Heater control panel-Micro Switch - Bimmerfest - BMW Forums
Old 04-28-2019, 01:21 PM
comsult comsult is offline
Mein Auto: 2001 Z3
I'm in the process of repairing my heater controls. Broken tab on the temp control. Anyway, while I had to completely remove the control panel, I see that there is a micro switch on the centre wheel. The temp control wheel. What does this micro switch control?
Thanks for any feedback.
Greg.
Old 04-29-2019, 04:23 AM
vintage42's Avatar
vintage42 vintage42 is offline
BMW CCA 1405
Mein Auto: 1997 BMW Z3 1.9 5MT
Is it an actual electrical switch, or is it a holder for a spring loaded detent pin that is mentioned here:
https://www.bimmerfest.com/forums/sh...9&postcount=56
Old 04-29-2019, 06:32 AM
fignewton fignewton is offline
Mein Auto: 98 Z3 2.8 5sp roadster
From what I have learned posting on another forum, it controls the electrical water control valve that opens to let water into the heater core. I was told that it opens just after you move the center control off of the fully cold (all the way counter-clockwise) setting.
Old 04-29-2019, 01:32 PM
NZ00Z3 NZ00Z3 is online now
Mein Auto: 2000 Z3 3.0i
@fignewton is correct with his description.
Old 04-29-2019, 07:36 PM
Mein Auto: 2001 Z3
Thanks for reply, the switch was difficult to get into place, almost broke one of the guides.
Working through the radio hole, with two big hands is difficult, have the scratches to prove it.
So I just wanted to be clear, that if the guide did break, did I need to glue it into place, or just discard it.
After the reply, I gently, straightened out the guide pin, and thank heavens it did not break, then gently guided the micro switch into place.
I've taken it out for a run, and I do get hot air, and can now control the temp.
I replaced the broken tab on the dial with an RC control arm ball, Silicone grease in all channels and everything moves smoothly now.
Thanks to this forum.
Greg.
info on replacing the Plastic Tab.
Similar Threads
Complete BMW OBD II codes doru E39 (1997 - 2003) 5 10-19-2017 03:44 PM
can an 02 sensor code be tripped by something else? Larrick E34 (1989 - 1995) 23 01-01-2011 09:36 AM
Carsoft - BMW Diagnostic Software | what will it do? & how to do it? drakar E39 (1997 - 2003) 91 11-08-2009 07:17 AM
stealer voodoo - i can't believe it badabingjr E39 (1997 - 2003) 33 04-01-2009 08:43 AM
