G-Series X3 2018 M40i G01 Series Coding Parameters Cheat Codes - Bimmerfest - BMW Forums
Old 07-22-2018, 02:37 PM
ngr2001 ngr2001 is offline
Mein Auto:
I would like to get a thread going for a known verified list of ESYS Programming codes for the 2018 X3 G01 Series Chassis.
To start, I can validate the following works: (Tested on 2018 X3 M40i)
Disable Auto Start Stop (ASS)
DME – 3020 – TSA_MSA_Memory - werte =
0 = Default
1= Remember Last Setting (Effectively Disable “ASS” Auto Start Stop)
*Must Code this with the engine off !!
Requesting:
Anything and everything Seat belt and or warning / restriction Related.
Old 08-09-2018, 12:22 AM
sbinshihon sbinshihon is offline
Mein Auto: X5 M-sport
Bumping up this thread. Did you ever find how to disable the chimes and warnings?
Old 08-14-2018, 11:08 AM
Mein Auto:
Nope, I'm hoping someone out there can help a brother out.
Anyone out there
Old 08-14-2018, 11:19 AM
I got you brother, here you go all the codes to disable all the warnings;
https://github.com/packetpilot/bmw-f...e162dbfa729102
Sent from my iPhone using Bimmerfest
Old 08-14-2018, 11:27 AM
Mein Auto:
Thank you, i'll give these a shot. many of them look very similar to the codes I am already familiar with but seemed absent on the X3 2018 M40i when I browsed the normal locations using Launcher Pro.
Old 08-14-2018, 12:04 PM
You are welcome. These codes are located in the ACSM module, with the G012 I found them in the first folder of that module. Search all the ACSM folders you will find them in there.
Old 08-18-2018, 03:24 PM
Almaretto's Avatar
Almaretto Almaretto is offline
Super Moderator
Mein Auto: Test Vehicles
Those will not work for a 2018 G01. Functions moved in your updated firmware.
Old 09-03-2018, 01:53 PM
Mein Auto:
I searched all the folders, they were not found, no dice brother.
I did find Gurtzustandsanzeige_Fahrer, but it nothing.
Almaretto, are you saying this is impossible on a 2018 x3 m40i, that the engineers removed this tweak from the firmware from the factory ?? This is driving me crazy I really want to turn this off.
Thanks.
Old 09-03-2018, 03:10 PM
Almaretto's Avatar
Super Moderator
Thanks.
I still code it all the time.
Old 11-15-2018, 12:54 PM
pej7445 pej7445 is offline
Mein Auto: 2019 X3 m40i
Bump.. Any progress on a cheat sheet for the G01?
Old 11-22-2018, 06:42 AM
kevinkay kevinkay is offline
Mein Auto: x5
0 = Default
Requesting:
I could'nt find TSA, but found TCM would this disable ASS?
2019 X3 G01 series
Old 11-22-2018, 07:20 AM
Yes, use TMC
Old 11-22-2018, 07:59 AM
Mein Auto: x5
YES, this worked for me. THANK YOU!
DME – 3020 – TMC_MSA_Memory - werte =
0 = Default
1= Remember Last Setting (Effectively Disable "ASS" Auto Start Stop)
Old 12-03-2018, 10:23 AM
Mein Auto: x5
LEGAL_DISCLAIMER_TIME werte=0A
MACRO_CAM_LEGALDISCLAMER werte=06
MACRO_NIVICAM_LDISCLIMER werte=06
got rid of my disclaimers
not my original work....
Old 12-23-2018, 07:57 AM
I'm going to start working on my 2019 G01 m40i this week. Here is my wishlist on what to code;
1. No more seatbelt reminders
2. Turn Signal in HUD
3. Max start-up volume for audio system
4. 1 touch tailgate close via rocker switch
5. 1 touch tailgate close via key fob
6. Windows continue to close even if doors are opened.
7. Holding lock button on FOB to close all windows.
8. Adjusting the angle of passenger mirror, it goes down way too far.
9. Find a way to control/moderate the digital display brightness, especially the HVAC controls during the day. They get very dim way too easily and adjust too frequently for my taste.
I'm going to create a spreadsheet of my work as I go and will share with the forum. If anyone has already achieved any of the above and can save me time/risk I'd appreciate a message.
I have already used the BimmerCode app to do some basic stuff;
1. Disclaimers Removed
2. M-Sport Graphic at start up.
3. Remove On Screen Display.
4. Disable ASD
5. Using expert mode activated Enhanced Bluetooth so I can read Emails and SMS, as well as dictate and send messages using voice commands. I had to do this because I didn't order the Wireless Charging/Hot Spot option.
Thanks!
Old 12-23-2018, 11:54 AM
Mein Auto: x5
Playing other video formats:
ENT_CODEC_OGG -aktiv
ENT_CODEC_XVID - aktiv
ENT_MC_VIDEO_SUPPORT - aktiv
remove vol. pop up display:
VOLUME_POPUP_DISPLAY - nicht_aktiv
Enhanced bluetooth, more than 3 lines of text:
PIM_DRIVING_TEXT_LENGTH - all
Old 12-24-2018, 01:32 PM
djrobx djrobx is offline
Mein Auto: BMW X4 G02 m40i
My sole wishlist item is stopping the seat belt tensioners from activating when you drive off. I don't mind the "hug" itself but sometimes it doesn't let go (awkward hug!)
Old 02-18-2019, 04:21 PM
Mein Auto: x5
Disabling seat belt waring - this worked for me (copied from G12 post):
ACSM_5 > Gurtwarnung 3001 > Gurtwarnung_0_0_255 = nicht_aktiv [Default]
ACSM_5 > Gurtwarnung 3001 > Gurtwarnung_1_1_255 = nicht_aktiv [Default]
Old 05-22-2019, 10:45 AM
09bmw335d 09bmw335d is offline
Mein Auto: 335d
anyone got any more codes for g01?
Old 05-22-2019, 11:03 AM
Mein Auto: x5
I posted what i had - you got any?
Old 05-22-2019, 11:51 AM
Mein Auto: 335d
How to code fogs on with parking lights only?
Under BDC, go into expert mode.
NSW_EIN_AUF_LDS_STL = Aktiv
If you want fogs on with highbeams:
NSW_AUS_BEI_FL = nicht aktiv
DKOMBI2, expert mode, 3000 configuration, ALPINA_ENABLE
To activate VIM on NBT ID5/ID6 you need to code the following:
HU_NBT2 – 3000HMI – SPEEDLOCK_FREISCHALTMENU – aktiv
lane keep assist
CODING :
C:\Data\CAF\CAFD_00001C7A_002_240_003.ncd
SAS10
C_SWA_Vorhanden -> True
C:\Data\CAF\CAFD_00001EF6_006_028_018.ncd
HU_NBT_EVO
Spurwechselassistent -> Aktiv
turn off front window roll-up door interrupt (Auto-Up when door is locked)
----- BDC 3050 -> FH_TUERAUF_STOP_MAUT set to: nicht_aktiv
Old 05-22-2019, 01:12 PM
Mein Auto: x5
Rolls Royce sounds:
for chimes 3002 AUDIO_TUNER_TRAFFIC
SOUND_SIGNAL_SET
ROLLS_ROYCE
RINGTONE
3003 TELEFON_TELEMATIK_ONLINE
RINGETONE
RR
Old 05-22-2019, 07:34 PM
Mein Auto: 335d
Found some more
KOMBI2 (CAFD 2660)
3001 KI_Parameter / LOGO_SCHRIFTZUG: Displays the M (or other) logo in sport mode. You must have the option 6WB for it to work Tested and functional with the value msp_logo - Other available options: b5 / 6 / 7_biturbo, edrive_logo, m40d_logo, m550d_logo, m750_d, xd3_biturbo, ...
3000 Anzeige_Konfiguration / HUD_SPEED_LIMIT_ENABLE: disables the display of speed limit signs Tested by Stylefr and functional
HU_NBT2 (CAFD 1ef6)
3001 EXBOX / STARTUP_EMBLEM: to display the logo M (or another) on the idrive at startup. 1 is M, 6 is connected drive - if you search on google, you will find the list without problems Tested and functional
3002 AUDIO_TUNER_TRAFFIC / SOUND_SIGNAL_SET: change the sound of "gong" by rolls royce or mini Tested and functional
DME_BAC2 (CAFD 29b7)
Reminder: Never encode the DME with the engine running.
3020 BSU_BEREICH / TCM_MSA_MEMORY: memorizes the start / stop configuration Still being searched
BDC_BODY2 (CAFD 5fa9)
3040 VaMaster / VAM_HORN_AT_SECURE: Do not honk twice when you lock the car with the engine running Tested and functional
Old 05-23-2019, 03:16 AM
Mein Auto: x5
look back - memorizes start/stop worked for me-
https://www.bimmerfest.com/forums/sh...5&postcount=13
Mein Auto: x5
