Shuddering/Shaking! - Bimmerfest - BMW Forums
Old 03-30-2010, 09:27 PM
3mp3ror 3mp3ror is offline
Mein Auto: 97 528i
Shuddering/Shaking!
Hiya, new member here with some issues that I'd like to quickly solve...
My e39 recently started shaking/shuddering during start up and at idle! So, I popped open the hood and the engine is shaking. I don't remember it shaking before, is this normal? Also, the car doesn't shake at speed, only when it's in not in motion. High revs while driving is perfectly fine so I decided to rev the car in park to see if the shaking worsens and it does. It becomes much much worse as the needle climbs. If I start driving it goes away, however the shuddering intermittently starts again at idle or park.
My guess is that it has something to do with the engine mounts? The car ran smooth before I did a thermostat/air pump/air control valve repair...
Old 03-30-2010, 09:34 PM
edjack edjack is offline
Mein Auto: '97 540i 6 speed
"air pump/air control valve repair"? Secondary air pump?
Did you go back over your work and double-check it? What codes have you read?
It makes sense that, since the shaking began after the repairs, you've overlooked something.
Old 03-30-2010, 09:42 PM
Mein Auto: 97 528i
My car wouldn't pass smog and the OBDII scanner threw codes P0116, P1421, and P1423. Secondary air pump, engine coolant temperature, and low air flow readings. After doing much research I did the repairs and passed smog. I've rechecked after repairs and the components replaced are all fine
Old 03-31-2010, 04:16 AM
Fudman's Avatar
Fudman Fudman is offline
Mein Auto: 2015 X3 xDrive35i
Check your codes. Since the issue is at idle only, have you checked your ICV?
Old 03-31-2010, 09:19 AM
aa240sx's Avatar
aa240sx aa240sx is offline
Mein Auto: 2001 BMW 530I
Check your fan clutch too! I just had this problem. If it seems to spin like it's off balance it could be stuck and you'll need to replace it ASAP. $100 part fix.
- 2008 R350 Mercedes Wagon
- 2003 M3 Coupe - Alpine SMG
- 2001 530i - 5 speed, Anthracite Metallic, Sport Package
Old 04-02-2010, 09:17 PM
Mein Auto: 97 528i
Not yet, but I plan on it.
I do have a fan blade broken (thanks to a certain family member stepping on my fan :/) but I intended on replacing the fan and fan clutch anyway.
I checked my air filter and it wasn't secure in the housing so I fiddled with it. Now it's only rough/shakes at startup when the engine is cold. After normal engine temp, it starts smooth. Thanks for the suggestions so far.
Old 04-03-2010, 03:30 PM
TheeDragon TheeDragon is offline
Mein Auto: 98 740il
check MAF sensor
that was my problem
Old 04-03-2010, 06:13 PM
ztom's Avatar
ztom ztom is offline
I gotta have more cowbell
Mein Auto: 1997 528i
Make sure your MAF is connected also.
Old 04-14-2010, 07:15 PM
Mein Auto: 97 528i
$136 later my idle shake is now gone! From start up to continuous idle revving, it's rock solid now.
After weighing everyone's input, I narrowed it down to the only thing that changed since my recent repairs. A broken fan. I figured the missing fan blade would cause the fan to spin off axis and cause the engine to shake so I got a new fan clutch and fan.
Thank to everyone who replied!
Old 04-14-2010, 10:15 PM
aa240sx's Avatar
Good on ya - Truth be told when this happened to me, I brought it to a dealer. Service guy told me it was the fan clutch just on eyeballing it and I left for home to DIY.
Old 12-09-2012, 07:43 PM
Ktaylor757 Ktaylor757 is offline
E39 540i Sport
Mein Auto: 2003 540i w/Sport Package
This sounds exactly like what is going on with my 540 right now. I'll check out the fan clutch in the morning. Fan itself looks good at first glance.
Old 12-12-2012, 02:50 AM
xxthr4sh3rxx xxthr4sh3rxx is offline
Mein Auto: 2000 BMW 528i
My car was starting to shake at cold start, and occasionally at a red light (and other random times but only when stationary), then I bought a new siemens VDO MAF and now my issue is fixed. your MAF *MAY* be bad
