oil filter housing post warranty repair - Bimmerfest - BMW Forums
Old 12-19-2017, 07:20 PM
ugottricked ugottricked is offline
Mein Auto: 2012 x5 3.5
Just got quoted from the dealership that my 2012 bmw x5 3.5 has a oil filter housing leak again. The thing is I had this replaced under cpo warranty less than two years ago. Now because I'm out of warranty they won't cover the part because the initial repair wasn't out of pocket! What are my options?
Old 12-19-2017, 09:19 PM
ard ard is offline
Resident Curmudgeon
Yeah, they changed that a few years back.
How far out of CPO warranty are you?
Dealers can try and get BMWNA to cover it, but you live in NYC- basically owners are viewed as chumps with wallets.
OEM is not what BMW sells
Old 12-19-2017, 09:20 PM
ard ard is offline
Resident Curmudgeon
Also, maybe time to find a good indy?
Oh, you can try telling the SA "you get this covered by BMWNA this 100 bill is yours"
Old 12-19-2017, 09:43 PM
I'm about 8 months out of warranty
Old 09-28-2019, 07:26 AM
ChiefCockeye ChiefCockeye is offline
Mein Auto: X-5
My 2012 E70 XDrive 530i was in for warranty work & the dealer said my oil filter mounting was leaking -$2500-$3000 to repair. I did NOT have the recommended work done. I had NEVER seen or had any oil spots on my garage floor prior to the warranty work, but started seeing occasional spots quarter sized spots soon after the warranty work. I checked for the 'oil leak' myself and quickly found the OIL FILTER COVER to be the source of the leak. The cover was torqued properly, so I bought a new NAPA oil filter (comes with a new 'O-Ring" to seal the cover. That fixed the problem - for several months. But after several months the oil leak around the cover returned. I put on a new oil filter and the problem went away, again, but returned several months later. I've tried using different brands of filters/O-rings with the same results. A new O-ring stops the leak for a few months (about 6-9 months), but the leak will return.
After 'fighting' this 'leak' for about 3 years, I've finally decided to try replacing the Oil Filter Cover (OEM P/N: 11-42-7-525-334).
Anybody else seen this problem? The fix?
Old 09-28-2019, 07:34 AM
1bad540's Avatar
1bad540 1bad540 is offline
pretty sure on my 535 paid about 350 at my indy to do the oil filetr gasket leak. to the o ring, make sure they didnt damage any of the rings.
[SIGPIC]
e39 540i sprt, acs type 2's,acs pdls,clrs(sold)
e65 745i sprt,21's aib's acspdls, rf splr(sold)
e46 328i 18" 335spt whls(sold)
c5vette 6sp,z51,2"drp,19"ccw'sshrt shft,corsa exh,dd nav(sold)
e53 X5 3.0, pna rf,,20"4.6rims.(sold)
e65 750I aw, sprt. 21's,acs pdls,acs rfsplr,mtecs,8k hid(sold)
Srt10 VIPER, 19-20" forged,tune,corsa ex,intake.
w221 S550 amg,dia white,20"s63rims
e70 3.5 aw.mtec,20" 214 whls.
e46 M3vert,6spd,19"HRE,bbk,ext,intke
w222 S550 amg, dia white
Old 09-28-2019, 08:35 AM
twh twh is offline
Mein Auto: '06 530xi 6sp, '09 X5 3.0
Some other thoughts:
There are some folks that have put the large o-ring in the wrong groove.
The cap could be cracked.
There could be a leak coming from the oil filter housing gasket.
Old 09-28-2019, 01:34 PM
Ziggy328xi Ziggy328xi is offline
Ziggy.
Mein Auto: 11 328xi N51
the fix is to use a quality german filter, OEM or MANN or MAHLE. others cause leaks
Old 09-28-2019, 04:50 PM
sohor1's Avatar
sohor1 sohor1 is offline
Mein Auto: 2012 X5 35i
It should cost max $500 to do both OFH gaskets...average is 3-400. Stop going to the dealer now that you’re out of warranty.
