Process for removing rear brake calipers- BMW manual has odd instructions - Bimmerfest - BMW Forums
Old 10-19-2018, 07:04 AM
Bozman52 Bozman52 is offline
Mein Auto: 2010 530d
I need to replace my rear pads, and as my 530d has 80k miles on it, I'm sure the rotors will need to be replaced as well. I discovered that the 535d/550i in Europe came with larger rear brakes that will bolt onto a 530d, so I'm just going to completely upgrade the rears and buy new calipers while I'm at it. The ones I have look awful and probably need to be rebuilt anyway.
In the BMW service manual (see PDF attachment), the removal procedure for the rear calipers states that you're supposed to depress the brake pedal and keep it there while you remove the calipers. However, it would seem to me that fluid will come spraying out of the lines, as the system would be pressurised. The manual reads as if the act of depressing the pedal will actually PREVENT fluid from being released, though.
Has anyone done this before who can advise on if I should prepare to be soaked with brake fluid or not?
Old 10-19-2018, 10:31 AM
geminiys geminiys is offline
Mein Auto: F10 5353xi, E46 M3
I wouldn't follow the guidelines you have attached. I doubt the rear brakes are different between US and European model F10 besides bigger rotors and potentially pads. I can only speak to US based model.
You do need to address Parking Brakes per other descriptions on the forum. Due to caliper piston been extended with old pads you may experience resistance removing calipers from it's bracket. I have removed bracket and calipers all at once and after all was loose, bracket separated from the caliper easily. The next step is to open brake fluid reservoir and compress the caliper piston back into it's compressed position while watching brake fluid not been spilled from the reservoir. If never added fluid, it shouldn't be a problem. If you did, watch out and remove excessive fluid as you compress the piston. Do that on both sides. Replace rotors, if necessary, put bracket back, and so on.
Current Rides:
2013 535XDrive, 110k Miles
2005 M3, 77k Miles
1997 328is, 335k Miles - RETIRED
1998 Mercedes ML320, 200k Miles - SOLD
2005 Volvo XC70, 160k Miles
2018 Audi Q5, 100 Miles
Old 10-19-2018, 11:49 AM
3Pedals_6Speeds 3Pedals_6Speeds is online now
Mein Auto: fun cars
80k miles sounds like extremely low mileage to be replacing calipers at. Why not just hang them out of the way *still connected to the brake line) and replace rotors, then follow geminsys's steps on doing the pads?
Drive fast, take chances.
Old 10-20-2018, 02:57 PM
JeffDunes JeffDunes is offline
Mein Auto: 2011 535i Sport 6sp MT
It appears he wants to upgrade to a larger setup, otherwise I agree no reason to change at 80k miles unless the calipers are sticking.
2000 328ci Sport 5sp MT
1958 Isetta bubble car
Old 10-22-2018, 01:23 AM
Thanks for the replies, fellas. I'm looking to upgrade the brakes, hence the reason for replacing the calipers. I'm not really looking for steps on how to do the brake job, but I'm just specifically interested in what happens when I remove the calipers.
The manual makes it seem like the fluid will not be released from the hoses, but I find that hard to believe. I'm trying to determine if the brake system will be drained by me removing the calipers, of if BMW has devised some way for the fluid to remain in the lines if the brake pedal is engaged, as the instructions say it should be.
Old 10-22-2018, 02:37 PM
When you remove the brake hose from the old caliper just plug up the hose as best as you can (I use an old wooden golf tee and it works perfectly) and you will be fine. You do not want the level of brake fluid in the reservoir to get too low so keep an eye on it and top off if it starts to get too low.
Old 10-22-2018, 07:16 PM
Glaird Glaird is offline
Glaird
Mein Auto: F10-'16 550i, F82-'18 M4
With ABS and other Nanny State features on today's cars, I would have a mechanic change a caliper/install new brake setup. Opening those lines, will absolutely lead to the need to flush the fluid, bleed the brake system, replenish fluid in the tank. With the modern intervention systems, depending on vehicle, it is not as easy as; crack nipple, push pedal, squirt fluid, close nipple, raise pedal, repeat as necessary anymore.
Old 10-26-2018, 12:32 AM
550iFreak 550iFreak is offline
Mein Auto: 2011 F10 550i 6MT
I completely replace all my brakes in my 550i. I upgraded the fronts to x5M 4 pot brembo (from a 2011 x5m) and refreshed the rears. It isn't hard to do, and basic bleeding procedure is the same as other generic cars.
The rear calipers needs a special tool that will compress and turn the piston in the clockwise position to fully compress the caliper. Autozone rents out the tool when I did mines. I also got a one man bleeder tool that has a one way check valve inside the bottle. I just crack the bleeder, hook up the hose, press the brakes away until it is about full.
My brakes are brutal now ***x1f642;. My original fronts were replaced not too long ago but my rears are junk....even though it stated it was replaced and has 60k miles left on it...........
That was a major lie lol.
Now they are all reset and gives me 60k miles on front and rears....
And since mines a 6 speed manual......this might be the last set of brakes for a long.....long....long time.
