signs of F30 N20/N26 timing chain issue, and OCI to the rescue? - Page 8 - Bimmerfest - BMW Forums
Old 06-27-2018, 10:21 PM
namelessman namelessman is online now
Mein Auto: bimmer
Originally Posted by Michael Schott View Post
Are the timing chain issues isolated to colder climates? 0 weight vs 5 weight only matters if the temps are low. If you're in Vegas or Miami it doesn't matter.
If someone has spec sheets of BMW Twinpower 0w30 versus 5w30 please post them, my google search has not returned any.
bobisoilguy has lots of threads of 0w30 versus 5w30. The common themes of these threads are "pumpability" at low temp, and "thick enough" at high temp. Note that w30 means the same [email protected], so 0w versus 5w still have lots of "room" below 100C, all the way to -40C(e.g.)
E.g. some non-BMW oil spec(e.g. M1) says 0w30 being thicker than [email protected]
So the secrets may be hidden in the specs of BMW's 0w30 versus 5w30.
Old 07-23-2018, 10:25 AM
DBU's Avatar
DBU DBU is offline
Mein Auto: Glacier Silver X4 M40i
Timing Chain Tensioner - Replacement
BMW has used at least three different Timing Chain tensioners over the years for their N20 motor. My wife's X4 (F26) was produced 8/2014 so it didn't have the latest iteration of the TC tensioner. The car only has 16K miles on it and has not displayed any of the telltale signs of the TC going bad. Nonetheless. I decided to change the tensioner to the latest version (released 8/15/2016) and I wrote a little DIY (attached). In the words of BMWtechnician "it couldn't hurt."
If nothing else, the attachment has a decent description of the difference between the two latest versions of the TC tensioner.
File Type: pdf N20 Timing Chain Tensioner changed.pdf (504.4 KB, 150 views)
His: 2017 X4 M40i - Glacier Silver with all the options (except cold weather stuff) - not needed in SoCal
Hers: 2015 X4 28i - Glacier Silver - loaded M-Sport
Old 08-19-2018, 11:49 PM
Mein Auto: bimmer
My local dealers are group F, and the foremen said they saw 20+ N20/N26 in the shop for TC so far, mainly X3 and xDrive.
These service bays typically take in 140-150 cars per weekday, and can exceed those numbers on Sat.
How many N20/N26 TC issues your local service departments saw? E.g. SoCal dealers should have even bigger service volume than NorCal ones.
Old 12-11-2018, 12:42 AM
Mein Auto: bimmer
Is anyone aware of any update of these N20/N26 timing chain lawsuits?
https://www.carcomplaints.com/news/2...g-chains.shtml
https://www.kgglaw.com/class-action/...-filed-by-kgg/
Old 03-20-2019, 12:59 AM
Mein Auto: bimmer
bmwtechician.com has several excellent threads on this issue. E.g. some recent posts already ask if borescope can be used to inspect the guard rail weak points(i.e. the clip-on parts), Andreas's answer is that it is not possible, or at least there is no official SIB for this type of inspection.
The only suggested way to visually inspect the clip-on weak points is to remove the valve cover($$$$$)
Old 03-20-2019, 10:44 AM
Mein Auto: bimmer
A friend with a X3 forwarded a few references to me.
The first one is a comment from another N20/N26 TC thread:
https://bmwtechnician.com/2016/08/07.../#comment-5930
"On the otherhand, coming from polymer industry, Ive seen alot challenge that the old rail were white once and turn orange over time, plastics do turn yellowish overtime due to degredation, it is a result of polymer chains breaking down which is what we will see in aged plastics, yellowing headlights or in our case the timing chain rail. However, it will not turn orange even it is summerged in oil. I do believe BMW revised part to uncolored for a reason. Adding pigments into any plastics reduce the melt flow of the material which results in decreasing the mechanical properties of the materials. The revised uncolored rail suppose to last better. Adding pigments into plastics causes the pigment to break down polymer chains during the injection molding of the part or extrusion which is a 2 step process(color compounding), when I say 2 steps it means 2 heat history applied to the material to further degredates the materials.
P/S: The "white color" of the rail is the virgin color of material, I haven't touch them in person but I strongly believe it is made of unfilled Polyamide."
Another reference is to a X3 thread about N20/N26 TC issue. And post#25 is the first time a poster confirmed a CEL and a camshaft timing fault code, 130E20 "Intake Camshaft offset angle to crankcase outside tolerance", for this TC issue.
https://x3.xbimmers.com/forums/showt...1482736&page=2
Old 05-17-2019, 05:51 PM
Mein Auto: bimmer
https://f30.bimmerpost.com/forums/sh....php?t=1614899
Another thread of a N20 TC failure.
BMWNA really should consider extending the N20/N26 TC ELW to 15 years/150000 miles, especially since BMWNA is not issuing a recall on this.
Old 07-11-2019, 11:27 AM
TopQuark TopQuark is offline
Mein Auto: BMW 528i
I thought this was refuted already because, if you look that the video BMW provided on the initial batch of N20's, the color of the guide rail is already white. Skip to around 1:05 mark:
Old 07-12-2019, 10:10 AM
Mein Auto: bimmer
My guess is that the comment from bmwtechnician implies the color oigment is even further reduced with latest batch, e.g. white color itself can be from pigment.
Old 01-16-2020, 11:28 AM
backpackerx backpackerx is offline
Mein Auto: 2013 328ix
Add me to the list. Mine just went out at 68,500 miles. It was 5 days out of the 7 year warranty but BMW NA agreed to cover thankfully. Car pre-owned from 26k miles and was low mileage and well taken care of prior. ASS coded off from beginning and I drove it pretty easy with oil changes 8k-10k intervals.
Old 01-16-2020, 11:41 AM
Mein Auto: bimmer
Thanks for feedback! N20/26 with xDrive is high load application, and this data point shows 8k OCI and ASS off do not help with that.
Well BMWNA will present its resolution in the the first settlement conference in 2.5 weeks, so hopefully BMWNA will man up and do the right thing for N20/N26 owners.
Old 01-17-2020, 02:52 AM
Michael Schott Michael Schott is online now
Super Moderator
Mein Auto: 2017 VW GTI Sport MT
How are you defining a high load application?
Old 01-17-2020, 05:31 AM
imtjm imtjm is offline
Mein Auto: 328ix sdn; M240ix cpe
why? 15/yr/150k argument has no basis to it. Yes, the claimants are asking for 15yr/150k, but those are numbers based on no scientific basis like failure rate, service life, etc. Why not just argue the vehicle should have bumper to bumper unlimited mile warranty in perpetuity.
Old 01-17-2020, 08:56 AM
gkr778's Avatar
gkr778 gkr778 is offline
Novice driver
Mein Auto: 2014 320i ZSP ZMT
15 years/150k miles is the PZEV/TZEV warranty interval (for cars registered in U.S. states that adhere to CARB regulations for this warranty coverage).
I think what namelessman is conveying is that timing chain guide failure can trigger a CEL, and also affect the operation of the camshaft position sensor. In such cases, the PZEV/TZEV warranty applies.
What the world needs is a few more rednecks - Charlie Daniels
Tell you about rednecks. Theyíre probably the only people in the whole country that ainít unfit. - Fred Reed
God and guns keep us strong. That's what this country was founded on. - Lynyrd Skynyrd
Old 01-17-2020, 11:50 AM
Mein Auto: bimmer
Originally Posted by gkr778 View Post
5 year/150k miles is the PZEV/TZEV warranty interval (for cars registered in U.S. states that adhere to CARB regulations for this warranty coverage).
That is correct, BMWNA offers 15 years/150000 miles PZEV emission warranty on N20/N26, and model year 2016 N6 does have TC included.
Since BMWNA is already confident that MY2016 N26 TC can last 15 years/150000 miles, why not apply to all PZEV N26 instead of just MY2016?
Old 01-17-2020, 11:54 AM
Mein Auto: bimmer
Application that can lead to high(er) rpm, e.g. tolling, xDrive(loads from all wheels), sustained autobahn speed, uphill, sustained spirited driving, heavier weight(e.g. x3)
Old 01-17-2020, 11:56 AM
Mein Auto: bimmer
The claimants supposedly ask for 10 years/150000 miles, but since BMWNA already provides 15 years/150000 miles TC coverage for MY16 N26, that warranty should be extended to all N26.
Old 01-17-2020, 12:38 PM
John MS John MS is offline
Mein Auto: 2014 Glacier Silver 328i
How does an N20/26 with xDrive result in a high load application? Presumably much higher than an N20/26 with rwd. That high load is not reflected in published mpg numbers.
Old 01-17-2020, 01:12 PM
Mein Auto: bimmer
Local foreman specifically mentioned xDrive and X3 as high load(and most N20/N26 in the shop for TC issues have been those variants)
My thinking is that xDrive + transfer case can induce more variations of rpm, and TC can be subject to more accelerate/decelerate than just RWD without transfer case.
Old 01-17-2020, 02:41 PM
Super Moderator
My question should have said why is the car you cited a high load application. Itís just an xDrive.
Old 01-17-2020, 03:58 PM
How can the transfer case induce more rpms? I've driven loaner 320i and 328i xdrives and have not noticed anything like that. If those engines were working harder the published mpg would be much lower. It isn't.
Old 01-17-2020, 07:11 PM
Mein Auto: bimmer
The 328i XDrive transfer case and extra/beefed up components should be 150-200lbs extra when compared to 328i RWD, so extra weight can be a factor.
The published (EPA?) mpg's are similar between RWD and xDrive, probably as those are city/highway constant speed.
At the same time, accelerate/decelerate of TC is related to how fast to ramp up/down to specific rpm. E.g. in spite of extra 200lb, the 328i iDrive 0-60 is 0.2(?) second faster than RWD.
In a way, the engine can rev up to, say, 5000rpm, easier/faster in xDrive than in RWD. That can attribute to TC stress/load too.
Now the best is BMW engineers can disclose their technical analysis of the issue, maybe those can be disclosed in the settlement conference(?) .....
Old 01-17-2020, 08:04 PM
Super Moderator
There is zero chance BMW will disclose what you ask. Zero. It's not required of them. That's different than seeing a certain % of failures that indicate a design flaw resulting in some sort of settlement.
Old 01-17-2020, 08:08 PM
Super Moderator
All of this may be true what load is determined by how hard the car is driven. A heavier car could be driven lightly by some owners and a light car more aggressively by another. There are too many variables to say that weight is a major factor. All else being equal you may be right but until we see statistics showing that xDrive F30 cars vs say a 528i xDrive or X3 xDrive 28i failure rate we have no proof.
Old 01-17-2020, 08:19 PM
Mein Auto: bimmer
From an engineering perspective the root cause probably was determined long ago, and failure % computed with extreme precision.
To get that info(and spare everyone the guessing/discussing/arguing) is another undertaking that probably requires certain legal maneuvering and discovery.
In the meantime, another fellow N26(with PZEV warranty) owner at work plans to not bring car to dealer until CEL, even if engine whines crazy.
His rationale is that if CEL is not on, BMW will not pay for repair. But when engine blows(or is close to blow) due to TC jumping teeth, CEL will almost be inevitable(at least that's theory).
So just wait for the magic CEL, and make BMW pay for engine replacement.
This is not my preferred strategy, but it sounds logical.
My thinking is still that BMWNA at least should cover TC for all N26 PZEV cars, so that dealers can fix TC(relatively cheaply for BMWNA) before engine blows up.
