E63 power steering not working - Bimmerfest - BMW Forums
Old 07-10-2020, 04:01 PM
Hanybahie E63 Hanybahie E63 is offline
Mein Auto:
5 Steering Issue
Hi gents
I got Error Active Steering Fault and steering alarm in dash board, some time power steering not working
Where is the problem I changed power steering oil and nothing happened....
6 series 630i 2005
Please any one can help
Old 07-10-2020, 04:13 PM
Mein Auto:
I got diagnostic report as attached
What is required for solve this problem And why communication faults?
Old 07-10-2020, 04:14 PM
Mein Auto:
Diagnostic report attached
ID:	900295   Click image for larger version
Old 07-10-2020, 05:43 PM
HerbP HerbP is online now
Super Moderator
Mein Auto: 05 645Ci, 14 750 M-Sport
I am not sure what you are using for diagnostics, but the fault for the steering is marked as a safety fault, which will need to be removed from the module itself. ISTA will do this, but not sure if your diagnostics can enter the module itself? Try & disconnect the battery overnight, & see if the faults will clear. Have you been having battery problems, since all these faults are popping up. This sounds like your battery is low on voltage, it must stay above 12 volts at all times.
Old 07-10-2020, 11:23 PM
Hsurf's Avatar
Hsurf Hsurf is offline
Super Moderator
Mein Auto: E63 645ci
That's a lot of faults, +1 on the battery as low voltage will cause this type of thing, do the lock to lock steering reset after confirming the voltage is good then clear the codes, let the car go to sleep and then re-read them, see what you get.
Neal.
_________________
E63 645Ci
Toyota Hilux Surf 3.0
Honda CBR1100XX
_________________
Old 07-11-2020, 02:46 AM
Mein Auto:
Many thanks for your reply I just changed the battery to bosch 100AMP I'll disconnect the battery during this night and tomorrow let's see I hope it will work
Regards
Old 07-11-2020, 08:20 AM
The Thomas J The Thomas J is offline
Living the dream.
Mein Auto: 2004 645 convertible
Regards
Did you register the new battery?
This is how I roll
