akk headlamps inoperative - Bimmerfest - BMW Forums
The X5 SAV Forum
Old 05-10-2019, 05:11 PM
primem primem is offline
Mein Auto: 2005 x5 4.4L
Hi Everyone...first post. The wife brought home a used 2005 x5 4.4L. Now I gotta fix it.
Problem: All 4 headlights are inoperative
-xenon low beam and halogen high beams do not come on in auto or full on switch position.
-the park light do work in both switch positions
-the fog lights work
-the high beams come on for flash to pass
-check low beam message is displayed in the cluster
I've had a look at the headlight wiring diagram. Everything is fed from the headlight module. I plan to check for power and ground at the headlight connectors. If I get no power to the headlights and the wiring is intact, can I assume the headlight module is NFG?
Does the headlight module set dtcs that can be read with a scan tool?
If I need a new module...is it a dealer part only? does it need dealer programming?
Old 05-10-2019, 06:22 PM
Zulu95's Avatar
Zulu95 Zulu95 is offline
Mein Auto: 2001 X5 3.0L
High beams might be flash to pass only if you have bi-xenon lights. Can you hear a noise like a relay operating when you go between high/low beam? It could be you need two new xenon bulbs, ballast or modules. A new LKM has to be linked to the vehicle. A number of aftermarket programs claim they can do this. When my LKM failed in the E53 the $tealer took something like 14 hours on the computer to get it linked in. Sure glad it was a CPO repair.
Sent via Telegraph wires using my Morse Key.
2001 X5 3.0L SOLD
2013 X5 xDrive35i
Old 05-10-2019, 08:20 PM
I do have xenon lights. I do not hear a shutter/cut off for the xenon lights. Is the light control module located in the passenger footwell by the Apillar? I will check things out tomorrow.
Gotta say obtaining service information for this vehicle is pretty difficult and I have access to all data and identifix.
Old 05-11-2019, 07:48 AM
QSilver7's Avatar
QSilver7 QSilver7 is offline
Mein Auto: 2006 X5 4.4/2013 650ix GC
If you dont' have the www.newtis.info website saved/bookmarked...you may want to add this site to your arsenal. If you enter the last 7 digits of your VIN...it will pull up wiring diagrams, operational and DIY instructions based on the VIN entered.
Here's some historical development of the LM/LCM info that will help you determine its location:
ID:	851441   Click image for larger version
ID:	851443   Click image for larger version
ID:	851445   Click image for larger version
Q {BMW CCA Member #191509}
2006 E53 X5 4.4i (Sterling Gray) 12/05 mfg date <<~>> 2013 F06 650ix Gran Coupe` (Black Sapphire) 1/13 mfg date
(SOLD)
97 740iL (Arctic Silver) <<~>> 99 540iT (Orient Blue) <<~>> 95 525IT (Alpine White)
https://www.bimmerforums.com/forum/attachment.php?attachmentid=637911&d=1538398374&thumb=1&stc=1
Old 05-11-2019, 10:04 PM
Thanks. I will check it out and report back when I find a fix.
Old 05-18-2019, 03:49 PM
Thanks to zulu95 and q silver7 for the info.
did some testing today
-as stated by zulu95...the highbeams are daytime running lights and flash to pass only. The hids are the full time headlights with shutters to differentiate for high and low beams. HIDS don't like to be shut on and off.
So the "highbeams/dtrl" are working normally...just no high or low beams from the xenons. I can hear the shutters working for both headlamps.
I accessed the right headlamp connector and checked for power from the light module; battery voltage was present, grd was good. The headlamp control module/ballast must be bad. I have found them at the retrofit source, much cheaper than anywhere else...$65 each. 10 to 15 days I may have lights.
Old 05-18-2019, 07:00 PM
Zulu95's Avatar
I find it strange both ballast would fail at the same time but I guess anything can and does happen. Keep us posted.
2001 X5 3.0L SOLD
2013 X5 xDrive35i
Old 05-20-2019, 08:13 PM
the history of the vehicle is unknown. All I know at this point is both are inop. I have power and grd to the headlamp so the fault must be in the headlamp...either the ballast or bulb. As far as I can tell, the only way to test the ballast and bulb would be to swap it with a working one.
I did not inspect inside the headlight; that might be my next step.
Old 05-20-2019, 08:28 PM
Zulu95's Avatar
I do remember something about wiring faults in some facelift headlights back when they first came out. Might need to do a search for that one. One guy cut into the units to get to the faulty wires.
2001 X5 3.0L SOLD
2013 X5 xDrive35i
Old 05-25-2019, 04:46 PM
update:
pulled both headlamp assemblies today to inspect the wiring. The wiring was ok....the bulbs and igniters were removed by someone before my wife bought it.
I have found an aftermarket replacement kit that includes, 2bulbs, 2 ballasts, wiring... everything for $137...and lifetime warranty.
On another note...I called the bmw dealer for a quote for transmission control module programming. What an effort that was.
Asked for a quote to do programming....got told diagnostics are $175/hr. I said I don't need diagnostics, I need programming....was transferred to the parts dept. Told parts guy I don't need parts...sent me back to the same service writer....told her I don't need to buy any parts, I need a module reprogrammed. She didn't know what that involved. She asked someone and said it would be $135/hr and would take 2 to 3 hours.
...which is complete bs. We have zf transmissions at dodge where I work. They can be flashed in 12 minutes and quick learned in 5 minutes if the trans fluid is at the right temp. Warranty time to do this pays 12 minutes. customer pay time is 1 hour.
Gonna search for an aftermarket shop that has a j2534 programming interface....with the $1700 tool...any programming can be bought from bmw for $30.
Old 06-28-2019, 09:38 PM
Update:
The first suppliers kit was not for xenons so I ended up getting bulbs and igniters from europarts.com. Everything arrived on time and all parts were the correct fit. Bulbs and igniters fixed the headlights.
I also found a Non dealer BMW shop that perfomed my trans programming for 1 hour labour time $116. The update fixed everything...the trans is shifting smooth.
Similar Threads
angel eye total replacement headlamps for e39 graves540i E39 (1997 - 2003) 4 11-27-2013 04:46 PM
Headlamps and wipers terryn F30 / F31 / F32 / F33 / F34 / F36 (2012 - current) 8 05-19-2013 02:39 PM
Umnitza pre spring sale UmnitzaSupport E46 (1999 - 2006) 4 03-15-2012 06:40 PM
BMW 650 Headlamps fogging / moisture Jpylori E63 / E64 6 Series (2004 - 2010) 1 11-25-2011 01:53 PM
330i - What years have ZKW headlamps? Shrike E46 (1999 - 2006) 25 05-14-2010 10:29 PM
