Bmw tis - Bimmerfest - BMW Forums
Old 07-26-2013, 08:06 PM
Dami916 Dami916 is offline
Mein Auto: BMW 650i
Bmw tis
So I finally found the BMW TIS online, downloaded and this mother...r won't work on my iMac. I need that for the front control arm replacement. Does anybody has pdf or something that will open on mac?
Old 07-26-2013, 08:46 PM
kjboyd's Avatar
kjboyd kjboyd is offline
Drink the koolaid or else
Mein Auto: 2017 Volvo XC60 T5
Bmw tis
Old IMac? I had this problem too. Any chance you have virtualPC or a Citrix network at work that you can run IE from?
Kevin
2017 Volvo XC60 T5 - "Asgaerd"
2015 X1 sDrive XLine - "Hamilton Maxwell"
2009 MINI Cooper Clubman - "Oxley"
2007 Volvo S60 2.5T
2007 X3.0si PlatBronze/Beige
2006 X3 3.0i, Flamenco Red/Beige
1997 528iA, Oxford/Tan
1994 318iS, Black/Gray
1979 528iA, RubyRed, Tan
1971 2002, Sahara, Saddle
Old 07-26-2013, 08:50 PM
Mein Auto: BMW 650i
new iMac, I installed something called wine, which supposed to open windows files on mac, but it's not working. I installed the program, but it says that I need ODBC??
Old 07-27-2013, 06:25 PM
Mulchman's Avatar
Mulchman Mulchman is offline
Mein Auto: '07 650i
TIS is a Win 95 era program. That is probably your issue. You may want to buy one already setup on virtual machine.
'14 X6 i50 - Deep Sea Blue Matallic
'07 650i Coupe - Black Sapphire Metallic
'11 328i Sedan - Alpine White
Old 07-27-2013, 06:44 PM
HerbP HerbP is online now
Super Moderator
Mein Auto: 05 645Ci, 14 750 M-Sport
This should help you out!
Good Luck!
Old 07-27-2013, 06:54 PM
Mein Auto: BMW 650i
Good Luck!
This is lower control arm, the upper control arm is called tension strut, I think. If you could give me that in PDF that would be great,
Old 07-27-2013, 07:23 PM
Super Moderator
The 1st post just said control arm?
Old 07-27-2013, 07:29 PM
Mein Auto: BMW 650i
thanks a lot, is this it, just one page?
It looks so easy. Dealer want $600 for that.
Is alignment necessary after installation?
Old 07-27-2013, 07:33 PM
Super Moderator
I would say that anytime you remove & replace suspension parts, an alignment is always recommended. I would watch the tire wear very close, if you do not do an alignment.
Good Luck!
Old 07-27-2013, 07:35 PM
Mein Auto: BMW 650i
Good Luck!
Thank You
