Yellow Triangle W/exclamation Goes on Periodically - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 1 Series & 2 Series > E82 / E87 / E88 / F20 1 Series (2008 - 2014)
Old 10-14-2019, 03:10 PM
NucGal NucGal is offline
Mein Auto: I 135 Convertible
My yellow triangle goes on periodically, when I check nothing shows as problem. My mechanic, a highly respected BMW shop has checked at least 10 times, and even reloaded the software and nothing shows as a problem.
Had the car into the BMW dealership for the recent recall and they checked, as the light was on, and they found nothing. I am getting ready to sell the car and I know this will stick out like a sore thumb to potential buyers.
This is a 2010 135i and the problem light only comes on occasionally. Sometimes it comes on and goes out in 10-15 minutes, other times it will stay on for a few days. Thoughts?
Old 10-15-2019, 06:11 AM
waaazooo waaazooo is offline
Mein Auto: Audi b8.5 s4
When my oil level was a little low it would do that. No problems since 1/2 qt of oil and 1000 miles
Old 02-03-2020, 12:26 AM
iosman123 iosman123 is offline
Mein Auto:
Just got a not to bad offer on a lease for a new loaded 2019 m240i conv.
Sure autoputzer will disagree but leaning that way as opposed to buying my 235 or an m4. Thanks
Old 02-03-2020, 05:36 AM
jaye944's Avatar
jaye944 jaye944 is offline
where da clutch at ?
Mein Auto: BMW 128i Msport
did he pull codes ? even an expired code will still stay on the system, find it hard to believe there are "NO" intermittant codes found by anyone
Old 02-09-2020, 10:10 AM
Mein Auto:
Originally Posted by iosman123 View Post
Just got a not to bad offer on a lease for a new loaded 2019 m240i conv. .
Thanks my issue has been fixed.
Old 02-21-2020, 04:14 AM
dannymajlak dannymajlak is offline
Mein Auto:
Just got a not to bad offer on a lease for a new loaded 2019 m240i conv here.
Thanks for the information. I guessed it correctly that codes will expire with in a time frame.
Old 02-21-2020, 04:23 AM
jaye944's Avatar
unless the codes are physically cleared using INPA etc, they won't just expire/disappear, they may not show on an OBDii tester or on the idrive or the dash display,
but it will always show up in the system, I check my car regularly on INPA, it will show codes (that I have not cleared) as expired or non effecting, but still there.
This is important for diagnosing intermittent faults.
I had a code for a blown bulb, which I fixed, didn't bother clearing the codes, it stuck in the system for ages (as clear with the millage) till I cleared it
Anyway your issue is fixed which is good.
2010 135i, yellow triangle warning
