Z3 Roadster (E36/7) New sub amp wiring - Bimmerfest - BMW Forums
Old 10-31-2013, 01:51 PM
pem216 pem216 is offline
Mein Auto: 2001 z3
Talking New sub amp wiring
Does anyone know the input wiring for a new sub amp when leaving the existing main amp wiring intact? There are three wires coming into the HK sub amp from the main amp:
green on terminal #20
blue w/ green stripe on terminal #7
black w/green stripe on terminal #16
Is the green a common?
I intend to solder RCA plugs to these wires as input to a new Alpine class D mono sub amp.
Thanks for your help!!!!
Old 10-31-2013, 04:46 PM
Blacklane Blacklane is offline
Mein Auto: 1998 Z3 Roadster
Have you looked over this thread?: https://www.bimmerfest.com/forums/sho...d.php?t=690361
Old 10-31-2013, 05:52 PM
Mein Auto: 2001 z3
sub amp wiring
Thanks Blacklane for the response.
I have reviewed that thread and still cannot positively determine if the GREEN wire ON TERMINAL #20 is the common for the L & R channels going into the SUB AMP. If it is then I will connect some RCA male plugs and use the brown as the common to the shield, and plug into my new Alpine mono amp.
Does this make any more sense?
Thanks again!
Old 10-31-2013, 06:33 PM
Mein Auto: 2001 z3
Should be GREEN wire above
Old 10-31-2013, 07:01 PM
On BMWs, brown is always the power ground. Audio signals are usually twisted pairs with one stripe being the "muted" color of the other stripe. So say you have a twisted pair of yellow with blue stripe and yellow with gray stripe, the gray stripe will be the negative one.
Old 10-31-2013, 07:13 PM
Mein Auto: 2001 z3
Thanks Blacklane, for the information!!
