coding Speed Limit Display - Page 3 - Bimmerfest - BMW Forums
Old 08-21-2015, 10:25 AM
Vinnya320 Vinnya320 is offline
Mein Auto: F80 M3
Originally Posted by neo_andersson View Post
Coding will require adding 8TH to VO and code CIC/NBT and kombi/dkombi.
Wiring instructions are provided with adapter.
thanks neo. are both units posted here the same? the euro one is more expensive than the Chinese one. unsure as to which one to order. coding seems simple enough. thanks!
Old 08-21-2015, 11:06 AM
neo_andersson's Avatar
neo_andersson neo_andersson is offline
Mein Auto: 2014 640xd
i can not tell anything about the Chineese one. According to label on it its doing something else, it enables 7E FSC code in a KAFAS2 unit, so car must have Kafas in order for SLI to work. The European unit (which we manufacture) is a standalone solution for Speed Limit Display, taking info from navigation system and showing it on cluster and/or HUD. Our unit works with or without KAFAS so is a good solution for cars without Kafas. FOr forum memebers we have a 50 euro discount available. Use coupon code "SLI50" during checkout to claim it
F13 640xd M Aerodynamics Package / AC Schnitzer Performance Upgrade / 360CP - 690Nm / Individual RubinSchwarz Metallic / EVO ID5 / Digital Cluster (6WB)
F36 420xd M Sport Package/MPPK 200CP-420Nm/Individual Frozen Bronze Metallic/Individual Merino Muskat leather / EVO ID5 + EVO RSE + Touch Command
Old 08-21-2015, 11:27 AM
Mein Auto: F80 M3
thanks! no kafas here so I think I'm going to try your solution. can you confirm that you have done an install with this unit and it does work? thanks! I'll be placing an order later today.
Old 08-21-2015, 11:33 AM
we installed more then 10 units during the last week after it went on sale. This solution was tested by us for the last 2 months using Europe and North America Premium and Next maps (2015-2) and is working very well.
We also have some test units out in different parts of the world and waiting for functionality feedback from beta-testers (Shawn is one of them). As system uses map SLI data we can confirm now is working with Europe and North America maps but have not tested yet for other regions (Asia, Australia, Middle East, North Africa, etc.) This maps must contain SLI data for unit to work.
I see you are in US so will not be a problem for you.
Old 08-21-2015, 11:35 AM
Mein Auto: F80 M3
great! thanks!
Old 08-21-2015, 11:46 AM
secany secany is offline
Mein Auto: 650i F13
Hi neo_andersson,
Do you think it works with BMW i8 ?
I have X5 F15 and BMW i8 , both of them are using Australia 2015 maps.
If you confirm that it will works for both X5 and i8, display on NBT and/on HUD, and of course, with proper easy DIY instruction, I'll get 2 units.
Thanks.
Old 08-21-2015, 11:57 AM
Hi, we did not tested with Australia maps. We dont know if NBT map of Australia contains SLI data. You can get 1 unit for testing in both cars, if OK you can order a second one, if not you can return it for refund.
Old 08-22-2015, 03:36 AM
GDMERC GDMERC is offline
Mein Auto: 2013 528xi
Does it come with instructions on how to install it?
Old 08-22-2015, 06:31 AM
shawnsheridan's Avatar
shawnsheridan shawnsheridan is online now
bimmerfest Supporting Member
Mein Auto: 2016 650i GC M-Sport
Yes.
2016 650i GC M-Sport w/ 20" 373M Wheels; Alpine White; Individual Opal White Full Merino Leather; Gray Poplar Wood Trim
Anthracite Alcantara Headliner; Ceramic Controls; Executive Package w/ B&O Sound System; Integral Active Steering, etc.
Old 08-23-2015, 05:17 AM
miotoo miotoo is offline
Mein Auto: F10 520d
Regarding the Chinese box, the label is as usual in China - says "BMW" and "FSC" and "KAFAS2" and "NBT" but it is none of these..and it is not an "FSC emulator".
The box is tapping into the PT_CAN network and injecting code to bypass the requests where KOMBI is asking KAFAS or KAFAS2 for validating a road sign signal.
The PT_CAN network already exists in any Fxx series as part of the ZGW gateways and is activated with coding / VO coding the relevant features. It will work on any car whether it has no KAFAS or any version of it.
For me they are worth the 30 USD that they are sold for and will do the job apparently. If I spend 200 USD I can retrofit a used KAFAS 1 + CAMERA and have the other benefits like a path for LDW etc..
What is interesting to find out, is whether any of these boxes interfere with LDW, ACC, CDW and other features that the car may have installed, while not having SLI.
F10 520d Deep Sea Blue 11.04.2011/16:24
Retrofitted:
5DF Active Cruise Control with Stop & Go incl. Collision Warning with Brake Function /ver. 1
2TB DEC Switch for Normal / Sport / Sport+ Writeup: https://www.bimmerfest.com/forums/sho...d.php?t=685869
8TH SLI Speed Limit Info / KAFAS 1
5AD LDW Lane Departure Warning / KAFAS 1
319 Universal Garage Door Opener
6WA Instrument Cluster with Extended Contents
Old 08-23-2015, 07:27 AM
I can speak only for our "box", there is no interferance with any of the car systems. We installed already in Fxx with LDW, ACC, TLC, standard cluster, 6WA and 6WB.
Also, our box has dual functionality as it can be configured by internal dip switch to activate 7E FSC code if KAFAS2 is installed.
So it can be used as a stand alone map based SLI device for cars without KAFAS or as KAFAS2 SLI 7E FSC code activator if a used KAFAS2 ECU is retrofited with pre-loaded 7E FSC from donor car.
Old 08-23-2015, 07:32 AM
ViperX ViperX is offline
Mein Auto: 420D
After some research heres what ive managed to find. FOLLOW AT YOUR OWN RISK, I WILL NOT BE HELD LIABLE AS THIS IS FOR INFORMATION PURPOSES ONLY
Locate the wiring connector to the kombi and remove it
Remove the small connector thats inside of it
Locate the wires, i believe
Pin 1-Power
Pin 7-Ground
Pin 6- CAN High
Pin 12-CAN Low
The SLI adapter has four wires, connect
Pin 1-Power
Pin 2-Ground
Pin 3-CAN High
Pin 4-CAN Low
VO code 8TH and activate
Old 08-23-2015, 10:15 PM
Mein Auto: 650i F13
Hi neo_andresson and Shawn,
On this thread: https://www.bimmerfest.com/forums/sho...624810&page=11
Original quote from Shawn: https://www.bimmerfest.com/forums/sho...&postcount=254
He has Pro Nav with NBT and latest 2015 Australia NEXT map. The problem is BMW did not license SLI Map Data, so it is blocked in Australia.
Shawn confirm that Australia map did not have SLI data, so your hardware will NOT work with Australia maps, right?
If so, of course China solution won't work as well.
Old 08-23-2015, 10:35 PM
I am not 100% sure SLI data is missing in Australia NEXT map.
We could not test yet in a live car driving in Australia.
Anybody willing to test it can do so, if not working can return the adapter for a refund.
Old 08-24-2015, 03:35 AM
g4movtpt g4movtpt is offline
Mein Auto: bmw 520da 2014
Where can i find the kombi if i have the nbt after 2013? I have no kombi isn't it?
Old 08-24-2015, 04:02 AM
you have kombi or dkombi
Old 08-24-2015, 04:24 AM
Mein Auto: 650i F13
check my email, i was about to put order, but asked more about another product so I could save on shipping.
Old 08-24-2015, 05:15 AM
To clarify, BMW not license Australia SLI Data; however, I do not know if a) SLI Data is missing from map or b) SLI Data is present, and blocked. So if the latter is true, then Adapter would work if SLI Data can be unblocked.
Old 08-24-2015, 06:00 AM
Thanks and where can i find it?
Old 08-24-2015, 06:25 AM
You dont need Smart Opener. In you car this option can be installed with OEM parts and coded.
Old 08-24-2015, 07:23 AM
How difficult is the installation?
Old 08-24-2015, 08:08 AM
you are asking for smart opener option or speed limit info?
Old 08-24-2015, 08:20 AM
Speed limit info
Old 08-24-2015, 08:24 AM
what car you have? you have kafas or not?
Old 08-24-2015, 09:18 AM
DTKT DTKT is offline
Mein Auto: BMW E90 325
Hi Neo, can ask, if my car dont have camera, LDW, ACC and TLC, can this work ?
