R12 to R134 - Bimmerfest - BMW Forums
E36 (1991 - 1999)
Old 05-09-2019, 07:56 AM
franan franan is offline
Mein Auto: 14 F10 5spd,3 E30 5 Speed
R12 to R134
My plan for the summer is to convert my 1992 325i from R12 to R134. Any tips? What do I need in order for a successful job? Do I have to change the expansion valve? I know I have to change the receiver as well. Let me know Thanks.
Old 05-09-2019, 08:43 AM
Doug Huffman's Avatar
Nuclear engineer
First hit on my not G00gle search engine
https://itstillruns.com/convert-r12-...m-6616048.html
Old 05-09-2019, 09:52 AM
bluptgm3 bluptgm3 is offline
Mein Auto: 99M32
Originally Posted by Doug Huffman View Post
Wow, they did not recommend changing anything. Is that an over simplification?
Old 05-09-2019, 10:07 AM
Nuclear engineer
I dunno. R-12 is Dichlorodifluoromethane and It may be the case that any elastomer resistant to it is also resistant to 1,1,1,2-Tetrafluoroethane R-134a. They are pretty similar chemistries.
But note IMPORTANTLY that R-134a is also banned for its (((Global Warming Potential))) and is being replaced by 2,3,3,3-Tetrafluoropropene, HFO-1234yf, a hydrofluoroolefin (HFO) with the formula CH2=CFCF3. It is also designated R-1234yf.
When my refrigerant must be replaced then I will order R-1234yf.
Among all of these changes the AC oils have compatibility problems.
Old 05-09-2019, 10:55 AM
southpark11235's Avatar
southpark11235 southpark11235 is offline
Mein Auto: 1999 BMW 323is
Don't change to R134a. R134a does not work as well as R12 so in a system designed for R12 you are going to lose around 20% of AC capacity. Instead use R12a. R12a works just as well as R12 so your AC will blow just as cold as it does now. Also R12a has a global warming potential of 8 vs R12 at 7300 and R134a at 1200. You can get R12a online from a couple of places. Personally I use Frosty Cool. Somethings to keep in mind. R12 and R134a use different connectors on the AC system so you are going to want to either install R134a connectors or use adaptors. It takes less R12a to fill a system so you are going to want to do the math to figure out how much to use. Use a scale to measure the refrigerant. The system needs to be under a vacuum before you put refrigerant in because there should not be any air in it. Fix any leaks before you put new refrigerant in. If you are low on R12 you have a leak. If the system still has any R12 in it, take it to a shop to have the R12 removed. R12 is not something you want to dump into the air.
Alex//1999 323is - power e46 M3 seats, style 43 rims, 328 exhaust, Z3 rack, Bilstein PSS coilovers
//1992 Mazda Miata - cat delete, power windows, oil filter relocation
We got about ten minutes before this entire county is up in flames. If you want to live, youd better step on the gas! Oh wait is this a Tesla? Sh!t! Well, step on the prissy pedal, we're going to die! Cartman
Old 05-09-2019, 11:14 AM
Nuclear engineer
HC-12a A.K.A. R-12a EPA Unacceptable Substitute
"Substitute (Name Used in the Federal Register): All flammable refrigerants, including OZ-12 (Hydrocarbon Blend A), HC-12a (Hydrocarbon Blend B), and Duracool 12a except HFC-152a and HFO-1234yf in new MVACs.
End-uses: Motor vehicle air conditioning, retrofit and new.
Reason: Lack of adequate assessment that characterizes incremental flammability risk."
https://www.epa.gov/snap/unacceptabl...e-refrigerants
Old 05-09-2019, 11:38 AM
It is only against the EPA to use R12a in a R12 system directly. Using R12a in a R134a system is fine by the EPA and so is using R12a in a R12 system after it has been converted to R134a. Converting R12 to R134a just involves changing to R134a fittings and putting R134a in. Considering there is no way of know if R134a was in the system after you put R12a in, I would say that just swapping the fittings is fine. If you want to be 100% by the books you could put R134a in the system and then recover it, but that seems silly to me.
Similar Threads
AC Refrigerant Type for Recharge (R34 or R134?) clarkyoung E63 / E64 6 Series (2004 - 2010) 1 04-06-2014 06:56 PM
refrigerant in 1997 e39, R12 or R134? Kapten_sjovild E39 (1997 - 2003) 11 01-13-2014 10:52 AM
1990 735i A/C Upgrade to R134 (or next gen) archlab Classic Bimmers 0 06-22-2012 03:45 PM
R-12 to R134 325_family E36 (1991 - 1999) 1 04-10-2006 10:29 AM
