Stall when cold and in reverse. 2013 X5d - Page 3 - Bimmerfest - BMW Forums
Old 01-22-2019, 06:31 AM
rmstevensiii rmstevensiii is offline
Mein Auto: BMW X5 xDrive35d (E70)
The transmission fluid/filter change resolved my issue.
My assumption is that the fluid level was low (no easy way to check this), cold, and when backing down a hill the torque converter was locking up and causing the motor to stall.
Old 05-17-2019, 11:31 PM
Dieseltime Dieseltime is offline
Mein Auto: 335D
How many miles did your x5 d have when you did the transmission service. Mine is doing the same thing 2011 45,000 miles.
Old 05-17-2019, 11:38 PM
SPL15 SPL15 is offline
Mein Auto: E36 M3. E46 325i, E70 35d
If you're experiencing similar; at your milage & age, I'd do a drain & refill w/ a new pan filter regardless of what the OP says their mileage was... If your trans is doing the same due to low fluid, it really doesn't matter what mileage anyone else's transmission service was performed at...
ZF recommends a fluid change at 8 years, or 80K miles if you drive like a normal person... Sooner if you drive hard and / or at high speeds frequently.
If you're losing trans fluid, you need to find out why...
Old 11-05-2019, 04:43 PM
Majorkahuna Majorkahuna is offline
Mein Auto:
back up problem solved
Transmission was in fact low on fluid. I went ahead and did a full service at 66k.
