Brake fluid service notification - Bimmerfest - BMW Forums
Old 06-02-2020, 07:25 AM
jumbo_jet_z jumbo_jet_z is offline
Mein Auto: 2018 340xi GT
Hi,
I have a 2018 F34 approaching (slowly) 25000 miles. Yesterday a notification popped up telling me to schedule a brake fluid service appointment soon. However, my annual service is not due for another couple of months. Aren't those on the same schedule or does brake fluid have its own schedule?
Thanks,
Gene
Old 06-02-2020, 08:21 AM
John in VA John in VA is offline
Mein Auto: '74 tii / E28s / '03 530i
I believe BMW switched from 2-year to 3-year intervals for brake fluid several years ago. It makes sense to have it performed when you're in for other services.
___________
BMW CCA #30375 - National Capital Chapter
1974 2002tii
1986 535i
2000 328i
2003 530i
2006 330ic ZHP
2015 228i M Sport
Old 06-02-2020, 08:22 AM
FredoinSF FredoinSF is offline
Mein Auto: 4 BMWs, 1 Mini, 1 Vespa
Brake fluid is every two years.
Is annual service your oil change? If yes get both done together and synch them up.
Are you still under maintenance contract? If yes dealer obviously but if not find a euro independent and start establishing a relationship for out of warranty work that won’t break the bank.
Current:
2018 540ix
2015 428i convertible
2013 Cooper S
2007 650i - 6 speed
2002 330ci convertible - 5 speed
Past:
2012 X5 Diesel
2012 Countryman S All4 - 6 speed
2006 Cooper S - 6 speed
2006 330i - 6 speed
1997 328is - 5 speed
1991 318is - 5 speed
1988 635csi - 5 speed
1988 325i convertible - 5 speed
1969 2002 with tii and 5 speed conversions
Old 06-02-2020, 09:43 AM
Thank you. This would be the last 'free' service, so I'll get it all done in August. Yes, finding an independent mechanic is on my to do list and I got a couple of references from BMWCCA.
Old 06-02-2020, 10:15 AM
Good plan
Current:
2018 540ix
2013 Cooper S
2007 650i - 6 speed
Past:
2012 X5 Diesel
2006 330i - 6 speed
Old 06-02-2020, 08:57 PM
Dave 20T's Avatar
Dave 20T Dave 20T is offline
Super Moderator
Mein Auto: 320i/F30
BMW specifies that brake fluid should be changed 3 years from the date of manufacture, which is on the label in the driver's door jamb. After that, it's every 3 years. One should have the brake fluid changed under the free scheduled maintenance (US cars).
As far as when to change brake fluid, there's variable information.
Every year - this was the previous interval many years ago but still after the introduction of DOT4 brake fluid, which is the kind used today. BMW M series cars used to specify this. So did Saab.k Cars with track use may change their brake fluid even more often.
Every 2 years - this was the recommendation for BMW up until approximately 2015. (2013, it was still 2 years)
Every 3 years - this is the current BMW recommendation. Also the current Mercedes Benz and brake fluid manufacturer ATE recommendations. Color starts to change by 3 years.
Every 4 years - this was the latest Saab recommendation around 2010, about 2 years before they went bankrupt and stopped car production. GM also recommends 4 years. Color is definitely changed by year 4.
I feel that 2 years is a best economical interval but 3 is fairly reasonable. 4 years is tops. Don't go beyond that though you won't lose your life if you go to 5 years.
Bimmerfest is a wealth of information!
TPMS sensors from BMW are VDO or HUF/Beru, but are not the same even though frequency is the same.
https://www.bimmerfest.com/forums/sh...d.php?t=976197
Step by step instructions when a hood release cable needs replacement. https://www.bimmerfest.com/forums/sh...d.php?t=981724
SIB 11 13 15 oil filter housing for the F30 - metal since mid-2013 and can be retrofitted without charge
https://www.bimmerfest.com/forums/sh...d.php?t=951692
