BMW E70 X5 - DIY and How-To Thread - Page 5 - Bimmerfest - BMW Forums
Old 06-02-2019, 10:32 PM
plunkyjon plunkyjon is offline
Mein Auto:
I've been struggling with an intermittent Dynamic Drive Failure light for the past 8 months. Thought we licked it for a while, but it led to a High Voltage draw and then eventually came back. Other posts say it might be the module, as I already replaced the front shocks.
Old 10-03-2019, 06:18 PM
orthotist orthotist is offline
DIY_Nation_TH
Mein Auto: 2002 M3, 2009 X5
BMW X5 E70 Door Handles DIY
Fix those sticky door handles with my step by step, DIY. Hope this helps someone out.
Thanks!
Old 12-19-2019, 12:07 PM
MrCarMAN MrCarMAN is offline
MrCarMAN
Mein Auto: BMW X5 E70 3.0si
BMW E70 Oil Change DIY
Hello Everyone,
I just wanted to share with you how easy it is to change the oil on the BMW X5
Old 12-19-2019, 02:44 PM
Blown540 Blown540 is offline
2010 BMW X5 35d
Mein Auto: 2010 BMW X5 35d
THANK YOU! Very Helpful---
THANK YOU and this should help everyone too! Jim in TN
E 46 M3 2005 6 speed Convertible- 3- X5 35ds E70s, 2010 models, Shelbyville, TN 37160
Old 04-07-2020, 08:21 PM
IBRAHIMMICHAEL IBRAHIMMICHAEL is offline
Mein Auto: X5 2011 3.5I
Ignition coil replacement now miss fire
HI , MY NAME IS IBRAHIM I HAVE X5 2011 3.5I , I MANAGED TO CHANGE THE 6 IGNITION COILS BUT AFTER ALL JOB DONE , STARTED THE CAR WELL BUT NOW ITS MISS FIRING AND SHOWING LOTS OF MESSAGES REDUCED POWER , STEERING MESSAGES
Old 04-07-2020, 09:38 PM
B4_685 B4_685 is offline
Mein Auto:
What coils did you buy and from where? Did you seat them properly? Do you know the misfire was caused by coils or did you just change them as a Ďfirst stepí? Need more info about the car and whether plugs were changed.....
Do you have a scan tool you can check for codes? If you do, find out which cylinders and transpose with non misfiring cylinder to verify new coil isnít bad out of the box
2012 E70 X5 50i
