2014 GC - A/C cools when driving, but not when idling - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 6 Series > F06 Gran Coupe (2013 - 2018)
BMW's entrance into the 4 door coupe segment to go head to head with the Audi A7 and MB CLS
Old 06-29-2020, 07:24 PM
AttorneyinSC AttorneyinSC is offline
Mein Auto:
My A/C used to cool colder than ice very quickly after startup. Recently it started to require driving for it to cool, and even then itís not as cold as it used to be. Thoughts on causes?
Old 06-30-2020, 03:47 AM
Doug Huffman's Avatar
Doug Huffman Doug Huffman is online now
Nuclear engineer
BMW IHKA HVAC incorporates a cold start-up prevention. It may be more noticeable during one season than another. It requires some engine heat for temperature control before full cooling capabilities are enabled. The BMW IHKA HVAC is not intended or designed to provide a frigid blast but to gently maintain set cabin temperatures.
I have posted the technical description of IHKA many times. www.newtis.info includes IHKA HVAC troubleshooting information. The capacity test is the same across all platforms that I have studied.
Old 06-30-2020, 06:18 AM
QSilver7's Avatar
QSilver7 QSilver7 is offline
Mein Auto: 2006 X5 4.4/2013 650ix GC
Just in case you don't know or forgot...where is your stratified air dial set on the dash's center vent?
When was the last time the interior recirculation filters replaced?
Q {BMW CCA Member #191509}
2006 E53 X5 4.4i (Sterling Gray) 12/05 mfg date <<~>> 2013 F06 650ix Gran Coupe` (Black Sapphire) 1/13 mfg date
(SOLD)
97 740iL (Arctic Silver) <<~>> 99 540iT (Orient Blue) <<~>> 95 525IT (Alpine White)
https://www.bimmerforums.com/forum/attachment.php?attachmentid=637911&d=1538398374&thumb=1&stc=1
Old 07-04-2020, 12:23 AM
Robin750 Robin750 is offline
Mein Auto: 2013 750i and 2015 740i
If the AC is no longer blowing cold, the most likely cause is low refrigerant. Even though the system is sealed, some refrigerant will be lost through the compressor when it is running. Given the age of the car, it may be normal loss and the system just needs to be evacuated and refilled to the specified amount.
Below is the article about refrigerant:
https://www.newtis.info/tisv2/a/en/f...eck/1VnYI6BJG5
2015 BMW 740i and 2013 BMW 750i (current)
2011 BMW 750i (previous)
2002 BMW 745i (previous)
2001 Lexus LS430 (previous)
delete pls 8K
*NEW* delete pls 8K
Old 07-04-2020, 03:25 AM
Nuclear engineer
Did YOU read your linked article with understanding? Particularly the part about permissible leak rate, 30 grams 1 ounce per year up to 150 grams 5 ounces before it is permissible to recharge.
BMW HVAC is ECE type accepted and very robust and ECE allows interference only by licensed TECHNICIANS - not shadetree mechanics.
Old 07-04-2020, 12:41 PM
Not sure what is the point that you're trying to make. Without evacuating the system, how can you tell whether the leak rate is permissible?
I never suggested this was something you can DIY. It's always better to be equipped with some knowledge beforehand when going to the dealer.
delete pls 8K
*NEW* delete pls 8K
Old 07-17-2020, 01:43 PM
QSilver7's Avatar
Just to verify...are you driving in Eco Pro mode? If you are, it affects the AC.
(SOLD)
