Bmw e39 540i M62tu Stalls on revs 1600 or more for short period - Bimmerfest - BMW Forums
Old 11-30-2019, 01:49 PM
bigmind69 bigmind69 is offline
Mein Auto: BMW
Hello,
I'm facing a problem on my Car Bmw e39 540i M62tu when i try to push the gas pedal on 1500 RPM or more for 2 minutes or less the car start to stall and the fuel will cut.
What i did, i try to remove the back seat and hear the Fuel pump and what happen is the fuel pump sound start to decrease until it stops and as i feel that there is vacuuming happened inside the tank since the fuel leveler is also decreasing more and more the car start to stall and then when i push the acceleration more the fuel pumps starts again with full load and the fuel level it goes back. i add the video on the below link.
i try to remove the connector of MAF and and the same on the above statement, there was no issue in fuel pump the sound is normal and the car doesn't stall.
Do you think the MAF is the reason of what happening for my car, or there is another issue could be.
The below link is the sound of Fuel pump.
Old 11-30-2019, 02:16 PM
edjack edjack is offline
Mein Auto: '97 540i 6 speed
Cannot identify the clicking sound.
Have you monitored the fuel pressure?
How old is the fuel filter?
Old 11-30-2019, 02:38 PM
Mein Auto: BMW
Clicking sound it is like the tank is getting vacuumed when the pump starts to decrease it sound and when pump starts again the vacuum get released.
No I didn't monitored the fuel pressure
I change my fuel filter and fuel pump and i get the OEM Bmw parts since two years
Old 11-30-2019, 04:35 PM
mattmar1's Avatar
mattmar1 mattmar1 is offline
Wingnut
Mein Auto: 1999 5281 5 sp msport
if you think the gas tank is going under a vacuum, loosen the gas cap. you will probably get an evap emissions error code, just reset it after
99 528i 5sp sport
be alert...the world needs more lerts
Old 11-30-2019, 08:27 PM
JimLev JimLev is offline
Mein Auto: 540/6, '16 Highlander XLE
Here's some background info.
https://www.bimmerforums.com/forum/s...d-not-starting
His 2000 540 uses pressure to test the Evap system for leaks.
New Sig, per Hitdog's request.
Next Project.....New Ride
2000 540/6 Slightly tweeked...everywhere
Old 11-30-2019, 11:35 PM
Mein Auto: BMW
But why it doesn't happen when i remove my MAF connector? By the way i don't have any problem with Idling and even i don't have any Error on Scanner.
