BMW E70 X5 - DIY and How-To Thread - Page 2 - Bimmerfest - BMW Forums
Old 11-28-2015, 11:01 AM
Originally Posted by SpeedFrK View Post
Anyone seen instructions to replace the upper radiator hose on the 4.8 N62 motor? I can figure out how to get at and remove the hose but it seems like the BMW clamps require a special tool, can anyone verify? The new part images have the clamps on there but I have looked at then on my car and they seem crimped. Maybe just some images on how to remove the old and set the tension on the new ones?
Not sure exactly what the hoses are like on the N62 but when I did the cooling system refresh on the E46 the hoses had a metal collar sort of arrangement (not sure how to describe it.) Pull on the collar, it releases tension the hose can be pulled. See this video, just past 8:00 mark
I would assume the hoses on the N62 would be a similar arrangement, but who knows. Hope this helps.
Old 12-01-2015, 03:54 PM
SpeedFrK SpeedFrK is offline
Mein Auto: 2010 X5 xdrive48i
That is very similar to how the hose clamps work. Thanks for the video, it was helpful none the less.
Old 12-02-2015, 11:44 PM
11leven 11leven is offline
Mein Auto: 2012 X5d
Any DIY transmission, differential and transfer case oil change?
2012 X5d...with all possible pks & flowers...
Old 12-04-2015, 03:08 PM
rrubberbandman rrubberbandman is offline
Mein Auto: a bmw x5 soon
second that and also i want to change my own oil on my 35i 2011 any diy on this?
Old 05-16-2016, 09:52 AM
Davegsu Davegsu is offline
Mein Auto: 645 ci
Can we get one for the headlight washer replacement?
Old 05-16-2016, 11:38 AM
icuc's Avatar
icuc icuc is offline
Mein Auto: 2012 X5, 2012 MINI ALL4
You can turn off the headlamp washer if you don't want to fix it.
BMW Coding for E, F and G Models - www.bmwminicoding.com
Old 05-16-2016, 12:07 PM
Mein Auto: 645 ci
No I'm in need of replacing the cover and nozzle. It got ripped off in a car wash.
Old 05-20-2016, 03:18 PM
Vojta8407 Vojta8407 is offline
Mein Auto: BMW X5 4.8i V8
Hello,
I just made a short vid about PCV, its just slide of few images to help you find PCV witch is actually moved to ventilation hose...Before replacment I was looking in forum and noticed that few more ppl had the same problem.
Maybe it will be usefull for someone.
Bye.
link ->
Old 05-31-2016, 02:46 AM
chiefl954 chiefl954 is offline
Mein Auto:
Hey fellow BMW fans I'm looking for a DIY on an N55 engine to change the spark plugs. I have a 2011 X5 35i. I have the spark plug socket on order so hopefully by the upcoming weekend i can do the job. Thanks
Old 08-29-2016, 09:31 AM
ard ard is offline
Resident Curmudgeon
Not sure this has been linked... wachuko's DIY on the VW DEF temp sensor
Diagnosis of 4D32 (DEF temp sensor): https://www.bimmerfest.com/forums/sho...20#post9452920
DIY replacement using OEM VW part begins at post 11:
https://www.bimmerfest.com/forums/sho...81#post9800681
OEM is not what BMW sells
Old 09-03-2016, 10:18 PM
x5Boise x5Boise is offline
Mein Auto: 2014 E63 AMG S, 4Runner
Due to scattered info on the web, I just created a DIY for changing the D1S Xenon headlight bulb (including pictures, which are probably more helpful than my text):
https://www.bimmerfest.com/forums/sho...d.php?t=929184
Old 09-17-2016, 07:51 PM
Armand Armand is offline
Mein Auto: 2019 X4 M40i 2016 435i GC
E70 Daylight Running Light Replacement
Video for replacing burnt DLR lights (the angle eyes don't light up): Thank you Daniel Boland!
Driver side gave up after six years and nine months exactly to the day (65K miles). Took less than 5 minutes to change. The H8 $15 at AutoZone.
Old 09-18-2016, 03:37 AM
Doug Huffman's Avatar
Nuclear engineer
"Without touching it ...". He touched the bulb glass on removing it from the package. I recommend using cheap cotton glove liners.
What reason would an owner have to believe that the stealership's mechanic would be any more careful as long as the bulb lit when he drove away?
Old 10-19-2016, 11:12 AM
ard ard is offline
Resident Curmudgeon
Transmission and Shifting issues:
https://www.bimmerfest.com/forums/sho...9&postcount=20
https://www.bimmerfest.com/forums/sho...8&postcount=23
Beginning on post 34...really nice pics and discussion:
https://www.bimmerfest.com/forums/sho...d.php?t=930091
(Note above, first 30+ are funny, then he gets down to business...)
Old 11-05-2016, 08:34 PM
orthotist orthotist is offline
DIY_Nation_TH
Mein Auto: 2002 M3, 2009 X5
DIY How To Do BMW X5 E70 Straight Pipe Install
Old 11-05-2016, 08:38 PM
DIY_Nation_TH
DIY How to BMW X5 E70 Install HID Fog Lights Conversion Kit
Old 11-05-2016, 08:40 PM
DIY_Nation_TH
DIY How To Do Install BMW X5 E70 4.8I AFE Pro Dry S Air Filters
Old 11-05-2016, 08:41 PM
DIY_Nation_TH
DIY How To Do BMW X5 E70 HeadLight Restoration
Old 11-05-2016, 08:43 PM
DIY_Nation_TH
DIY How To BMW X5 E70 4.8I Redline Water Wetter Coolant Additive
Old 12-20-2016, 10:41 PM
routeburner's Avatar
routeburner routeburner is offline
Bimmers4Life
Mein Auto: 2013-X5
Originally Posted by orthotist View Post
Looks great. The stock foglights are so pale next to the pure white headlights they look out of place.
"Work is for people who don't Golf".
Old 12-29-2016, 12:58 PM
Jersey John Jersey John is offline
Mein Auto: 2013 X5 xDrive35i Premium
Any information out there on adjusting the rear tailgate/hatch?
"So many faces in and out of my life. Some will last, some will just be now & then. Life is a series of hellos and goodbyes, I'm afraid it's time for goodbye again" - Billy Joel
"If winning isn't important, the why keep score"
Every day I'm reminded that Common Sense isn't common.
Old 01-09-2017, 07:18 AM
serge1's Avatar
serge1 serge1 is offline
Mein Auto: 2011 BMW X5 35D
Starting With Rheingold/ISTA Diagnostics
*Prepare Hardware
1. Set Sleep settings to Never (will be a long download time, 10 hours, on that later).
2. Purchase K+DCom cable online
*Get Software
1. Ask user Reclaimer for download link
2. Sign up for trial version on mega.nz
3. Login to mega.nz
4. In Chrome, add Extension for mega.nz (extension allows avoiding "HTML 5 disk space limit" error).
5. Start/Run mega.nz extension
a. URL bar should now have something like: chrome-extension://..
6. Paste download link URL in place of "chrome-extension://.."
7. R-click Tools > Download > download As Zip. Let it finish before proceeding.
8. R-click "ISTA+ Installation Guide v4.03" > Download > download as Zip. Let it finish before proceeding. \
9. R-click "unblock.reg" > download > download as zip. Let it finish before proceeding.
10. This is a big one with Rheingold.7z
a. R-click Rheingold.7z > Download > Download as Zip.
b. Let download run (a couple hours).
c. After 5 gigs get downloaded, a message will pop up informing that limit for transfer was exhausted.
i. The options are to pay $5 or wait 7 hours.
ii. Let browser sit and wait on this message - don't click anything. It will dismiss itself and continue.
d. Observe download resumed after 7 hours and message is gone. Download should finish.
* Install Software
1. Open "ISTA+ Installation Guide v4.03.pdf"
2. Follow instructions (carefully)
a. Found this a little confusing:
"Step 2: Install everything in Tools folder" - seems to suggest Tools as target installation directory. Wrong.
It actually means "Run all installers located in Tools folder".
* Connect to Vehicle and Configure Port and Driver (info source)
1. Plug in the K+D-Can cable into OBD on vehicle and USB on computer side. Let it install drivers automatically.
2. Go to Device Manager -> USB serial port properties -> port settings -> advanced -> change port number to com9 and latency timer to 1
3. Open C:\EDIABAS\BIN\EDIABAS.INI with notepad and check that "Interface = STD:OBD" and in TCP settings ensure "Port=6801"
4. Open C:\EDIABAS\BIN\OBD.INI with notepad and check that "Port=Com9"
* Test Connection
1. Open ISTA program by clicking shortcut created earlier
2. Click Operations -> Read out Vehicle Data -> Complete Identification.
3. In a minute, ISTA will return a graphic of the system modules.
Happy Diagnosing!
Old 01-09-2017, 07:20 PM
boostedX5SAV boostedX5SAV is offline
Mein Auto: X5 35i
Originally Posted by serge1 View Post
*Prepare Hardware
*Get Software
3. Login to mega.nz
* Install Software
* Configure Port/Driver
(http://www.bmw-icom.org/how-to-setup...-kd-can-cable/)
* Connect and Test
1. Open ISTA shortcut
Happy Diagnosing!
Do I need to have the cable connected to the car and laptop for me to get the repair diagrams/instructions?
Old 01-10-2017, 09:10 AM
serge1's Avatar
No.
Operations -> VIN -> Input VIN:
The documents will be under "Vehicle Management" and "Workshop/Operating Fluids" tabs.
Old 01-15-2017, 09:32 AM
DIY_Nation_TH
How to BMW X5 E70 HID Headlight Replacement 6000K DIY
