X5 E70 CCC upgrade to 10.25" Android - Page 7 - Bimmerfest - BMW Forums
Old 09-05-2017, 04:46 AM
weaselchops weaselchops is offline
Mein Auto: X5 E70 3.0sd
Originally Posted by rpoitras View Post
So if you have factory cameras does the unit automatically switch from Android to the car screen when, for example, putting the car in reverse? Or do you have to switch it yourself every time?
Yes, auto switches to factory camera view.
Old 09-05-2017, 09:26 AM
pplayer pplayer is offline
Mein Auto: BMW X5 E70
Originally Posted by IvanBux View Post
Hello!
2. Middle speaker in/out is made for passing through the sound from Android to OEM middle speaker if you have this one. I've got HiFi pro system with the Center speaker in the centre of the dash. So you should connect the OUT to the speaker and IN to the OEM CENTRAL speaker connector. If you don't have such speaker the easist way just not to connect this. Or you can run the wires to the LEFT or RIGHT speaker of the car, which won't be easy.
My car also has top hifi. Where are the connectors of the speaker and central speaker that you connected the middle speaker in/out wires to? Do you feel the sound better when connected than not connected to those speaker? Thanks
Old 09-05-2017, 10:01 AM
IvanBux IvanBux is offline
Mein Auto: BMW X5 E70LCI MY2011
It's in the center of the console.
See attached images.
So you should remove central speaker to get to the connector and remove installed Android screen and than connect the speaker and connectors.
As for the sound - this is not for the quality but for the Android navigation can "talk" through the speaker while you are listening the radio.
ID:	658585   Click image for larger version
ID:	658593   Click image for larger version
ID:	658601   Click image for larger version
Name:	E70 Speaker Layout (Premium Audio).jpg
ID:	658609   Click image for larger version
Name:	E70 Speaker Layout (Standard Audio).jpg
Old 09-05-2017, 10:15 AM
Thanks a lot Ivan. By doing this, is the OEM radio or music still able to output to the central speaker?
Sent from my SM-G920F using Tapatalk
Old 09-05-2017, 10:21 AM
Yes, radio will be muted through the central speaker only in case of Android navigation is speaking.
Old 09-08-2017, 03:44 PM
ill_kuma's Avatar
ill_kuma ill_kuma is offline
Mein Auto: 2009 X5
Might be a dumb questions but do you have to disconnect the battery before doing all the wiring?
Old 09-08-2017, 04:09 PM
miguellara420 miguellara420 is offline
Mein Auto:
You're supposed to.
Sent from my Pixel using Tapatalk
Old 09-08-2017, 04:34 PM
msan msan is offline
Mein Auto: 2012 X5 35i / 2011 E90 M3
Unboxing AVIN
Got my AVIN CIC model in. Also added CarPlay (I am an iPhone user and mainly wanted ability to view Waze app on the big screen). No included instructions so will follow what people have done in this thread.
ID:	661609   Click image for larger version
ID:	661617   Click image for larger version
ID:	661625   Click image for larger version
ID:	661633   Click image for larger version
Old 09-08-2017, 04:45 PM
More pics
ID:	661657   Click image for larger version
ID:	661665   Click image for larger version
ID:	661673   Click image for larger version
ID:	661681   Click image for larger version
Old 09-08-2017, 05:13 PM
ill_kuma's Avatar
Mein Auto: 2009 X5
Originally Posted by miguellara420 View Post
You're supposed to.
Yeah, I know we are "supposed" but did anyone of you guys did disconnect the battery first?
Old 09-09-2017, 01:34 AM
Serge858 Serge858 is offline
Does anyone know what the Camera DET cable is intended for? I am about to purchase the Android head unit together with an aftermarket wireless rear view camera and trying to understand how to connect it to the unit. The main question is if the Camera +12V is ON all the time or on reverse gearbox mode only. I don't want the camera receiver to be ON all the time (only when Reverse is ON) in order to avoid any radio interference. Appreciate any clarifications.
Old 09-09-2017, 03:53 PM
Got it hooked up but I also get "No Signal" when trying to view the original car CIC..... Tried unplugging and re plugging the y adapter to no avail....
Old 09-09-2017, 04:34 PM
No, I didn't
Old 09-09-2017, 05:43 PM
Originally Posted by lalit.sis View Post
Hey Guys installed my yokotron, took me 3 hrs also being a first timer. However it showing no signal! Any ideas please? Also I couldn't find place to put one cable from the original unit with locking hatch and 8 pins female to new unit? Pretty Poor instructions for installation....
Did you solve your issue? I'm having the same problem
Old 09-09-2017, 06:37 PM
I also got the "No signal" sometimes but normally after a reboot it is ok. Below is what I got from their newest instructions. I've never tried it.
iDrive Reboot
Symptoms: prolonged BMW screen at startup, then "NO SIGNAL" when switching to "original car," no audio, iDrive controller only partially worked in the AVIN menus, and green SOS light in headlineroccasionally blinked.
Push both eject buttons (DVD and CD) and the volume knob (a.k.a themute button) at the same time. Wait about 30 seconds for the factory system to complete its reboot. https://www.bimmerfest.com/forums/sho...d.php?t=254420
Old 09-09-2017, 10:08 PM
I am an idiot. I never reconnected the "purple" plug into the new screen. Once I connected it it's all good
Old 09-10-2017, 02:54 PM
What are the wires "Middle Speaker In", "Middle Speaker Out", "Camera DET"? Where to connect them to? I guess the "Camera DET" and "Camera +12V provide power for rear camera. However under the name "Camera DET" there are Chinese words start with 360 so I guess they may have something to do with 360 degree camera.
Sorry I tried to post the picture from my google photos but it did not show up. But those who has the unit should know those wires.
You will see a middle speaker cable where you removed your old screen. Just unplug and plug in the two plugs in and out. No need to mess with the middle speaker from the top. The cable is accessible from under/behind the screen.
Old 09-10-2017, 06:10 PM
Can you guys tell me "CAN type" setting works for you and what size screen you started with? I have a 2012 CIC 8.8" and can't find a good CAN type. I used #6 per instructions but original car doesn't work when I restart the car. I get a blank screen .
Old 09-11-2017, 07:14 AM
noelskii noelskii is offline
Mein Auto: E70
Finally got my Apple CarPlay adapter. Pretty cool!
2007 X5 3.0 Si
Old 09-11-2017, 03:46 PM
Dubai2013's Avatar
Dubai2013 Dubai2013 is offline
Mein Auto: F01 & E71
I just made it. I felt so bad that my CCC didn't show an original screen like CIC. Anyway, everything worked fine except the knob of course as well as the Aux sound for android. It's kinda of having a background noise when you play someting. My next project is going to be retrofitting a CIC which I already have all parts (But original camera didn't work before) and I will use an emulator I received from bimmerretrofit OR I will ask the Chinese friends to make an emulator to operate the follows ( RFK original camera, TV and DVD). I shall order another android screen that supports the CIC and give a try.
ID:	663385   Click image for larger version
Old 09-11-2017, 03:57 PM
Dubai2013's Avatar
ID:	663401Click image for larger version
ID:	663409Click image for larger version
ID:	663417Click image for larger version
ID:	663425Click image for larger version
ID:	663433Click image for larger version
Sent from my SM-G935F using Bimmerfest mobile app
Old 09-11-2017, 06:08 PM
BiGJZ74 BiGJZ74 is offline
Mein Auto: 2008 BMW X5
Audio when mirroring???
I installed the unit in my X5 today, when i try to use Airplay screen mirroring for my Iphone 7plus running w/ ios 11, the 10.25 inch screen goes blank gray, and audio just crackles and makes popping noises, Bluetooth audio works fine otherwise. Has anyone else had this issue? or know what to troubleshoot. Could it be do to my phone using a beta version of ios11 and not ios 10?
On a side note, does anyone know the password to the DEVELOPERS SETTINGS? in android?
Old 09-11-2017, 06:11 PM
Is there a way to get Media cover art when using BT Audio?
Old 09-11-2017, 06:41 PM
Knob should work well with old CCC controller: Go to Settings -> System Info -> Factory -> Enter 1314 OK -> CCC IDrive Type = iDrive B
Old 09-11-2017, 08:03 PM
Dubai2013's Avatar
1314
10.25" ccc e70 android radio
