iDrive controller not working - need help with diagnosis and P/N - Bimmerfest - BMW Forums
Old 03-30-2020, 09:23 AM
meanieme meanieme is offline
Mein Auto:
Hi I purchased a used 2012 x5 not too long ago.
Today the iDrive controller stopped working - buttons, round knob, nothing works.
The screen seems to function ok because I can use some voice commands to move the selections on the screen. The iDrive seems clean and console underneath is clean and I don't see any signs of liquid spills but I don't know the previous history since I just bought the car.
I tried everything from resetting the iDrive system, removing iDrive completely and opening it up and using electronic contact cleaner, and I also unplugged car battery for reset.
Before I spend more money to buy a replacement iDrive, can someone please help me with a few questions:
1) In my case no buttons or knob work. Is it most likely the iDrive or could it be something else like the wiring?
2) Is there anything else I can try? Is there a fuse for the iDrive and if so which number is it.
3) My iDrive P/N is 9334611, I checked eBay and I see some P/Ns are 9205177 or 9285443 but they look exactly the same. Can I use those too? Also there are some being sold but with mounting brackets.
Thank you so much for your help.
Old 03-31-2020, 09:39 PM
Mein Auto:
No one?
Old 03-31-2020, 10:05 PM
FredoinSF FredoinSF is offline
Mein Auto: 4 BMWs, 1 Mini, 1 Vespa
Could be as simple as a connection issue or failed controller due to a spill or shear bad luck.
I think you need to have a look see under that controller. Hopefully itís simple. Failure of the controller seems rather rare but a spilled slushy / venti pumpkin spice latte / Franzia / Coors light by the PO could have done it.
Sent from my iPad using Bimmerfest
Current:
2018 540ix
2015 428i convertible
2013 Cooper S
2007 650i - 6 speed
2002 330ci convertible - 5 speed
Past:
2012 X5 Diesel
2012 Countryman S All4 - 6 speed
2006 Cooper S - 6 speed
2006 330i - 6 speed
1997 328is - 5 speed
1991 318is - 5 speed
1988 635csi - 5 speed
1988 325i convertible - 5 speed
1969 2002 with tii and 5 speed conversions
Old 04-01-2020, 08:38 AM
Mein Auto:
I took apart the controller and also looked under the console and I can't see any indication of any spill but can never tell. that was my concern as well because didn't think the controller just fails on its own so wondering if there is something else i can check like a fuse or.....
Old 04-01-2020, 08:51 AM
Doug Huffman's Avatar
Doug Huffman Doug Huffman is offline
Nuclear engineer
Location: Washington Island, Wisconsin, thru Death's Door
Mein Auto: CPO2012 X5 35d M57(E70)
www.newtis.info. Chapter 61 General Vehicle Electrical System. Subchapter 31 Switches. Section ~190 - 200
PN 65 82 9 334 611
Scepticism and Animal Faith (1923)
Scepticism is the chastity of the intellect, and it is shameful to surrender it too soon or to the first comer: there is nobility in preserving it coolly and proudly through long youth, until at last, in the ripeness of instinct and discretion, it can be safely exchanged for fidelity and happiness.
(The Works of George Santayana p. 65)
Eschew eristical argumentation. I am responsible for what I write, not for your understanding of it.
Old 04-01-2020, 09:21 AM
ard ard is offline
Resident Curmudgeon
FWIW..BMW part numbers are arranged as 11 digits
Xx-xx-x-xxx-xxx
The first 4, xx-xx are basically the main group and sub group. Like 'electronics' and 'idrive'... 'or drivetrain' then 'transmission'
The first 4 are usually NOT placed on the part itself.
Doug give you the full part number
II am NOT a fan of eBay, Unless you are shopping for used parts.
Alignment here: The Definitive Alignment Thread
OE is Original Equipment aka 'BMW Original Parts' aka 'What you buy at the BMW dealer with a BMW label'
OEM is Original Equipment Manufacturer... EITHER the company that made the OE part or.... A part this is identical to the OE part, but is sold by the OEM under their own label
OEM is not what BMW sells
http://www.bimmerzone.com/category/T...ricks_OEM.html
https://www.turnermotorsport.com/t-OEvsOEM
Old 04-01-2020, 05:40 PM
Mein Auto:
This is what controller and console looks like. Don't see any obvious liquid spill damage but who knows.
ID:	887263   Click image for larger version
Old 04-12-2020, 06:45 AM
Mein Auto:
UPDATE: The new iDrive controller I ordered came in yesterday, I plugged it in, and it still does not work. ARGH!!
I started checking the fuse boxes with the fuse diagram and notice I don't have all the fuses as shown in the fuse diagrams. Are we supposed to have them all? For example, F119 and F142 both say Multimedia control module but I only have a fuse for F142.
Can someone be so kind as to post a photo of their passenger and trunk fuse boxes? That way I can tell if I am truly missing some fuses, one that hopefully fixes my iDrive?
Old 04-12-2020, 06:51 AM
Nuclear engineer
A167a
https://www.newtis.info/tisv2/a/en/e...6-fuse/p6Hb9Pt
5 A F119 supplies video module A197
20 A F142 supplies CIC N38b
Old 04-12-2020, 12:55 PM
Mein Auto:
Doug! Thanks to you so much I got the iDrive working again!
Turns out someone had put the 10A in Fuse 7 slot instead of Fuse 6, so I just moved it and it works!
Do you know if Fuse 7 does anything? It looks like Tire Pressure and Cruise Control?
If so I'll go buy a 5A Fuse for Fuse 7 since that's what it is rated for.
Old 04-12-2020, 01:28 PM
Nuclear engineer
Learn to use NewTIS and its schematic wiring diagrams. The component identifications on the WD are links to location images and more information.
