyologist
Wheel bearings should be ok..I have no idea about the camber..
Old 04-23-2019, 06:07 PM
Bob Ramsey
1997 1.9 z3, 1997 z3 roadster suspension, 97 z3, z3
Similar Threads
eas | Now available at eas - APEX ARC-8 Wheel Set eas Site Sponsors & Bimmerfest Group Buys 35 12-17-2014 10:22 AM
Condensed VO/FA list john mclane BMW Coding and Programming 10 02-25-2014 08:53 PM
Bought 540i on tuesday, joined bimmerfest today. houseOFounces E39 (1997 - 2003) 55 09-13-2013 02:17 PM
best exhuast for 1994 IS ? russian318is E36 (1991 - 1999) 50 06-13-2009 02:40 PM
Angel Eyes Aztyeu07 E36 (1991 - 1999) 8 02-07-2009 03:03 PM
