Air Suspension e70 3.0si 2009 (2008 model year) - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > X3 M, X5 M, X6 M, Z3 M & Z4 M > E70 X5 M and E71 X6 M (2010 - 2015)
The BMW X5 M and X6 M are the first xDrive all-wheel-drive vehicles from M GmbH. The M variants offers the same utility as the regular X5 and X6, with the addition of the V8 M TwinPower Turbo, a twin-turbocharged 4.4-liter V8 delivering 560 horsepower and 500 lb·ft of torque.
Old 04-11-2019, 02:33 PM
PhilClayton PhilClayton is offline
Mein Auto: E61 550i, E60 530d & E70
Investigating failure of rear air suspension failure. Car is down on the stops on both sides. No history from PO.
1. No DTC codes.
2. All fuses intact.
3. Have pulled and reinstalled relay. 4.Compressor does not run with ignition on/door opening.
5. With car jacked up to get access to compressor removed connectors to check for supply.
A) 5.3v across two pins of valve block connector.
B) no supply to motor (under ign on/door open etc)
C) no supply to solenoid/valve on accumulator chamber.
When I removed the connector to the solenoid valve/ accumulator water dripped out. So I removed the solenoid valve from the accumulator and it was very wet dripping inside. Investigating further I removed the accumulator chamber and found it to be full of wet desiccant. Does this suggest that there has been a leak resulting in the motor running for an extended period of time and creating water from condensate? Does this make sense?
1. Would you normally expect to have 12v on the supply to the motor?
2. Is the 5.3v on the valve block a signal from the level sensors/control module?
3. Anyone else seen something similar with the desiccant in the accumulator?
4. Any tests I can run on this? Put 12v across motor and see if it runs? Put 12v across solenoid valve on accumulator tank?
Thanks in Advance.
Note I’m expecting to replace airbags, have some on order, but want to have a running compressor before they arrive.
Sent from my iPhone using Bimmerfest mobile app
Old 04-14-2019, 02:01 AM
Have tested relay and operates correctly.
Have disassembled compressor and found more water and three corroded/seized bearings on the motor that appear to have been a consequence of the water. Wondering if this can all be condensate or if the PO flooded the car. No other obvious sign of water damage.
Old 04-18-2019, 03:27 PM
Update on progress. Replaced airbags, compressor now operational fingers crossed that when I reinstall the suspension will be operational.
Old 05-02-2019, 06:14 AM
Suspension now operational with new compressor. Winding burnt out on old motor unit (likely result of seized compressor).
Similar Threads
Air Suspension Problem johan3134 7 Series - G11 / G12 (2016 - current) 7 03-13-2019 01:20 PM
Complete 2018 Model Year BMW Pricing and Ordering Guides - All Models tim330i Ask-A-BMW-Dealer 7 10-09-2018 01:15 PM
FS:Fuel Injector (OEM/NEW) BMParts954 Parting Out 0 04-30-2018 01:28 PM
FS:Xenon Light Control Unit BMParts954 Mobile Electronics and Lighting 0 04-30-2018 01:14 PM
E65 V12 debuts nate General BMW Questions 22 06-09-2016 01:44 AM
