Help with F10 ACSM reset to OEM - Bimmerfest - BMW Forums
Old 12-31-2014, 02:38 PM
Alex.br Alex.br is offline
Mein Auto: 2013 F10 M5 / 2012 E82 1M
Hi all,
Happy New Year!!
I messed my F10 ACSM module after coding it just after my wife's F25.
Now I have an Airbag faulty code and System restrain Module error at the iDrive.
How do I reset and re-code the ACSM module with the Factory configuration?
Any helps and directions will be appreciate.
Thanks,
Alex
Old 12-31-2014, 09:25 PM
shawnsheridan's Avatar
shawnsheridan shawnsheridan is offline
bimmerfest Supporting Member
Mein Auto: 2016 650i GC M-Sport
Does ACSM have CAFD with Green Dot next to it?
If so, you need to lock ACSM:
Lock ACSM (Required After Flashing to reset the Airbag)
Try E-Sys Transmitter:
Click "External Applications" in the left menu.
Click "External Application"
Double-click "Transmitter"
Double-click "ACSM verriegelung_schreiben" (ACSM verriegelung_schreiben_new?)
If that does not work, try EDIABAS / Tool32:
Launch C:\EDIABAS\Bin\TOOL32.EXE
Hit F3
Load C:\EDIABAS\Ecu\ACSM4.prg
In the "Select Job: F01" window, select steuern_verriegelung_schreiben
Hit F5
Results" window should show "JOB_STATUS = OKAY"
Note: fs_lesen_funktional only read fault codes, FS_LOESCHEN_FUNKTIONAL will delete it.
2016 650i GC M-Sport w/ 20" 373M Wheels; Alpine White; Individual Opal White Full Merino Leather; Gray Poplar Wood Trim
Anthracite Alcantara Headliner; Ceramic Controls; Executive Package w/ B&O Sound System; Integral Active Steering, etc.
Old 01-01-2015, 02:36 AM
Thank You Shawnsheridan!
Do I need a new EDIABAS Version? Could you PM where I can find it?
Thanks,
Alex
Old 01-01-2015, 05:14 AM
Thanks,
Alex
PM sent.
Old 01-01-2015, 09:24 AM
Hi Shawnsheridan,
The F10 ACSM ECU still with the issue. When I read the CPS from ACMS it shows [yyyyyyy] instead of the VIN.
Should I send it to the dealer or is it possible to fix this error?
Thanks for you help.
Alex
Old 01-01-2015, 09:28 AM
Hi Shawnsheridan,
Alex
Back to my first question. Does ACSM have CAFD with Green Dot? If so, what is name of CAFD?
Old 01-01-2015, 09:35 AM
No it doesn't have green dot. It doesn't have a CAFD.
It shows:
ACSM[1]
BTLD_00000906_003_003_001
HWEL_0000090C_002_005_000
SWFL_00000908_004_003_001
Thanks,
Old 01-01-2015, 09:37 AM
It shows:
ACSM[1]
Thanks,
Exactly, and therein lies your problem. You must inject CAFD (all 3 of them) into ACSM and VO Code it,
Old 01-01-2015, 09:46 AM
How do I inject the 3 CAFD into ACSM?
Old 01-01-2015, 09:57 AM
PM me TeamViewer login and I will fix it
Old 01-01-2015, 10:21 AM
Solved by Shawnsheridan! Thank you very much.
Be my guest when you fly to Rio!!
Old 01-01-2015, 10:33 AM
Old 03-01-2015, 01:37 PM
livaditisd livaditisd is offline
Mein Auto: x70
Sp-daten files and stupid brother
hello I have a 2007 x5 my brother convince me that he can update daten files so now the issue is I have an error on my screen pass. restraint system so my question is how do I go back to an old file to corrected please keep in mind I'm new and have a day and a half of reading all this information I appreciate
ID:	495202   Click image for larger version
ID:	495203   Click image for larger version
ID:	495204   Click image for larger version
Old 08-08-2016, 01:25 AM
Drealdeo Drealdeo is offline
Mein Auto: 2011 BMW 535 Xi
Hi shawnsheridan, I have 2011 535xi, I have a few issues I need help with. I have code 930AB7 after replacing airbag and seatbelts. (Three crashed data stored) how can I recode the acsm. 2) I changed the fog lamps to led from a 2014 style, how can I code it to the car in order to get rid of the fog lo malfunction message. Thanks in advance.
Old 08-08-2016, 07:36 AM
I am not sure about ACSM. I would clear all errors with Tool32 and then Lock ACSM, and then see what you got.
Clear Fault Codes:
  1. Launch C:\EDIABAS\Bin\TOOL32.EXE
  2. Hit F3
  3. Load C:\EDIABAS\Ecu\F01.PRG
  4. In the "Select Job: F01" window, select FS_LOESCHEN_FUNKTIONAL
  5. Hit F5
  6. Results" window should show "JOB_STATUS = OKAY"
Lock ACSM:
  2. Hit F3
  3. Load C:\EDIABAS\Ecu\ACSM4.prg
  4. In the "Select Job: F01" window, select steuern_verriegelung_schreiben (steuern_verriegelung_schreiben = control locking write)
  5. Hit F5
As for LED Fog Lights, I would FDL Code the fol;lowing:
FRM => AUSG_11_NSW_L_IS_LED = aktiv
FRM => AUSG_11_NSW_L_KALT_UEBERW_AKTIV= nicht_aktiv
FRM => AUSG_11_NSW_L_WARM_UEBERW_AKTIV = nicht_aktiv
FRM => AUSG_12_NSW_R_IS_LED = aktiv
FRM => AUSG_12_NSW_R_KALT_UEBERW_AKTIV = nicht_aktiv
FRM => AUSG_12_NSW_R_WARM_UEBERW_AKTIV= nicht_aktiv
Old 08-08-2016, 11:05 AM
Clear Fault Codes:
  2. Hit F3
  5. Hit F5
Lock ACSM:
  2. Hit F3
  5. Hit F5
Thanks a lot boss i will try that and get back to you. On the other hand i replaced the szl with a 2014 model szl with paddle shifter, it works fine, just not coded to my car. Is there anyway i can do a retrofit so o can code it to my 2011 model as its only giving me a replace option when i tried to code it. If there's an option i'd like to try it all together tomorrow. Thanks i really appreciate your swift response.
Old 08-08-2016, 11:10 AM
Clear Fault Codes:
  2. Hit F3
  5. Hit F5
Lock ACSM:
  2. Hit F3
  5. Hit F5
Thanks a lot boss i will try that and get back to you. On the other hand i replaced the szl with a 2014 model szl with paddle shifter, it works fine, its just not coded. Is there anyway i can do a retrofit so o can code it to my 2011 model as its only giving me a replace option when i tried to code it. If there's an option i'd like to try it all together tomorrow. Thanks i really appreciate your swift response.
Old 08-08-2016, 01:15 PM
Sorry, but I don't know about SZL. Use E-Sys to Code it i instead of ISTA/P.
Old 08-09-2016, 08:12 AM
Thanks ill try that and let you know if it works.
Old 08-12-2016, 07:30 AM
bmw0510 bmw0510 is offline
Mein Auto: f10
You need code DSC,SZL will be coded.
Old 03-14-2017, 04:22 AM
mohammod mohammod is offline
Mein Auto: BMW 420D F32
Shawnsheridan
Can you please help me because im stuck i the same position? The green dot is missing and i cant fix it. I have teamveiwer and the esys software.
Old 03-14-2017, 04:29 AM
Originally Posted by mohammod View Post
Shawnsheridan
Did you try and Inject CAFD into it and VO Code ACSM?
Old 03-14-2017, 07:06 AM
I dont know how to do it my friend
Old 03-14-2017, 07:10 AM
Connect => Read FA (VO) => Activate FA (VO) => Read SVT (VCM) => Left-Click on ACSM => Click on "Detect CAF for SWE" => Select the CAFD (all 3) from latest I-Level shown => Select OK => Right-Click on ACSM (the ECU itself not the underlying CAFD) => Select CODE.
Old 05-23-2017, 04:33 PM
almaz almaz is offline
Mein Auto: F10
Hello,
I have the same problem, after uptade all block in my F10, i get the airbar error.
and if i go in e-sys "ACSM verriegelung_schreiben".. the error is still there
do you can help me ? i have TeamViewer
