rear window seals for coupes (free) - Bimmerfest - BMW Forums
E36 (1991 - 1999)
Old 10-31-2016, 12:26 PM
JayMac JayMac is offline
Mein Auto: 01 M3, 83 320is, 75 2002
Getting my e46 M3 ready for paint and am replacing the window seals. There is an inner seal that goes behind the top of the window that prevents the window from hitting the metal on the car. On the e36 they are a separate part but on the e46 they are not and the roof trim with the rubber is rather pricey so I thought I would order a set of the e36 seals to try before I bit the bullet. If any of you plan to replace your seals on the rear windows and need the inner seal hit me up via IM and I will hook you up with these. You have to remove your roof trim to install these but if yours are cracked, like most are, you might want these. Only take them if you are going to use them.
For a reference these are part numbers: 51 36 8 119 961 and 962. New!
Jay
