2016 F21 - Drivetrain Warning - Flywheel/Clutch? - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 1 Series & 2 Series > F20 / F21 1 Series (2012 - Current)
The second generation of the BMW 1 Series range of hatchback cars. Not available in the USA the F20/F21 was released in 2011 as the successor to the E81/E87. The body styles of the F20/F21 range are a 3-door hatchback (F21) and 5-door hatchback (F20).
The coupe and convertible models were spun off to create the BMW 2 Series.
Old 05-28-2020, 10:30 AM
nash1 nash1 is offline
Mein Auto:
A couple of weeks ago i got a drivetrain warning come up on the car. It doesn't come and go it stays on the whole time and shows up as soon as you start the car. The coolant was low so i topped it up, before i did this i noticed on one cold start there was quite a bit of white smoke coming out of the exhaust and the car sounded like it was losing a bit of power when it got to the lower RPM's (Idle). After topping up the coolant there was no more white smoke and the car sounded fine at low RPM's but the drivetrain warning was still coming up.
I got a call from the garage today (Not a BMW Centre) and they said it's an issue with the flywheel/clutch and it all needs to be replaced. From what i understand the flywheel doesn't have a sensor so how would the car flag this up as a drivetrain fault? I've had no issues with the clutch, no burning smell or slipping, no issues when changing gears either. Also the car has only done 33k miles.
Any thoughts on this?
