Convertible top not working e64 2008 - Bimmerfest - BMW Forums
Old 01-18-2020, 02:43 PM
Dami916 Dami916 is offline
Mein Auto: BMW 650i
I'm having some issues with convertible top, opening trunk and rear window. None of them works properly. Top is completely not responsive, to open the trunk I have to manually turn the key and rear window goes up by 2in every time I press the button. Any advice on how to check what's wrong would be greatly appreciated. I was told it might be convertible module, if that's the case is it simple repair or it involves some coding or programming? Thanks
Old 01-18-2020, 05:45 PM
HerbP HerbP is offline
Super Moderator
Mein Auto: 05 645Ci, 14 750 M-Sport
Look in the DIY section for help, there are plenty of topics on the top problems.
Old 01-18-2020, 06:02 PM
Mein Auto: BMW 650i
Thanks but the only problem I'm finding in DYI section is the faulty sensor which is definitely not the case. My top is totally not responding. The only thing I noticed is a clicking noise coming from inside the car when I try to open the trunk.
Old 01-21-2020, 04:56 PM
zod zod is offline
Mein Auto: 1987 BMW 535is 2008 E64
I had a wire chafing problem with the trunk wires to where I had to use the physical key. There were wire bundles on both sides of the trunk.
Old 01-21-2020, 06:01 PM
Super Moderator
Send roseng a PM to see if he can point you in the right direction. I have a coupe, so I have not see any problems with the top. Gary should have an answer for you.
Old 01-21-2020, 06:24 PM
Mein Auto: BMW 650i
I sent him a PM, thanks
Old 01-21-2020, 06:26 PM
Mein Auto: BMW 650i
When you've had the problem with wires your convertible top still worked?
Old 01-22-2020, 01:19 PM
zod zod is offline
Yes - sorry for the tardiness
Old 01-22-2020, 08:36 PM
roseng's Avatar
roseng roseng is offline
Mein Auto: 2016 528i + 2007 650 Vert
Sorry I wish I had some input for you. Iíve never had that problem. Do you know that there is a handcrank in the compartment above the interior light at the front top? That may help you get it to a position where I can reset.
Sorry I wish I had more input.
Good luck
I Love LA. It lets me ride in the winter with the top down.
07' E64/Black....14' F10/M-Sport White
Old 01-22-2020, 08:46 PM
Mein Auto: BMW 650i
Sorry I wish I had some input for you. I've never had that problem. Do you know that there is a handcrank in the compartment above the interior light at the front top? That may help you get it to a position where I can reset.
Good luck
Yes, I tried that but no luck.
I'm thinking about getting used convertible module on EBAY and trying to replace it.
Just don't know if it needs some programming or not.
Old 01-22-2020, 08:47 PM
zod zod is offline
I only had a problem in the right wire bundle. The fact that you would put a wire bundle in a moving part is abhorrent to me. The Germans have a different way of doing wiring.
Isn't there a diagnostic tree for this?
